Possible RRB track frameset???
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times
Picked this up locally off of eBay. Unsure if it is legit RRB built by Ron Boi, but it is older and it is lugged. Definitely rough, has messed up BB which is stuck and appears to have been an issue for a PO also some denting on bottom of the top tube (concerned about crash or accident) as well as rough paint. Possibly a previous owner drilled out for rear brake caliper as well. Guy I bought it from did not know a lot about it, bust said PO bought it from a guy in Racine Wisconsin (I'm in Kenosha). Looks like partial serial or some numbering on BB shell, but it's scuffed as hell and I cannot make it out for certain.
28.6 mm tubing for TT, ST, and DT. Fork looks older, a replacement maybe?
First thing will be to see if frame is straight and take it to Ron's shop to see if I can authenticate it. If it pans out, I will have it stripped, powdered, and then try to build it out with some decent parts.
The dents on bottom of TT
Any input will be appreciated. I will try to post better pics tomorrow. Will update thread after I hear from RRB and or start the build. Thanks in advance.
Quoted: 1136 Post(s)
Liked 650 Times
One thing about track bikes is that top tube dents are very common, from swinging handlebars. That might be the source of your dents if in the right place.
Quoted: 2588 Post(s)
Liked 4,824 Times
I see the dents in the first pic - there appear to be three underneath the top tube. Not a typical place to dent one's bike in normal use/abuse.
Man, those chainstays are massive at the dropout end! And what strange treatment - the ends don't appear to have been brazed over at all.
Lastly, while I can't say for sure, I doubt this is genuine. The lugs are very clunky and don't appear to have received any thinning, same with the BB shell. No finishing attention whatsoever at the brake bridge, and if that paint job is original it was done without primer. RRBs are normally exquisite.
I wonder how it will handle if that fork isn't OEM? If it's a road fork (I see it's drilled for a brake), the rake would compromise a true track machine.
Waiting to hear more...
DD
DD
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,392 Times
I'm looking at that stuck BB - from the looks of it, the drive side still has teeth, so the primary BB shell is still presumably removable with conventional tools.
However, if it does get down to "creative" removal, it looks as if that's one of the Shimano sealed BB's that Park made a tool to adjust (believe it or not) them with: the BBT-6. It might be possible to loosen it up with that tool; not sure if it'd be possible to remove the spindle that way, but it's a thought.
-Kurt
-Kurt
Liked 4,392 Times
Whoever built it might not have cared much about the lugs, but they sure wanted to show off by brazing (soldering?) the tube/dropout interface...and nothing else.
-Kurt
Quoted: 279 Post(s)
Liked 326 Times
DD
DD
The fork, to me, looks a TON like the fork on my 57 Carlton track frame.
I was expecting rough, but after full in person inspection, I'm a bit bummed. Oh well, worst case scenario I have some strange frakenbike. Or I can try to return it on PayPal/eBay.
I'll keep you guys posted 👍
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
RRB still has a shop in Lake Geneva. You might take it there and get an opinion. If worse comes to worst, you can bring it to Ron and Walter in Kenilworth. Plan to be there chatting for long after the discussion about the frame is complete though. Ron's a talker. If you decide to make the trek down, let me know. Happy to get together for coffee or lunch.
Just a wild guess, but there was a Kenosha rider, Rick Dregne, that rode a bike similar to that. And that would have been 40 years ago so memory is a little sketchy. It sure has some similarities though.
Likes For big chainring:
Quoted: 279 Post(s)
Liked 326 Times
Appreciate the insight!! 😎😎
Quoted: 279 Post(s)
Liked 326 Times
If you wouldn't mind that would be awesome! So awesome in fact I would name my first born Big Chainring Barnes in your honor.
Quoted: 1361 Post(s)
Liked 423 Times
Seat cluster is familiar Boi.
Who knows but that bike was possibly raced - a workhorse who had a few mishaps, reworked. Then later converted for street use?? Curious how tight a wheelset sets in the frame and fork.
No shame. Inspect, align, refinish. Though too bad the seller hadn't disclosed the dingers.
Just came from RRB. Ron confirmed it is one of his. The chainstays are called "shotgun" chainstays. I mentioned Rick Dregne and he said yes that would be his size. And I remember Rick riding that color bike, so I would say that was his at one time. Rick Dregne was a track sprinter in the late 70's thru mid 80's. I'm sure he won several Wisconsin Track Championships.
Quoted: 279 Post(s)
Liked 326 Times
Thanks!!!
Also, thanks to my buddy @crank_addict for the assist!
This forum is amazing. I will continue to update as I build up parts stash and look at the refinishing.
Quick question though:
This is no beauty queen. At all. Should I just do a workman like bike with workman like parts? What kind of track gear would be appropriate for the late 70s and 80s? Any additional input is appreciated.
Likes For Senrab62:
Quoted: 279 Post(s)
Liked 326 Times
Oh yeah, I'm a beefy man , extra Clyde but I am steadily becoming a smaller Clyde lol.
I will likely be setting up with front and rear brake calipers. Any suggestions for vintage nutted brake calipers? Or go modern dual pivot nutted route? Thanks again.
Liked 4,824 Times
What to do? Well, you called it - if she's no beauty queen, build it up workmanlike. That's what I'd do. Of course, if you're looking to do it PC, you'll be wanting Campy and that can be an expensive route. I haven't shopped on CL or Ebay for track stuff, but it always seemed to come with a higher price tag a few years ago.
Looks like it will be a super project.
DD
RiddleOfSteel
Singlespeed & Fixed Gear
31
04-05-19 03:35 PM
realestvin7
Classic & Vintage
28
02-27-13 11:37 AM
