Your opinions on the "run-up and drift back"
Old 07-07-19, 01:18 PM
  #51
Hermes
Version 3.0
Hermes's Avatar
Bikes: Too Many
Quoted: 606 Post(s)
Liked 127 Times in 94 Posts
Originally Posted by redlude97 View Post
I've never seen this in a group ride even race/rides. Doesn't even make sense logically to burn matches sprinting to the front last min just to be at the front at the start of the hill. What is more common at least around here is to simply try to time your pulls so you're near the front when it starts or it there's a downhill prior use momentum to get around towards the front at the base
I agree. The physiology just does not make sense. If one has the ability to charge ahead, why not just try to conserve on the way to the climb use the energy to hang in. Generally, one is always capable of doing more than one thinks. A lot of hanging on in any situation is mental.
Second, having a surge to the front drift back plan just sounds odd and self defeating. I like to think I can hang and let me be proven wrong.
Now, being in the front of a larger group on the start of a climb gives one options if the I can hang strategy degrades into a I am losing contact and I wonder if there are others behind me that are as well. One can then work with the group that did not make the selection. If I am the only one that does not make the selection then welcome to Offthebackistan.
The drift back strategy is weak sauce at best in any situation.
BTS, you need to find much better riders with whom to train. This is going nowhere.
Hermes is offline
Old 07-07-19, 01:22 PM
  #52
asgelle
Quoted: 428 Post(s)
Liked 31 Times in 21 Posts
Because the former depends on W/CdA and the latter on W/kg.
asgelle is offline
Likes For asgelle:
Old 07-07-19, 09:19 PM
  #53
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 1935 Post(s)
Liked 85 Times in 70 Posts
It also doesn't make sense because that's not what's happening - being told us by someone who has a bone to pick. I've frequently gone by the leaders with a 5-10 mph speed differential. I don't sprint to get it. I simply move to the left, get down in full aero and keep a moderate pressure on the descent. I hold gear and bike position until I start up the hill, still holding aero but now giving full climbing power and downshiftng every time the needle gets close to 90rpm. Yeah, probably does look like I'm sprinting. I move to the right and get ready for some riders to pass. My w/kg isn't that great, though I'm not fat either.
I've tried to explain to other riders how I do it, doesn't seem to help. It's getting the coefficient and the area down. The weird thing is that's how you're supposed to ride. Most riders are too lazy. When one pulls out of the line on a descent, one should move backward, not forward. Draft extends back maybe 30'. Sometime I do get to ride with folks who aren't lazy. Then I can suck wheel all the time.
Asgelle is more terse.
Results matter
Carbonfiberboy is offline
Likes For Carbonfiberboy:
Old 07-07-19, 10:53 PM
  #54
caloso
caloso's Avatar
Quoted: 1962 Post(s)
Liked 358 Times in 201 Posts
Meh. If you’re not putting others at risk, causing gaps, or otherwise being a jackass, I wouldn’t sweat it.
caloso is offline
Likes For caloso:
Old 07-07-19, 11:46 PM
  #55
Camilo
Quoted: 231 Post(s)
Liked 15 Times in 10 Posts
I often pass fellow group riders downhill because (1) I like to go as fast as possible downhill and they don't and (2), I work harder at going fast downhill (pushing over the top, body position, line, etc.) and have a fairly small frontal area because of my size.
I'm not a strong climber so a lot of them pass me when the terrain changes. I hold my position and take my turn at the front on the flats and rollers when I can - assuming I can pull. If I'm too weak, I'll either make a token gesture at pulling or just hang in.
Nobody I know gives a flying rat's ass about any of this stuff. We just enjoy riding with each other.
Camilo is offline
Likes For Camilo:
Old 07-09-19, 02:23 PM
  #56
teejaywhy
teejaywhy's Avatar
Bikes: 2019 Specialized Roubaix Expert; 2018 Breezer Thunder Expert
Quoted: 73 Post(s)
Liked 28 Times in 22 Posts
Has the person been yelled at?
lol
teejaywhy is offline
acboett
General Cycling Discussion
24
07-13-18 12:23 PM
mckeithen
Road Cycling
20
06-07-14 09:38 PM
dennisa
Road Cycling
9
07-27-10 09:50 AM
ilovetheewind
Road Cycling
3
04-12-10 05:48 AM
