When things go just right: Everest freewheel + Regina America
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Those of you following my Match Paramount build will know that I had my eye on this ultra-lightweight Everest freewheel - missing one cog - for some time.
I picked it up from the LBS today, and proceeded to try something:
I've had that 8-speed Regina America 1992 at left for a while; its second-to-lowest cog was cracked when one of the LBS's cast it off:
The 12t cog - which would otherwise thread into the damaged 13t - was fine:
So, out of curiosity, I tried spinning it onto the Everest. Eureka:
The threads mesh perfectly. Who would have known? The America cogs refuse to thread onto conventional Regina Oros - I never would have expected it to actually fit the Everest. Lucky!
-Kurty
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
Liked 4,396 Times
Quoted: 2588 Post(s)
Liked 4,824 Times
Be careful with that new setup, too. I stripped/cracked the two screw-on cogs on two separate Everest Nova freewheels a few years back; one was during a race, resulting in an interesting anatomical meeting with my top tube.
I have one more left with zero miles and I plan to keep it that way. Those things are notorious for cracking right along the threads under load.
DD
DD
Liked 4,396 Times
Funny thing, I wonder if the Regina America's second cog - the one that is broken - is a drop-in fit to the Everest, as with the first. If that is the case, one could conceivably create a slightly more reliable setup w/two Regina cogs.
-Kurt
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Interesting. I was worried about using a steel cog on the outside for that very reason; looks as if I might as well worry about the original aluminum equipment just the same.
-Kurt
-Kurt
Liked 4,396 Times
