Chatter/Judder When Braking
I recently got a new-to-me 2010 Trek X02. Stock brakes and (carbon fiber) fork, upgraded (carbon fiber) stem and bars.
Under moderate to hard braking, I'll get moderate to severe brake judder. I'm not an expert on set-up and tuning of canti brakes. My San Jose does not display any brake judder.
https://velonews.competitor.com/2010/...o-cross_101807
I think the XO2 has holes in the fork crown? Crown-mounted cable hanger would almost certainly improve your situation.
I had severe judder on my TRP brake set-up. The first thing I did was toe the front of the brakes in and the judder went away. Not sure what brand of brakes you have, but that's a starting poing. I used a 1mm spacer at the rear of the brake pad to set the toe -in and that seemed to work.
Experienced
Quoted: 16 Post(s)
I have an X02 but with a Alpha Q full carbon fork; it has no hole for a hanger. I used a deep-drop hanger off the stem and have no judder at all.
cable is like a bow string, if the fork acts like a Bow ,
flexing between the 2 points of the cable fitting , things can act strangely.
fork comfort is flexibility..
the fork mount shortens up the distance to have a stiffer Bow,
Quoted: 3393 Post(s)
Liked 5,577 Times
In addition, the longer your headtube is, the worse it is.
The fork crown housing stops I know about:
https://www.specialized.com/us/en/bc/...jsp?spid=47409
https://www.sheldonbrown.com/harris/c...are-brake.html
Bikes: Click on the #YOLO
Quoted: 26 Post(s)
Liked 12 Times
Also-
https://www.trpbrakes.com/category.ph...1096&catid=188 (color!)
https://www.performancebike.com/bikes...18_-1___400202 (gotta be a coupon or something else you'd want from here.)
Praxis
Bicycle Mechanics
21
08-25-11 07:31 AM
mtnclimber
8
05-23-11 10:26 AM
