Salsa Casseroll still needs work...
So if anyone is familiar with my previous post I apologize but my salsa casseroll still needs help... I am having an issue with my spokes I am assuming, only because they keep coming lose in my back wheel. Even AFTER being professionally trued twice. So my current verdict is I will just need a new wheel set and start from scratch? I bought the bike second hand and have no idea how old or worn some of the components are. I also need to replace the cantilever brakes (the spring pressure screws have pushed all the way through and seem to be obsolete. As well as a frayed brake wire that is all that needs to be done... so my question to the much better educated public is, what wheel set(if I should replace) is the best for the buck? Not trying to spend more then 200 after shipping and setting them up etc. Any advice is welcome and appreciated
Good used quick release rim brake wheels are all over craigslist, facebook, etc... as people switch to discs. I'd suggest checking looking around for a nice used pair first.
Also, it sounds like all you need is a rear wheel.
Now THAT is what I want to hear! I am using a wheel that was on a trek bike just to get through today so I can fix
Quoted: 5888 Post(s)
Liked 3,471 Times
You're looking for a 130 mm OLD rear wheel, right?
If you want a wheelset, these wheels from velomine are a good deal (but perhaps out of your price range) at $219: 36 hole velocity A23 rims, shimano 105 hubs
https://www.velomine.com/index.php?m...oducts_id=5177
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
Assuming it is one of the 130mm OLD models(not sure if any werent)- Ill 2nd the velomine suggestion.
https://www.velomine.com/index.php?m...3s1elq4mlibcn5 $219 and great components. They may need to be touched up after riding a few times due to stress relieving during use instead of during the build.
https://www.velomine.com/index.php?m...3s1elq4mlibcn5 $189. Again, may need to be touched up after riding a few times.
