chain guard, cover, or bash guard..
What ever it is called....on the bike that i recently purchased...it is missing.
What should I look for as a replacement?
Thanks!
Thanks!
Quoted: 576 Post(s)
Liked 1,003 Times
You dont need a chainring cover unless you ride with long pants. I just roll em up or you can use straps
Bashguard replaces big ring and is for offroading and/or chain retention in single setups
Is there an increased risk of the chain rings scratching or clothes getting stained by the lube?
Quoted: 576 Post(s)
Liked 1,003 Times
Breaking or bending the teeth is the issue that bashguards solve. Scratching is a part of life with drivetrains. Better rings have hard slick surfaces. Anything that comes in contact with the rings will leave a mark - even skin; its called "the mark of shame"
An old helmet strap or velco strap can cinch the pants down, or wear skinny jeans. I just roll up one pant leg.
If you commute a lot in work clothes, you may want a more elegant solution. However, those plastic tabs are silly. Plastic must be avoided as much as possible on bicycles
Replacement? I Doubt it ever had one in the 1st place .
if theyre black it wont matter , tuck your trouser cuff in your sox. or use a trouser clip.
Hoopdriver
General Cycling Discussion
8
05-01-18 03:37 AM
LukeD1uk
Bicycle Mechanics
17
06-03-17 08:12 PM
