Help servicing Vuelta Corsa lite road wheels
I have a set of Vuelta Corsa lite road wheels that are starting to make noise while coasting. Not really sure if its the hubs or the freehub. The sound is intermittent, and happened while coasting down a hill last night with the road slightly wet. Couldn't find any info on how to service them online, is anyone familiar with this wheel set? The rear wheel is 10 speed.
Dave
Dave
Quoted: 4205 Post(s)
Liked 3,864 Times
Gosh now that you mention it my rear wheel is making noise while I coast... Andy
AndrewRStewart
AndrewRStewart
Quoted: 303 Post(s)
Liked 136 Times
Andrew refers to the normal pawl/ratchet sound when coasting any rear wheel makes (unless fixie wheel). So the OP
needs to distinguish the expected sound from what they think they are hearing that differs. IIRC Vuelta wheels have
sealed bearings and not loose bearings and cones (except the bottom end wheels). I suspect that generic maintenance
instructions on such as Park Tool would suffice for a general approach to service.
Quoted: 837 Post(s)
Liked 1,061 Times
Try contacting Vuelta directly. Contact Us (vueltausa.com)
AFAIK the hubs are not cone and cup, but Vuelta does sell replacement axles and bearings (not currently in stock) as well as a replacement freehub.
Dave
Urban Cyclist
Bikes: Guerciotti SLX - 84', Tide-Ace 11sp carbon frame & misc. Shimano parts
Quoted: 8 Post(s)
Dave
Dave
My communications with BDop has been lengthy but not helpful because they don't recognize any of the freehub photos I sent from my Vuelta Corsa-Lite 11sp wheelset, purchased about 5 years ago. The problem I have is removal of the freehub body because it progressively got louder and it was time to take a look inside.
The drive side of the Vuelta Corsa-Lite 11sp hub accepts a 5 mm hex wrench. The non-drive side does not accept hex-key of any size. It's completely smooth bore; the only thing it will accept is the skewer. The cone-covers on both ends of the axle have the flats, which can be turned with 17 mm cone-wrench, however turning in opposite directions from both ends, unscrews only the cone cover on the non-drive side. The drive side cone-cover can be turned in both directions, but all that does is unscrew the cone cover from the non-drive side. Thinking the drive-side cone cover is somehow seized, sprayed with penetrating oil but that accomplished nothing.
My question is, how to open the drive-side cone-cover?
The youtube video posted on this thread, does not apply to Vuelta Corsa-Lite wheelset. It's a different Vuelta wheelset where two hex keys are used on both ends of the axle. Corsa-Lite accepts a 5 mm hex key only on the drive side.
Thank you in advance, if you can comment.
Urban Cyclist
Quoted: 8 Post(s)
This video is about servicing Vuelta Team SL but not Vuelta Corsa-Lite, The latter model accepts 5 mm hex key on the drive side of the rear wheel. The non-drive side does not accept a hex key of any size except the skewer. I have the Vuelta Corsa-Lite wheelset and I'm still researching on how to remove the freehub body to inspect what's going on inside - because it has been getting louder.
Quoted: 430 Post(s)
Liked 460 Times
Two things come to mind: 1) bearings need replacement (does spinning the wheel without holding the freehub still feel rough at all?), 2) freehub is damaged (could either be the freehub shell is cracked or internals are damaged).
