Mavic open pro or Bontrager select whee
I just bought a Lemond Tourmalet 2005 with Bontrager Select wheels. this will replace my Steel 1993 Specialized Allen with Mavic OpenPros in good shape.Should I switch the Mavics before I sell The Allez.What are the advantages(performance or other)of the Mavic Pros over the selects?I'm heavy(220) lbs and I know theMavics are built for more weight but what apart from that?Thanks
Quoted: 344 Post(s)
Liked 20 Times
I am not a fan of Bontrager wheels mainly because I have found, based on limited experience, that they are harder to get tires to mount to. But otherwise I have had no problems with either rim. That said, more spokes are better and your open pro wheels are probably going to be a tad more serviceable than the bontrager.
Also, you dont say what hub you have mated to the open pros. Bontrager hubs are often DT Swiss design and are usually pretty good. But if you have something like a Shimano 105 or better hub with the Open Pros, I would go with those.
Open Pros were Mavic’s flag ship road rim for a long time. I ran them for many years paired with both Ultegra and 105 hubs. They have been overtaken by the wider rim trend so aren’t as prevalent as the used to be. But paired with 105 hubs make an excellent wheel. All things being equal...e.g. rims are straight and otherwise undamaged.. I would go with the open pro set over the selects as well (although if you plan to sell the wheels you don't use, you would probably get more money for the open pros).
FlashBazbo
Road Cycling
2
04-19-17 01:50 PM
lsberrios1
Road Cycling
0
03-18-16 11:58 AM
