Surly LHT forward-back rocking on descents
Just got a LHT and took her for a 40 mile ride today. I’ve modified from stock by adding VO’s 45 degree stem, but that’s it. On descent at a pretty good clip and on road, but not smooth road, I noticed forward-backward rapid rocking motion. The wheels look true, the brakes aren’t rubbing, all seems fine. What is this?? Doesn’t seem to be the same as shimmy. Bike was not loaded (no racks even) and I’m about 180. Thanks for any hints! Bike broken? Surly master-designed flex that I just don’t appreciate? Magic gremlins?
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
I assume this bike has a threadless headset, and you said you replaced the stem. Did you properly adjust the bearing preload in the headset before tightening the new stem mounting bolts onto the steerer tube. It sounds like you have a loose headset. If this is the case, you will need to loosen your stem from the steerer, tighten the top cap properly to take slack out of the headset, and re-tighten the stem bolts onto the steerer.
Edit: I just looked at the VO stem design, and it looks like this stem eliminates the top cap, and replaces it with a new, longer bolt. This new bolt is what will be used instead of the top cap to add preload to the bearings in the headset.
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
Before you/OP makes any adjustments. Squeeze the front brake and try rocking the bike forward and backward. If the headset is loose, you'll feel the bike/fork rock back and forth.
Check the web for proper tightening. You can load the headset too much.
Likes For fishboat:
aka Timi
As above, first thought was loose headset.
OP: If it turns out to be something else, do report back, would be good info.
Quoted: 18409 Post(s)
Liked 15,520 Times
When braking? My LHT with the model of tire I use can sort of “rock” at the front end with some braking if I’ve been lazy and haven’t checked tire pressure.
But I’m going with loose headset.
Go back to the bike store, that would be your best bet, internet unseen people's no really can help.
Quoted: 759 Post(s)
Liked 810 Times
For the OP..still thinking a loose headset from the stem change.
Quoted: 3458 Post(s)
Liked 1,465 Times
I really do not understand what you describe as "forward-backward rapid rocking motion", are you saying that there is flexibility in how the handlebars and stem feel? Or are you saying the bike itself it rocking? Or something else.
If the headset issues do not solve this, please describe in more precise terms what the symptoms are.
My point is that with nearly all real life mechanics stuff, to learn actual real world "tightness" or "looseness", you 've got to be shown in real life what "good" feels like.
And you do have to have a certain amount of real life mechanical experience or at least inclination. I've shown people I know how to do stuff and it's promptly forgotten and or they continually repeat over or under tightening.
heck,I've screwed up doing stuff so many times it still makes me laugh.
all I'm saying is that interwebs mechanic teaching ain't really practical, have someone show you headset adjustment in person, it takes 10 seconds and hopefully you pick up on the feel for proper adjustment.
Liked 1,465 Times
Likes For Tourist in MSN:
Re headset tightness, a mechanic I trust was going over my bike wheels before a trip, checked out everything quickly and recommended I tighten the headset a smidge, I have lots of spacers, he suggested tight until you can't twist the spacers anymore. Said that for cartridge bearings and touring, that tight is better. I had adjusted it just a bit looser than he suggested, but still with no play with rocking.
just thought I'd mention this, I've ridden toured a lot on this bike like this, and it appears fine, no stiffness etc
brilliant - will do
Liked 1,465 Times
Otherwise it could be a frame problem or perhaps something odd with the saddle or seatpost. In that scenario, unlikely that we can provide much help on this forum. Or a tire problem, but I think that would be noticeable from looking at the tire.
Anything else I can think of would likely cause some side to side motion that you did not mention.
And yes, check out the Parks Tools YouTube mechanic series, excellently made.
Will give you an understanding of headset adjustment etc, and their info is solid and generally very well explained
Quoted: 1182 Post(s)
Liked 833 Times
Another hint if you ever think you will have to ship your bike. If you have cantilever brakes, use your front brake cable hanger to lock your setting in after the headset is adjusted. If you have V-brakes or disc brakes, use a locking headset spacer. This will allow you to remove the stem and not worry about securing the fork and adjusting the head set when unpacking your bike. If you have a LHT, it comes stock with cantilever brakes so changing the stem should not have affected your headset adjustment. If it is loose, it came that way.
the stem can be removed from my wife's bike to facilitate packing, and the headset is secure with a locking headset spacer.
After checking headset, Try it on fairly new smooth pavement, then the bike should ride perfectly smooth.
that smooth-talking gentleman with the almost-handlebar ‘stache is reason I’m where I am! 100% agree.
Another hint if you ever think you will have to ship your bike. If you have cantilever brakes, use your front brake hanger to lock your setting in after the headset is adjusted. If you have
