Cannot get tire to let go of rim
Rim: Bontrager Duster Elite 622 X 22 "tubeless ready"
Tire: Continental Cross King Protect 58-622 (29 X 2.3)
The Conti's were brand new when I installed them last summer. My first try at tubeless.
Today I decided to dismantle the front wheel. Just for practice and to see if the sealant had dried out or what. Bike didn't get ridden all winter.
I cannot get the tire bead off the rim. Tried clamps, figuring if I squeezed the tire into the middle it'd pop off the rim shoulder. Nope. Tried tire levers and other tools. Could get a tiny amount of separation between rim and tire but that was it. Didn't want to deform the rim or damage the tire so I just stopped.
I've changed lots and lots of bicycle tires in my day (motorcycle tires too) but never ever had a tire that wouldn't move off the rim. So if there are some tricks I don't know them.
Liked 2,981 Times
you might try sliding in a second lever in that tiny separation & work it slightly side to side while walking it further across in to the lip of the rim.
-Oh Hey!
-Oh Hey!
Quoted: 4211 Post(s)
Liked 3,880 Times
Try harder. Current tires and rims are becoming tighter fitting as tubeless is being billed as the answer to a question only some were asking Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Rather than using levers to pry off the tire, try getting all of the beads into the center well, grasping the tire in one spot, and pulling it laterally until a bead comes over the rim sidewall. That's not a great explanation, and I'd like to make a video or something someday, but it works well for me when dealing with tight or really stiff tires. It's annoying to my "just use a tire lever!" friends, but I nearly always triumph in the end.
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
Quoted: 645 Post(s)
Liked 797 Times
Likes For Litespud:
Quoted: 569 Post(s)
Liked 589 Times
Tubeless ready rims are a nightmare when you have arthritis in your hands.
Likes For easyupbug:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1949 Post(s)
Liked 1,474 Times
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
With the tire fully deflated, put some soapy water on the bead/rim interface. Let it sit for a bit and try again. It is basically the equivalent of WD-40 for a tight bolt.
Don't use a tire lever to break the bead, you should be able to do that by hand over the entire time. Tire levers can be used to get the bead over the rim.
Likes For vespasianus:
I understand the part about getting the beads into the center. If I were at that stage the rest would be easy. I failed to get the tire bead to move off the rim shelf or shoulder or whatever the correct term may be.
Googled around and ran into some discussion of setting the rim on top of a garbage can, then applying force. I'm thinking of maybe setting a piece of plywood over the garbage can, then using a jig saw to cut out the center. Might cut out some slots that follow the shape of the rim so I could reach in with a C-clamp.
Laid in bed thinking about this instead of sleeping. I'm imagining supporting the rim as described above, then pushing something like a broad blade chipping gun attachment into the gap between tire sidewall and rim. Then use gradual force (C-clamp) or sudden force (hammer) downward, toward the center of the rim. The typical levering action that's usually used with tires won't work because I can't get a lever between the tire and the rim.
Will try soap and water, heating it up, C-clamps, etc. My wife's bike is set up the same as mine, so I'm looking at 3 more rims that might be better or might not.
Sure am thinking about going back to tubes. We're low-key riders, so some of the "advantages" of tubeless aren't much of a factor.
I've been unhappy with the asymmetrical Bontrager 22mm rims. In general, are wider rims easier to work with?
Quoted: 406 Post(s)
Liked 389 Times
Likes For alcjphil:
senior member
I tried everything as well and ended up bringing them to the LBS - the mechanic said it was tough but he eventually had success - I always used Michelin Pro Race and will go back to them - I also have removed lots of tires but these were ridiculous - my personal feeling is that they were manufactured to be used with or without a tube .
What about wider rims? All else being equal, do wider rims put less of a deathgrip on the tires?
Quoted: 406 Post(s)
Liked 389 Times
This 100%. I had a set of Challenge Gravel Grinders (with tubes) and I literally ripped my thumbnail off trying to unseat the bead. Just would not go. Added soap and water, waited 10 minutes and broke away easily.
Likes For KerryIrons:
Quoted: 406 Post(s)
Liked 389 Times
Gone Biking!
Bikes: Orbea Gain, Lynskey, Redline Conquest Disc, Bike Friday, Cannnondale T2 Tandem.
Quoted: 42 Post(s)
Liked 50 Times
Tubless ready rims are the worse
I got a new bike that came with tubless ready rims. The only way I could break the bead on clincher tire to remove was with a shop vice, not very practical to carry on the bike. So I thought I would chance it, until I got a flat tire ridin bike and could not break bead to change. Had to ride on flat tire 13 miles home. Didn't damage tire or break the bead. My solution was to order true clincher rims and replace rims. Problem solved. IMOP there is no advantage to tubless rims or going tubless.
Likes For Pridedog:
Pridedog, you describe the exact thing I worry about.
I've been carrying levers and pump and spare tube with me. Might as well leave that stuff at home.
Quoted: 426 Post(s)
Liked 274 Times
I have had the exact opposite experience. Took me forever to break the bead for my tube gp5000 25mm tire.
The tubeless gravel king slicks 32mm and Vittoria Corsa G2.0 700x25c TLR took almost zero effort. Made question how they stay on they came off so easy.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Yeah, I didn't want to whine, but that's my situation exactly. I can't apply nearly as much force, and my wrist/thumb/hands hurt for days after.
Vehicles - High lift jack
MC - pieces of curved cut wood and C-clamp(s)
I don't see where c-clamps wouldn't work for a bicycle.
or this guy's method
Likes For dedhed:
Liked 2,981 Times
the 4-inch ratchet clamps from wally world work & are less likely to snake bite the tire/tube. Sometimes those small 4-inch ratchet clamps are priced under $2 a pair, making it a better option.
-Oh Hey!
-Oh Hey!
dedhead -
Thanks for the short video. Regardless of how you get there (on the ground, on top of a garbage can, on your own custom plywood work surface) the guy in the video is applying force in the direction that it has to go. Levering won't cut it because you can't get a lever underneath the bead. Force has to be down and away from the rim shoulder. In the video the guy bends over and pulls upward on the rim. Seems to me you could accomplish pretty much the same thing with some wood cribbing under the rim. Maybe use a soft wood like cedar.
I'm optimistic that a technique similar to his (and soap & water) might do it.
Several guys have commented that the tire would be stuck on the rim whether it was a tubed setup or tubeless. I tend to agree. If the tire's bead is a bit too small and the rim is a bit too large, well, that's just physics. Or Murphy's Law. It's just that I've never ever experienced a stuck tire like this and it's my first experience with a tubeless. The tire's been on the rim for several months now so I assumed removal would be easy.
Quoted: 1110 Post(s)
Liked 1,204 Times
OP: do a web search for terms like "removing a dificult tire" or "removing tire bead from rim shelf" etc. There's several Youtube videos on tricks; I encountered the same thing recently - couldn't even get the bead off the shelf in order to get tire levers in there. I ended up using a vise. On another tire I used a board trick I saw on Youtube -which is best explained by watching some of those videos;
