What can I use to scrub off brake residue off of non-machined sidewalls?
Location: "Gosh honey, you pass more like Tony Rominger..."
Bikes: 2005 Scott CR1 Pro - 1992 Panasonix Fixed Conversion 60tx20t
I goofed when I purchased orange Weinmann fixed gear wheels and used brakes with them-they brake kind of rough look like crap with black smears on the sidewall (I plan selling these and buying the machined version).
Any kind of solvent that I can use to scrub off the brake compound?
"How did all those 'Keep Off the Grass' signs get there?"
Bikes: late 80's bianchi campion d'italia, early 90's trek 2100, early 90's shogun selectra, mid 90's aluminum marin xcMTB, dept. store grade but upgraded columbia double eagle tandem
just make sure its not taking off the paint. acetone might be a problem for that.
Licensed Bike Geek
Rubbing alky or mineral spirits won't remove the paint. But acetone almost certainly would. Same with lacquer thinner because it is really a soup of various solvents with acetone being one of the key ones. And avoid toluene and xylene and anything else with 'lene anywhere in the name as well since those are all highly aggresive solvents.
If it's grit and dust that has been pushed right down into the paint layer then it's going to be near impossible to remove all the streaking without affecting the paint. The other option is to remount the wheels and just carry on using them. Pretty quickly the brake pads will wear away the paint and you'll have nicely "machined" brake tracks. You just quite too early in the game!
Quoted: 5223 Post(s)
Liked 3,579 Times
I use whatever solvent is handy for rims: lighter fluid; engine starting fluid, etc. just be sure to use them outside. apply only to papertowels not directly to the wheels and tires, etc. oh and NO SMOKING! :-)
