Tip: My tubeless sealant in tubes experiment
Old 09-18-19, 06:13 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 1596 Post(s)
Liked 197 Times in 125 Posts
When the sealant comes out of a puncture it makes a rhythmic hiss as the hole passes through the puddle.
The question is do you go fast enough for the fluid to balance the tire like Dyna Beads?
Genesis 49:16-17
Darth Lefty is offline
Old 09-20-19, 07:03 AM
Le Mechanic
Le Mechanic's Avatar
Bikes: Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 55 Post(s)
Liked 18 Times in 16 Posts
Originally Posted by chas58 View Post
Hardy - Iím guessing you have a bad tire rim combination. As there is no good standard, some tire-wheel combos are too tight (and wonít go on), and some tires are too loose.
Contenital (and others) have developed a new standard they plan on rolling out in 6-12 months that should address that issue. Right now, high pressure road tubeless is hit or miss, unless you match your tire to an approved-tested rim. High-pressure road tubeless also requires a hooked rim. Personally, Iím fine with some fast 32mm tires running hookless at >70PSI.
The main issue with road tubeless is it is generally more miss than hit. I work at a bike shop where we install and service a very high volume of tubeless setups on a variety of bikes. A few combinations work great, but a higher percentage of them (enough that I have a hard time recommending road tubeless) have issues. We sell the Continental GP5000 TL tires, and the hype before we got them seemed like they were the answer, but alas, they are hit and miss as well.
Anything above 32-35mm wide seems to work decent but bellow that, you may be in for a headache.
Le Mechanic is offline
Likes For Le Mechanic:
Old 09-20-19, 09:23 AM
masi61
masi61's Avatar
Quoted: 442 Post(s)
Liked 21 Times in 19 Posts
Originally Posted by HardyWeinberg View Post
For me with skinny (28mm) road tires the problem with tubeless is not punctures (sealant caught'em all!) but just keeping the tires on the rim. Putting sealant in tubes sounds great to me.
Not sure if heís talking about a loose fitting tire or maybe a tubeless tire that just wonít mount onto the rim shelf.
My optimistic winter project of taking some used Dura Ace 7850 tubeless compatible clinchers (that had never been set up for tubeless) got sidelined due to the front tire never being able to hold air and leaking large amounts of air through one of the beads. The stubborn tire is a 23mm Hutchinson Atom. I donít think this tire will ever run tubeless. I mounted and dismounted it like 3 times and caused a small split in the square bead with my tire lever. I need to just wash out the Stanís sealant and put a latex inner tube in there (for now).
I really like latex inner tubes. I think I have heard of folks putting sealant into their latex tubed tubulars with some success. Iím fairly OK with the daily re-inflation before each ride necessary on my latex tubed road bikes. I did consider injecting about 45 ml of Stanís in there as an experiment to see if it changes anything.
masi61 is online now
Old 09-20-19, 09:43 AM
Notso_fastLane
Notso_fastLane's Avatar
Quoted: 149 Post(s)
Liked 47 Times in 38 Posts
Originally Posted by irwin7638 View Post
I used Stan's sealant in tubes for a season and was pleased, but found that Flat Attack pre-filled tubes were a better alternative. Their sealant is gauranteed for 5 years so it doesn't need to be "refreshed" from time to time to remain liquid. The sealant is also supposed to be biodegradable which makes me feel all warm and fuzzy for using it. Despite many punctures, I haven't had a flat on the road in over three years. When a puncture occurs, the tire loses a little pressure, I stop and remove anything I find on the tire, add air or CO2, give the wheel a spin and ride on.
Marc
I've experienced about a dozen flats in the last 3 months, mostly from wire/road debris, although there is some kind of plant around here that produces long (~1") thorns that are hard enough to go through a Marathon+ WITH liners!
The guys at Utah Trikes swear by Flat Attack, and I had them add some to my velo when it was in. I'll give it a couple months, and if it seems to help a lot, I'm going to order a bottle for my other bike as well.
Notso_fastLane is offline
Old 09-20-19, 10:58 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 787 Post(s)
Liked 77 Times in 62 Posts
Originally Posted by Notso_fastLane View Post
The guys at Utah Trikes swear by Flat Attack, ...
I had mixed experience with their tubes.
The 2" tubes worked well - almost too well as I didn't know I had a nail in my tire until it worked its way to the rim side of the tube - put a hole in there - and the sealant won't help with that.
the ~25mm tubes didn't seem to help seal much at all
The last couple of tubes I bought were defective and blew out within a day of installation (oddly at the same spot).
Bottom line - if you are using the bottle to fill up some mountain bike tubes, it can work great. Just be ware if there is an unusual small loss in pressure day to day - check to see if there is something in your tire. They should hold air with very minimal pressure loss day to day. Enjoy!
chas58 is offline
Old 09-20-19, 11:06 AM
HardyWeinberg
GATC
Quoted: 460 Post(s)
Liked 13 Times in 13 Posts
Please explain...
I have had 2 wipeouts where I didn't see what happened but at the end the tubeless tire was off the rim; once it was a blowoff (onlookers heard it), the other time, no witnesses, don't know. Once for the front, once for the rear.
HardyWeinberg is offline
Old 09-20-19, 11:40 AM
RubeRad
Keepin it Wheel
RubeRad's Avatar
Quoted: 13 Post(s)
Liked 119 Times in 89 Posts
I think it's not about the width, it's about the pressure. And since wider tires can run lower pressures, they work better.
RubeRad is offline
Old 09-20-19, 02:38 PM
Notso_fastLane
Quoted: 149 Post(s)
Thanks for the heads up. I check my tires (at least) weekly when I top up the pressures.
I've started to carry a Gerber multi-tool with me, as there have now been two instances where there were objects in the tire that I could not pull out with my fingers, and I needed pliers.
Plainsman
Mountain Biking
11
09-19-18 03:45 PM
ggbo951a
General Cycling Discussion
51
10-09-17 09:03 AM
Bradleykd
Road Cycling
30
07-10-15 08:03 AM
waynesulak
Tandem Cycling
2
04-15-14 06:48 AM
etane
Bicycle Mechanics
3
06-22-11 11:48 AM
