1974 Miyata P-1 Professional ?
Liked 11 Times
Here's a neat old Miyata that followed me home.
Dura-Ace crankset and levers
Really like this head badge
4140?
Looks like it might be a 74 P-1
https://www.velo-pages.com/main.php?g...serialNumber=2
4140?
Quoted: 5888 Post(s)
Liked 3,471 Times
I like it. I don't think I've seen a 4140 chrome moly tubing sticker before (as opposed to say 4130 chrome moly) but apparently it's a real thing,
https://en.wikipedia.org/wiki/41xx_steel
Cool.
Cool.
Liked 11 Times
Mocked up with proper pedals, saddle, post, and wheels.
It would be helpful if someone could confirm the seat post diameter on this frame. The post on it was too small. I've got a 26.6 in there now, might take something larger.
Top tube has some cable clip chew marks. No dents though and it looks like it might be chrome under that paint. Needs some attention.
Liked 11 Times
Frame dimensions are are kind of odd. 21" CTT seat tube and 22.5" CTC top tube. I normally ride 22.5" TT frames but they usually have ~22" seat tubes.
Will this fit my short legs/long torso? Not sure. Must tear down first.
Quoted: 4722 Post(s)
Liked 3,039 Times
Yes, it's a Miyata P-1 Professional, circa 1972-1974. The serial number will narrow down the range.
Edit: During this period Miyata was building with Tange tubesets. Champion #1-#3 all used the same seat tube, with a nominal 26.8mm inner diameter. Standard clearance allowance would result in 26.6mm post. However, Mayata typically performed a ream/hone of the seat tube and 26.8mm posts are common. It could have come with 26.6mm or 26.8mm.
The wheels are not proper. This was a racing model and came with a tubular wheelset equipped with large flange hubs.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Some of the Japanese bikes from that era had crazy long top tubes compared to seat tubes. I've got a 53cm ST ctt, 58cm TT ctc in my backlog right now. Oddest one I have is 50cm ST, 57cm TT.
Liked 11 Times
Thanks for the seat post and tubing info! The wheels were here on the shelf. The set it came with were nothing special. Not planning to run tubulars but will keep an eye out for a wheelset with early high flange Shimano.
When I said mocked up with proper parts I meant reasonably era correct. The seat, post, and pedals are wrong as well. I'm pretty sure it needs KKT Pro Ace rat traps, SR Royal 26.6/26.8 post , and an unobtanium Fujita saddle. I actually need 2x Fujitas to get one on my Fuji Newest. Feel free to PM if anyone has that stuff available
The serial number is B468696
Post a pic of that 50/57 frame in here if you get a chance. Would like to see that one.
Likes For 9volt:
Liked 11 Times
Top tube before and after. The majority of the funk is out of the paint and the battle scars look better in person. Most parts are hung.
Cable housing suggestions? I'm thinking one of the colors in the head badge.
Bikes: Indeed!
Quoted: 1507 Post(s)
Liked 3,478 Times
Now I see why you are looking for transparent green cable housing!
I have transparent blue if you can't find the green.
Brent
Brent
Love it. Super cool graphics and chrome lugs! Transparent housing would look dynamite. Porkchop BMX has all your retro housing needs, I’ve bought from them many times.
Okay I unintentionally lied, just went on the Porckchop website and they have every colour under the sun EXCEPT green .
Wow, VERY similar to my Volkscycle Mark 100 lugs. It was also chrome under the paint, same dropouts IIRC, and same component spec.? Same bar end shifters and all. Eery! Mine even had the same brakes, though in the older Dura Ace name, which was changed to Tourney. Any connection between the two brands that you know of T-Mar?,,,,BD
So many bikes, so little dime.
Bikes: Too many, but sometimes not enough.
Quoted: 225 Post(s)
Liked 18 Times
Very cool! I had one of these that I picked up as a frame / fork off eBay a few years ago. I really liked the ride, but it was on the smaller side for me, and the chrome was only so-so. I wound up putting it back up on eBay to make room for my current squeeze - a 1976 Centurion Semi-Pro.
That decal is probably the remains of another 4140 decal. I actually did up graphics files for my decals, as several of them were in pretty poor shape, and I was considering repainting the frame. If anyone is interested in having them reproduced, I have them as vector based illustrator Miyata-Professional--Combin by c79murphy, on Flickrfiles.
Regarding the long top tubes -- until the late 70s - early 80s, almost all production frames from a given maker were made with a single size of top tube. 49cm frame? Here's your 57cm top tube. 65cm frame? Here's your 57cm top tube. They would just use a shorter stem on the small frames, and a longer one on the larger frames. (This is actually good for me, as I need a tall frame, with a short top tube to fit my long legs / short torso body.)
Here are some photos: https://flic.kr/s/aHskAmgBJo
DSCF3032.jpg by c79murphy, on Flickr
Bikes: 1984 Centurion Elite GT 15, 1985 Centurion Ironman Dave Scott, 1983 Diamond Back Ridge Runner, 1985 Mongoose ATB, 1987 Ross Centaur, 1986 Raleigh Marathon
Quoted: 190 Post(s)
Liked 76 Times
What a lovely bike! While most people drool over the Italian stuff, it's always been the Japanese bikes that really turn me on!
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
Miyata catalog (1974)
Liked 11 Times
The stock cables on the Miyata are interesting. The derailleur cable that came with 1st gen Dura-Ace bar ends is teflon coated:
Are these ball end brake cable ends Dura-Ace specific? Can they be replaced with a common road brake cable? Haven't run into this style before.
The plan is to save these off the bike and run new cables. Probably modern teflon derailleur to match the original look.
Quoted: 225 Post(s)
Liked 18 Times
