Redline Asset for street BMX?
Hello and thank you for having me.
I could use some expert advice, please. This is my first BMX as I could never afford one as a kid. I've been reading threads here about frame material and from what I gather, full chromoly is the best. However, I don't plan to do anything crazy as a weightlifting injury resulted in spinal fusion surgery. Small jumps and hopping over curbs is all my body can tolerate. Would this bike be good for me?
Thank you for your time.
Bikes: Mongoose Maurice FS 2011 fixed gear, custom 2017 Haro Master Flatland bmx, Contrast FL475 mid school flatland bmx
Quoted: 15 Post(s)
Liked 11 Times
I believe that spec is made for the kind of riding you mentioned. Hops, curbs, 180's I think it can handle. If you are dialled they'll even survive trails and parks; but if you still need to perfect that land, be wary of the frame n fork. You may notice frame cracks, but the steerer tube is a diff. story. I found out the hard way! Get a good fork as you progress, they're worth it. And always check the crank bolts; loose bolts always ruins the 48spline types. Too loose here, or too tight there, always ruins it.
I was just giving the poster some attention when I said "aluminum is best". It's best for me because it's light and I don't do tricks. I like the fact it doesn't rust, too.
55+ Club,...
Bikes: 9+,...
Quoted: 1111 Post(s)
Liked 842 Times
Steel bikes are also heavier. The more likely reason is cost. The 7000 series of aluminum is strong as steel at half the weight, much better than 6061, but it probably is prohibitively expensive for this application.
The Apollo Command Model was made of an aluminum honeycomb-sandwich bonded between sheets of aluminum alloy.
Lockheed Martin has chosen an aluminum-lithium alloy for the primary structures of NASA’s new Orion spacecraft.
Ever since the launch of Sputnik a half-century ago, aluminum has been the material of choice for space structures of all types. Chosen for its light weight and its ability to withstand the stresses that occur during launch and operation in space, aluminum has been used on Apollo spacecraft, the Skylab, the space shuttles and the International Space Station. Aluminum alloys consistently exceed other metals in such areas as mechanical stability, dampening, thermal management and reduced weight.
The problem is cost. Cromoly is cheap compared to good aluminum. I can't even find 7075 aluminum tubes from retail outlets online (it can be ordered if you can afford a minimum quantity). Some 2024 is available retail, it's stronger than 6061 but not strong as 7075.
55+ Club,...
Bikes: 9+,...
Liked 842 Times
Bull. Aluminum is strong, extremely reliable, and lightweight, that's why it's used extensively in aviation and even aerospace.
