Attaching Race to Fork
Bikes: Kickbike, Raleigh M60, Electra Cruiser, Marin Nail Trail, Schwinn Hinge
So isn't there supposed to be something to keep the race from moving? I had to press the race onto my other forks but this one is new to me.
Quoted: 5767 Post(s)
Liked 2,541 Times
Three possibilities
1- the steerer in bulge formed and there is a crown seat, but not as a separate piece. This is fairly common on 1-1/8" threadless forks, so try the crown race and see if you get to an area where it needs to be pressed.
2- there is a seat in the form of a pressed on ring, that a prior owner removed with the crown race.
3- the fork was made for a split crown centering cone, of the type used with many cartridge bearing headsets. These don't need a larger diameter seat since they are a slip fit, until the matching conical lower bearing race constricts them.
FB
Chain-L site
FB
Chain-L site
It's on there snug but I slid it on by hand.
Liked 2,541 Times
To be a bit more precise, these aren't crown races, but crown race centering cones. They're used with sealed or cartridge bearing headsets, where the actual crown race is part of the bearing.
FB
Chain-L site
FB
Chain-L site
Quoted: 2026 Post(s)
Liked 1,095 Times
Right, Chris King calls these "Base Plates" , not crown races since they aren't races at all.
southpawboston
Bicycle Mechanics
22
02-19-15 11:39 AM
illdthedj
Bicycle Mechanics
19
12-14-10 11:38 AM
