Rear IS to 220mm disc caliper adapter--anyone make one?
Bikes: 2000 Santana Sovereign SE; 2005 Co-Motion Speedster; Kona Kilauea with various dorky commuter accoutrements; Mercier Kilo TT fixie; Burley Fladbed trailer for groceries, bags of cement and the like.
Quoted: 95 Post(s)
Liked 85 Times
Does anyone make a disc-brake caliper adapter for a 220mm rotor on a frame with a rear IS mount?
I've searched and cannot find. (I did find an IS front to 220mm post adapter from Hope)
Our Co-Mo speedster came with a 203mm adapter, and I added a 203mm-post-to-220mm-post adapter on top (see below), as I've seen done in pix elsewhere on this site. It works fine, but looks kinda jury-rigged and clunky. Would be nice to have a single piece.
Quoted: 95 Post(s)
Liked 85 Times
Quoted: 559 Post(s)
Liked 648 Times
Riiiiiiigh... it's for a tandem bike!
Ok, makes sense now.
so, like this?
https://www.modernbike.com/magura-qm46-disc-adapter-203---220mm-black
https://www.bike-discount.de/en/hope-pm/pm-adapter-q-203mm-to-220mm
so, like this?
Quoted: 95 Post(s)
Liked 85 Times
Those go from a 203mm post mount to the 220mm. You still need another adapter under that to go from the IS mount, effectively creating the post mount.
Quoted: 95 Post(s)
Liked 85 Times
I thought IS was a standard mount (the two vertical bolt holes) and that it would need an adapter in any case, IS to 160,m IS to 180, IS to 203, etc.?
Someone else here probably has more knowledge.
I'm looking for a single adapter for IS to 220.
Quoted: 502 Post(s)
Liked 436 Times
