Can’t improve my average speed
Quoted: 15 Post(s)
The 20-25 hour a week training schedule? And then the 25-35 hour a week racing schedule? Not particularly useful.
If the OP could ride that many hours, they'd probably be pretty fast, too. For all of us that don't, intensity helps make up for the training load which is instrumental in forcing adaptations (i.e., making you faster).
Riding 5-10 hours a week without much intensity isn't going to make you much faster once you've established some baseline fitness.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
These Garmin devices come with FirstBeat tech: https://support.garmin.com/en-US/?fa...x53UDqUH7q4WC6
Results matter
Results matter
Keep your weight within your height limits. Wider tires increase your speed. If you have 700/23 tires increase to 700/28. Get a Park Tool chain cleaner. Gunk can cut your speed also. Get professionally fitted for your bike. Incorporate weight training to increase leg strength. Carb-up before a ride. You can burn 60 grams of carbs per hour. I hydrate a day before a long ride. Make sure you use a tire pressure formula to ensure you are with your range. Google bike tire pressure calculator..
Let me know which one's above you were not following and how things turned out.
Dave
Dave
