Can bike riding help lose weight?
Quoted: 18 Post(s)
Hi everybody,
cycling can lose weight or not? My friend cycled daily around the area where she lived but did not seem to notice the weight loss but also tended to increase slowly. Do not know where the problem lies? Can someone point me out the problem?
Thank you very much for your interest in my matter.
Hi everybody,
Likes For HTupolev:
There's a formula for losing weight which is actually quite simple...eat less, move more.
Likes For Outrider1:
Any exercise combined with the right diet can help you lose weight. Question is how much exercise and what type of diet. There are plenty of internet articles on this.
2 speed- slow and slower
Bikes: Gravity X-Rod 8
Quoted: 24 Post(s)
Liked 9 Times
What is she doing besides riding? Typically if somebody wants to lose weight, eating patterns and/or diet need to be at the core of the strategy. This is because, if someone let's their body regulate its own food consumption, it will naturally try to compensate for calories burned by being hungrier more.
Of course I'd say that what kind of riding and how much also figures in. A leisurely turn around the block at a nice casual pace versus running a fitness monitor to stay at aerobic exercise levels to maximize energy usage would also likely produce different effects on the amount of calories expended.
Quoted: 18415 Post(s)
Liked 15,553 Times
Yes. Cycling helped me lose 90 lbs. in nine months.
But eating an entire pizza after a relatively tame ride probably won’t help with weight loss. See what I’m getting at?
Likes For indyfabz:
Not lost wanderer.
Quoted: 886 Post(s)
Liked 996 Times
Yes, it can but you will also gain from building muscle mass.
Diet.
you lose weight by reducing intake.
Diet.
It can. I cobbled together excerpts from a couple articles (below) that helped me when I was trying to lose weight, and helped me understand why weight loss isn’t necessarily the same thing as improved cycling ability.There are different schemes with different heart rate zones, and people use them more or less deliberately when they train but the following scheme is common enough: Zone 1: Very light, 50 percent to 60 percent of MHR (maximum heart rate) Zone 2: Light, 60 percent to 70 percent of MHR · Zone 3: Moderate, 70 percent to 80 percent of MHR · Zone 4: Hard, 80 to 90 percent.
To be in the zone that burns most fat per minute, you want your heart rate to be approximately 70 percent of your maximum heart rate (upper end of zone 2).
Quoted: 576 Post(s)
Liked 1,002 Times
Eating less is the best way to lose weight, exercise adds definition to muscle and helps you look better.
Quoted: 427 Post(s)
Liked 700 Times
My wife is petite. But at one point, she was gaining weight, and couldn't seem to lose it. She was eating "rabbit food", lots of salad, food high in fiber, was exercising, and nothing worked. Turned out it was a thyroid problem, which is now under control with medication. Her weight is steady now, and on a "regular" American diet. She eats healthy foods (for the most part), but isn't dieting. Your friend might want to have hers checked, to eliminate that possibility.
Likes For freeranger:
Quoted: 2604 Post(s)
Liked 1,933 Times
Can bicycling help you lose weight? Absolutely! Either go on a bike tour, where you're riding for 6-10 hours per day for weeks on end, or else reduce your food (calories) intake. Either will work, though the former is more fun. Just be careful with those "well-earned" brownie sundaes after a long day's ride.
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
There was a recent article studying children in the Amazon which concluded diet is much more important than exercise for keeping low weight:
https://www.nytimes.com/2021/02/24/w...in-amazon.html
If you read the article you can get an idea of what kind of (permanent) diet kept weight down: no processed sugars or carbs (that means no white rice or non-whole-grain flour), limited meat and dairy.
I bumped up my exercise big time at the start of the pandemic. I lost 10 lbs at first, but gained it all back as my body caught up and decided I needed to eat more.
Quoted: 20810 Post(s)
Liked 9,456 Times
They say that you can't out-run a poor diet and that is (for the most part) true. Intake is more important to weight loss than output - as has been mentioned, if you exercise more, your body will tell you to eat more, so you need to pay attention to intake. That said, I've gone through stretches where I'd average 4000+ calories burned per day, and I just couldn't stomach consuming the calories necessary to maintain weight (I wanted to continue to drop weight, anyway).
Quoted: 4227 Post(s)
Liked 2,488 Times
90% of cyclists that I see are slightly overweight in their belly area...They have an overall skinny appearance ,except that they have extra fat in their belly area. That right there tells me that cycling is not enough to loose fat. Sure cycling can make you loose weight but most of that weight loss will be muscle tissue and water weight, to burn fat you need to do more than just cycling.
Likes For wolfchild:
Bikes: 2012 Salsa Casseroll, 2009 Kona Blast
Quoted: 1031 Post(s)
Liked 208 Times
Hi everybody,
Say your friend rides 3 times a week for an hour at a moderate pace, burns, say, 500 calories a ride. So 1,500 calories a week. All she needs to do to negate those calories burned is to eat back and extra couple of hundred calories a day. If she isn't really controlling her eating, an extra 200 calories is nothing.
I started cycling in the fall of 2013, at the time I weighed I believe 215lbs and by cycling (and of course cutting back portions and what not) I got down to 155 in a few months. Without cycling to facilitate I don't think I would have lost so much so quickly. I'm currently around 160 and I train pretty seriously, and I credit cycling for being able to sustain a healthier weight.
One thing I like to note when it comes to cycling/weight loss type topics is that the amount of calorie burn the average newer cyclist *thinks* they're burning during a ride is likely to be far less in reality. As an example, I, a pretty well trained amateur, burn about 700 calories/hr at an endurance pace. A newer person might be half of that, so I think people eat because they think they burned a lot, but really the key is to realize that beginner rides aren't going to make a big dent in creating a caloric deficit. So cycling can help if you do it properly, either working to increase intensity in workouts or increasing duration. Really both need to be done eventually, I think. But that's my experience.
Likes For hubcyclist:
Liked 208 Times
But that is not what we are talking about here. The problem is, a lot of folks overestimate how many calories they are burning and underestimate how many calories they are eating. Go for a 2 hour ride and you might burn 1,000 calories, 1,200 or 1,400 if you are really working hard the whole time, climbing hills, doing sprints, or riding into the teeth of a 30 mph headwind. Maybe you ate an extra couple of hundred calories for breakfast before the ride, stopped and ate a 250 calorie energy bar in the middle of the ride, and came home and rewarded yourself with a big meal after the ride. Congratulations. You earned it. But if you are not careful, you might end your day with a calorie surplus.
Cycling is a terrific form of exercise, but it isn't some miracle weight loss cure.
Quoted: 1944 Post(s)
Liked 2,164 Times
Cycling in itself won’t cause you to lose weight. However, cycling, as well as any other tangible motivator, can be the reason to eat less and lose weight.
I think for a number of people, health is not a great motivator to lose weight, but needing to lose weight to be able to ride a trail, or make a climb, or even able to enjoy a physical activity can be.
For me, mountain biking was the motivator. On pavement, depending on the terrain, you can get by being overweight. But those extra pounds really take a toll on mtb trails.
John
John
Likes For 70sSanO:
Quoted: 2952 Post(s)
Liked 3,106 Times
Hi everybody,
Likes For caloso:
Quoted: 3352 Post(s)
Liked 1,056 Times
Hi everybody,
Quoted: 229 Post(s)
Liked 327 Times
I think people grossly overestimate how many calories they burn from exercise. People can lose 1 lb of fat (3500 Calories) per week from reducing calorie intake but most inactive people would blanch at burning 3500 Calories on a bike in a week.
Likes For guachi:
Quoted: 590 Post(s)
Liked 445 Times
I also started cycling in 2013, starting at 225 lbs and within 18-24 months got down to 168 lbs, by riding approx. 6k- 8.5k miles per year, with commuting 25 miles per day, and weekend warrior stuff. My loss was mostly attributed to trying to keep up with the cycling group(s) I joined, which meant being at my very best on Saturday and Sunday mornings, which meant no drinking alcohol on Thur, Fri and Sat nights, and also simply watching what and how much I ate. No real diet needed when riding that much. In theory, 100 miles of moderate to high intensity riding burns about 1 lb of fat (3,300 cals.), especially when you do rides of 50+ miles, since your stored glycogen in muscles and liver will be depleted after about 1.5 hrs of riding, and then your body will rely more on fat burn to fuel you.
