brake compatibility questions
Will a set of nice center pull brakes from a Schwinn drop bar road bike work well with flat bar brake levers that came off a 91 Bridgestone MB-1 MTB that also had center pull brakes? I assumed it would. I have everything installed but am awaiting my wheels so I have not had a chance to squeeze them with a rim installed but they seem to have sufficient travel. Did they make center pull caliper brakes with different pull ratios or is a center pull a center pull?
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
You should be okay. Bridgestone tended to be conservative with build specifications, so the brake levers should work with the Weinmann or Dia Compe center-pull brakes.
BTW did they actually make different ratio calipers for different levers or did they spec all levers to match a caliper brake? Also are side pulls a similar ratio as center or did they need different ratio levers to go between those 2 styles? I am aware that cantilevers are a long pull lever but know nothing about the other 2 styles.
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 429 Times
I’ve used flat bar levers for canti brakes with U brakes.
They worked fine but the braking was non linear. Meaning as I applied the brakes they would engage. Slowing just fine.
but if I applied more braking, I’d get more stopping very quickly!
If yer an engineering type- it’s like high gain response.
Cant say it was just the levers, as pads are part of the system. As are the rims.
Just something to be ready for.
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
welp - SheldonBrown specifies U-brake as the type with post mounts - like cantilever brakes, but the posts are in a different location. Just read Sheldon so I don't create more confusion: https://www.sheldonbrown.com/canti-u.html
I was (am?) in my initial reply referring to the same (similar, not quite the same!) brakes that use a single mounting point - like side pull brakes.
Paul Component sells them so you can mount them with a single mounting poin,t or if you happen to have a frame with the appropriate bosses (not canti-bosses), they can be mounted so.
https://www.paulcomp.com/shop/compon...-brakes/racer/
To the best of my knowledge, a person does not need to buy new brake levers until you go to linear-pull brakes (V-brakes). So you can use the same levers for side pull brake calipers (dual or single pivot), cantilever brakes, and U-brakes (either mounting types).
- Roller cam brakes? good night, man! I have no idea!!
cheers.
Mark "The Rim is a Disk!" V.
cheers.
cheers.
cheers.
Likes For trail_monkey:
