Crank set
Old 11-17-17, 10:50 AM
jan minnie
Crank set
I have to purchase a shimano crankset to fit my NEW S5 Cervello. Will a RF-R565 Crank fit a Shimano BBright?
jan minnie is offline
Old 11-17-17, 11:14 AM
Eggman84
Bikes: 2014 Bruce Gordon Rock&Road, 1995 Santana Visa Tandem, 1990 Trek 520, 2012 Surly LHT
Quoted: 211 Post(s)
Liked 43 Times in 35 Posts
Congratulations, you just bought into what is essentially a proprietary "standard". It is marketed as:
BBright™ is a new bottom bracket dimensional standard. BBright™ is the only bottom bracket standard that allows an oversized bottom bracket axle (30mm diameter) and oversized chainstay (79 mm), seat and down tubes (11mm wider). This is the optimum combination of dimensions for the best structural efficiency of the crank and frame system."
Optimum until it time to buy a bottom bracket and crankset. No the crankset won't work. You need one that is for a bottom bracket shell width of 79 mm (the BBright "standard"). The FC-R656 is for a standard 68/70 mm width bottom bracket.
Eggman84 is offline
Old 11-17-17, 11:38 AM
maddog34
maddog34's Avatar
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times in 534 Posts
A standard 68 mm Hollowtech II crankset will fit in the BBright Bottom bracket, and there is no FC-R656 crank set made by Shimano, Egg.
maddog34 is offline
Old 11-17-17, 12:15 PM
Eggman84
Quoted: 211 Post(s)
I won't contest your 1st criticism - you may or may not be correct. That is the fun of these "standards". As to your 2nd criticism, you are correct in that there is no FC-R656. In my defense I only repeated the OP, where I should have asked whether they meant a Shimano FC-R565. Notice the transposed numbers; it happens to all of us except maybe you.
Eggman84 is offline
Old 11-17-17, 12:26 PM
Eggman84
Quoted: 211 Post(s)
I suggest the OP visit the BBright FAQ page at BBright?
Might find correct answer rather than the apparently incomplete/misleading answers found on this forum. Good luck and truly hope you enjoy your bike once you get it set up like you want.
Eggman84 is offline
Old 11-17-17, 12:36 PM
maddog34
maddog34's Avatar
re-read your own post.... then look up the real answer yourself.
the BBright BB assy. accepts a standard HT2 crank set, egg.... and the OP even confirms this fact, on the other thread.
oh, and my post wasn't "criticism", it is the truth.
maddog34 is offline
Old 11-17-17, 07:34 PM
Eggman84
Quoted: 211 Post(s)
Whatever. I learned something by reading the BBright FAQ. I just recommended the OP might find it useful also. Glad to know that you already knew all the answers.
Eggman84 is offline
TimJames
General Cycling Discussion
6
11-20-17 05:47 PM
Diamond
Bicycle Mechanics
12
11-12-17 06:12 PM
Ravencyclist
0
03-20-14 09:07 AM
jlipinski3
Bicycle Mechanics
8
07-24-13 12:54 PM
makeitso5005
Road Cycling
4
01-31-10 04:38 PM
