Is it possible to ride a bike with ZERO pain and discomfort around the butt region?
#51
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
I have been buying my saddles from Performance Bike and Nashbar (and when they were Bike Warehouse). I usually will buy 2 interesting saddles to test out. But, I usually ride 2 weeks 4-5 days a week, just to break-in my butt, even with a current saddle, after not riding all winter.
Then, when I find one that works, I send back the unfavorable saddle and order 2 more of the saddle I liked, 1 for each bike. As we know, saddle designs change over time.
This of course, assumes the bike is properly fit.
#52
Bikes: '74 Raleigh International utility; '98 Moser Forma road; '92 Viner Pro CX upright
Quoted: 939 Post(s)
Liked 5 Times
The design concept is obviously the same with the Rivet as the SA. I like the "sling" idea and the fact that these never ridge. But are you saying that the Rivets are built sturdier than the SA? Selle Anatomica does say in their literature that it's for riders "up to 250 lbs" if I'm not mistaken so that does leave room for bigger guys breaking rails now and then. I'm only about 190 lbs.
I have SA saddles on three of my bikes and they have stopped stretching except for the one I bought at the end of last year.
The SA is instantly invisible - the Rivet isn't. It takes time to form sit-bone flats. Debra does a loaner thing where you essentially rent a new saddle for 2 months, apply to purchase price or mail it back to her. My daughter could not get one past break-in on her road bike and I sent it back. My daughter finally settled on a Fabric Shallow for her road bike, which has a flexible nylon pan and thin firm padding (and the wrong-shape saddle for our OP).
I ride through saddles, and the SA just didn't last for me. I have many e-friends on google groups who log lots of miles on them, would fight to keep them, and if they last for you, fantastic.
I still say with the 30-day money-back comfort guarantee and current sale price, for our OP to try Selle Anatomica is kind of a no-brainer.
Oh, and I haven't yet ridden through a Select - they last for me, as well as the Rivet.
ps- 6'3", 210 lbs
#55
As far as butt support, riding a bicycle seems different from every other sort of sitting that one may do. Not only does the saddle need to provide some weight support, but it must allow for free leg movement and exercise of the butt muscles, thigh muscles, hip joints, and all that other stuff around the pelvis -- ligaments and such. I think it must provide the ability to position and re-position with repeatability and stability and it should provide support primarily to the bones on the bottom of the pelvis, the ischial tuberosity, or "sit bones."
Looking at traditionally shaped saddles, the Brooks B17s and other relatively narrow saddles, or something like the old Avocet racing saddles, or thousands of other saddles of similar shape, it appears to me that you can see, in the design of these saddles, thought given to these considerations. Basically, how to support a bicycle rider in a normal bicycle riding posture and still allow all the lower body motions that bicycle riding entails. Support is provided mostly to the "sit bones" with some compliance of the saddle to distribute the load a bit and match differences in individual shape and size.
So, I think it should be expected that someone who is not accustomed to riding a bicycle should feel some discomfort or pain in the butt when riding, and afterward. We're not used to sitting in the position that active cycling requires, we're not used to the constant minor position adjustments that get made, there's just nothing else that we do that's like cycling.
So, what other people have said, when someone experiences pain or discomfort some of it may just be what's going to have to be lived with until the rider gets used to the activity.
Also, what others have said about bike fit and adjustment -- particularly not having the saddle too low, which would prevent someone from supporting as much weight as possible with the legs.
Part of fit and adjustment is adjustment of the saddle for tilt, fore and aft position, and nose angle. Seemingly minor adjustments can make a pretty big difference in how the saddle feels and all these adjustments are probably interdependent. All those adjustments, are also probably quite individual. Some people like their saddles tilted rearward a tad more than other people. I like mine tilted just to the point that I don't have a tendency to slide forward.
There are also differences in basic anatomy involved. People have different sized pelvises and many people can't get sufficient support with a narrower saddle like the standard B17 (or the narrower ones like the B17N, Swift, Swallow, Colt, etc). That's why Brooks, and others, make saddles with somewhat shorter noses and wider rears. I've not experienced it personally, but I'm told that trying to use a saddle that is physically too narrow for the pelvis is very, very unpleasant. That's a function of the pelvis size, which doesn't change as we gain and lose weight. Just because someone has more "padding" than desirable doesn't mean a wider saddle as the saddle shouldn't support the extra "padding," it should support the "sit bones."
What does this all mean to the person riding a bicycle for the first time in 20 years? Probably some thought and consideration to the bike, fit, and adjustment. Evaluation of the current saddle and how it is being ridden, whether the rider is on the saddle in the proper position or too far forward. Where, exactly, is the pain and discomfort on the body. If it's muscle ache and pain, that's a matter of conditioning. If it's located in the vicinity of the "sit bones" that's probably a good sign as it indicates that the rider is being supported by the proper body part. If it's chafing discomfort, it may be saddle fit or it may be adjustment related. If the pain and discomfort is forward of the "sit bones" and towards the center, it's likely something that needs to be addressed and fixed right away -- it's not something that somebody is going to get used to. It's something that shouldn't be happening at all and is probably adjustment related, but also may be a function of anatomy and saddle design.
Obviously, I'm not a big fan of the extra wide, extra short, extra padded saddles as I agree with others who have suggested that the basic, traditional, bicycle seat is pretty well designed for the purpose. When I look at those pictures of the saddles designed to solve problems that, in my opinion shouldn't exist, I see something that will screw up my riding experience. But, other people have different opinions and that's ok -- it's a matter of preference, not right and wrong.
#56
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I've used the Brooks B-17, but cannot recommend that saddle due to the generally poorer leather quality of the ones made in the last few years.
I also run very narrow Ritchey and WTB Valcon saddles on my racing-type and mountain bikes, respectively. No issues there, but the saddle comes less into play on those bikes because of how they're ridden.
The answers are: yes, of course, and it may be a long search for you.
#58
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
It might sound silly but Sheepskin, I've always wondered why cyclists never use it? I've used it on my motorcycle, and I've seen cowboys use it on their horses. IMHO it works 100% better then gel seats even though I don't understand why.
#59
Quoted: 939 Post(s)
Liked 5 Times
because that defines sitting on a blanket more than even a giant padded saddle.
#60
Erik the Inveigler
Quoted: 1310 Post(s)
This saddle ends up on everybody's invisible list. https://selleanatomica.com/
If there is a problem with them, the saddles stretch and don't last for distance riding. I tried two, and couldn't get them to last past 6 months.
But the people who swear by them wouldn't give them up for anything.
#61
Quoted: 939 Post(s)
Liked 5 Times
If you check the internet for "how to break in a Brooks saddle" you will find scads of home remedies - soak them in mink oil and stick them in the oven - boil them and let them dry - soak them in water and go for a ride.
All of these of these serve the goal of unnaturally softening the leather and without question shorten the life of the saddle.
I think Brooks made a choice to open themselves to a wider market by delivering softer saddles in their standard grades.
The Gyes saddles come from Taiwan - they're also sold as VO saddles. Yes, they're harder and have a longer life for it.
You and I wouldn't want a 5000 mi saddle. But most casual riders may not ride their bike 5000 mi over their lifetime use of it.
I think it would take our OP a long time to add up 5000 mi, and I'm comfortable recommending a B17 Standard Champion for him.
That said, I still think he should try the Selle Anatomica (especially for 30 days), and believe it will be just what he's asking for.
#63
Quoted: 939 Post(s)
Liked 5 Times
Eric, split hammock leather saddles accomplish two things - their cooling is out of this world.
Second, each side of the hammock moves independently with your legs, which prevents chaffing on a wider saddle like the SA.
It was the first saddle I tried on my Moser - here's a front view, it's not a bad-looking saddle.
But here's how much it stretched in the first 8 miles - so much that the saddle let go of the stretch bolt and I had to stop in a bike shop to borrow tools and reassemble it. Take along the tool to stretch the bolt on rides as needed - eventually it should stabilize.
But our OP needs something to get him out on the bike, and I think this saddle is it.
If it's not this, it's probably the sprung Brooks B67
#64
Quoted: 18369 Post(s)
Liked 4,507 Times
You don't need fancy padded jammies to ride a bike.
As others have mentioned, it often takes a while to get used to riding after a long break. Or, maybe a new saddle.
So...
- Make sure the bike is configured/adjusted well. (Heel on pedal, straight leg (or almost straight) at 5:00/7:00 position. At least for road bikes.
- Some good posterior support. You don't need a saddle the size of a lounge chair. But, I do like a little flatter on top. Mild padding, but nothing excessive. Fizik makes some nice flat top road saddles. Unfortunately my Fizik Technogel (Life Rondine?) is discontinued. The old barrel shaped saddles seem somewhat uncomfortable.
- Put in a few miles before giving up. 100 miles? 500 miles? A few longer rides?
I haven't done any "sit bone" impressions, but some people swear by it.
#65
Quoted: 550 Post(s)
Liked 325 Times
Maybe with things like a better saddle
You'll sink into padding until your ischial tuberosities aka sit bones have solid support which squishes soft tissues that don't do well with pressure like your pudendal nerve. Minimal firm padding prevents sinking so nothing presses on vulnerable nerves and other squishy bits.
A saddle that's too wide will rub on your thighs when you're pedaling. Too narrow and your sit bones will miss the saddle.
I like the specialized Toupe, but your anatomy and therefore preferences will be different.
Note that it takes some distance for your butt to toughen.
better bike underwear/shorts
I like Boure PRO shorts with a flat synthetic leather chamois and Voler shorts using the Comp HP pad with stiff 120 kg/m^3 foam beneath the sit bones.
#66
Bikes: Eddy Merckx San Remo 76, Eddy Merckx San Remo 76 - Black Silver and Red, Eddy Merckx Sallanches 64 (2); Eddy Merckx MXL;
Quoted: 143 Post(s)
#68
genec
Quoted: 13658 Post(s)
Liked 4,532 Times
#70
I haven't ridden a bike in 20 years until recently
#74
Butte Montana Has a Big hole That used to be a mine, now its, their Problem.
and paid by for others
Well except the Hanford nuclear weapons production reactor , that is another perpetual cost.
It is the largest pit lake in the United States, and is the most costly part of the country's largest Superfund site.
#75
Quoted: 88 Post(s)
Okay I am ready to buy a saddle. Which is better for my 2016 Giant Escape 2? Brooks B17 or B67? And what type of allen key would I need? Would a LBS install it for me for free? If not would it cost anything to borrow an allen key for 5 minutes? Does Home Depot have one we can borrow? If the answer is no to the last 3 questions I'll just probably buy an Allen key then return it once I have no use for it. Or maybe I'll keep it, I'll see.
