Should I blow $160 on Compass 28mm Chinook Pass tires for my 1987 Bianchi?
#126
Quoted: 3015 Post(s)
Liked 3,802 Times
#127
Quoted: 1216 Post(s)
Liked 185 Times
Oh man Clement Stradas are some of the worst rolling and least comfortable tires I've ever seen. Like a stiffer, harsher gatorskin. Pretty much anything is going to be better.
#128
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
The 60TPI match your description. The 120TPI (which I put on this bike in the photo after I replaced them with Conti 4000sII on my primary ride) aren't terrible, although the Contis were a significant improvement.
#129
Occam's Rotor
Liked 2,331 Times
Bianchi replaced my original frame in late 1989 (and upgraded it from SL to SLX). The original one cracked at the front derailleur braze-on. (That was the main reason I decided to modernize rather than restore it.)
#130
Occam's Rotor
Liked 2,331 Times
I've recently acquired a nice clincher wheelset and am considering this 'twin pack' purchase.
https://www.probikekit.com/bicycle-t.../11443944.html
Vittoria Graphene in a 28mm, 2 for $90 with free (slow) delivery from UK.
Mine arrived today, so I decided to put them on. I struggled for the better part of an hour to get the first tire mounted, and finally got the tire on the rim, only to find I pinched the tube. My hands are in pain. There is no f---ing way I could deal with this on the road. The tires look great, but if I knew they would be this recalcitrant, I would never have pulled the trigger.
My wife helpfully suggested I take it to a LBS to have them do it.
#131
52psi
Quoted: 790 Post(s)
Liked 802 Times
The difference in quality between my wife's 35mm Compass Bon Jon Pass and my 32mm Paselas is massive. The Compass tires' rubber is far more supple and... what? Organic feeling? Whatever it is, they're just really, really well made, and you feel it the moment you touch them.
That said, I too had to fight -- and I do mean fight -- to get them onto her '95 Trek Matrix rims, pinching two tubes in the process a la @wgscott and very quietly swearing about whether or not installation was even possible. It was freaking ugly. I've heard that they stretch somewhat once installed on the rim and things get easier, but I can't confirm that and seriously hope she'll never have to try. I've also heard of installs with zero hassle though, so rim-specific maybe?
Am I going to put them on more bikes? Absolutely yes. But at the price I'll have to pace myself.
#132
Occam's Rotor
Liked 2,331 Times
I bought the Vittoria Graphene 28mm. With a combination of soap, hair dryer, and my least evil tire levers, I eventually got them on, and they look beautiful, but the process kind of took the joy out of it. I can't even imagine how I am going to deal with a flat in the field unless these things stretch out a bit with use.
I have box rims, which doesn't help. (They don't have a well in the center like modern wheels).
After I got the rear tire on, I realized I hadn't lined up the valve with the logo on the tire, which is pitting my obsessive-compulsive instincts against my hope never to have to re-mount either of those tires again.
I'm also worried that with all the soap on those rims, the brakes will never work again. Where I live, I need brakes...
#133
I'm not one to "blow" $180 bucks on a pair of bike tires but I do like having good tires. So, I took a look at the value received.
Let's assume something in the range of X,000 miles of tread life for that $180 price. That's something on the order of $1/hour for your enjoyment of those tires (possibly as low as $0.10 per hour). What other form of entertainment costs you so little, adds so much value to your quality of life AND is actually good for your health?
#134
Quoted: 7348 Post(s)
Liked 2,465 Times
There is the KoolStop Tire Jack™ and there are other, similar products. I have one bike with tight tires, so I strap the tire jack onto the down tube using a ball bungie. I move my seat-attached tool bag to whichever bike I ride, but the tire jack stays on that one bike. They make a difficult job into an easy one. Using a tire lever to install a tire, I have a 50% chance of pinching the tube, but the tire jack doesn't pinch the tube.
#135
Bikes: are fun!
Quoted: 466 Post(s)
Liked 863 Times
The bike looks great with the new tires. Judging by the small pic on my phone the rims appear to be H Plus Son TB 14s, yes? I’m curious what the measured tire width is on those (wider than vintage) rims. I have the same to go on a bike that should just fit a 28 mm true-width tire. Rubber is currently undecided.
#136
Liked 185 Times
#137
#138
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
But on the bright side. I know what not to buy for MY next clinchers. Thanks for the feedback.
Glad my fleet is almost entirely tubular, but I followed this thread because I need some supple tan-walled clinchers. Never Paselas! Probably Veloflex, given your Graphene hassle.
#139
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#140
Quoted: 1949 Post(s)
Liked 2,010 Times
I'd like to know what rims are on that Bianchi. Matrix rims have given me nothing but trouble mounting tires.
#141
Occam's Rotor
Liked 2,331 Times
#142
Occam's Rotor
Liked 2,331 Times
#143
Occam's Rotor
Liked 2,331 Times
I need to figure out what pressure to ride these. For a 200lb payload, I don't want them too squishy.
#144
Occam's Rotor
Liked 2,331 Times
Most humble apologies for the pricing heads-up on a tire that caused pain. Everyone gushes about how great they are; I've no experience with the new Vittoria Graphene. I used Vittoria clinchers a lot in the past and largely for the simple reason they were an easy on/off the rim. ??? I assume mounting hasn't been an issue on this wheelset with other tires???
I wouldn't avoid these tires because of this.
#145
Veteran, Pacifist
Liked 4,832 Times
Nothing a bit of Ibuprofen won't help. The Stradas I had on there were recycled from another cycle, so my guess is that they traumatized me less. (I don't remember.) Box rims don't have a well in the middle, so they are always more of a challenge.
Hey WG - haven't seen riding pics from you on the Where Did You Ride thread. Give me a shot of Ice Cream Grade or something in Bonny Doon, for old times sake please.
#146
I bought one of the Kool Stop jacks when I bought the Vittoria graphene (25’s) for my Trek. I use one of the Rivendell Banana Sacks, it fits in that bag no problem.
#147
Occam's Rotor
Liked 2,331 Times
@Wildwood: Right around the corner, on Martin Road...
#148
Veteran, Pacifist
Liked 4,832 Times
Ahhhhh yes.
The carved wood sign and redwood fence propped with 2X4s - takes me back in time and younger years.
Thanks
edit: Can't recall BD Volunteers, but spent quite a few hours in the Bonny Doon Vineyards' tasting room - with every out of town guest i could drag over there; I remember it well, not exactly in Bonny Doon and as eclectic as your avatar, @wgscott.
Thanks
#150
Also, there are so many uncertainties in the numbers, it did not seem worth my time. BIG uncertainties are buried in those numbers for tire life (miles) and rider's average speed (mph). If one considers very inexpensive tires (as low as free) as an option to reduce cost, and the uncertainty in taxation and shipping costs, sale prices, etc., well,... I hope you get the idea.
It's just another way to look at the OP's balking at the price. Make sense?
