Park does JIS, sort of...
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Did not know JIS was different from Phillips. That is why Shimano limit screws are so hard to turn. Anyway, the first thing I do on any Shimano derailleur is to replace the limit screws with 4mm allen head ones.
Quoted: 850 Post(s)
Liked 1,081 Times
After wrenching without the JIS screwdrivers for 40yrs I finally found out about these and bought some a few years ago. So much nicer to work with, they feel like they lock into Japanese and most any Asian screws and no more stripped or chewed up heads . So whatever they're calling this standard now I recommend them.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
I've always used a small flat-blade screwdriver for limit screws. Hate trying to use limit screws that have been garfed up by someone's use of a Philips.
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Aren't most modern phillips screwdrivers actually JIS anyway? (Flat tipped)
I made a thread about this subject... years ago and I think that was mainly the consensus.
With that said, I often use flat screwdrivers on limit screws.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Phillips is not JIS.
A Phillips screwdriver will cam out (strip) the head of a JIS screw.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 741 Times
i have a custom ground small flat blade for adjusting limit/B screws.... and most limit screws incorporate a flat blade slot anyway.
