Hard to steer?
#51
Bikes: Trek 3900
Used a degreaser I have, used a fine jet of water to help the old grease out. (sure I'll be ridiculed for that, but I've done it for a long time, even with my BMX bike and they never rusted/failed) and yes, I greased them before I put them back.
gave em a fast rinse in some weak rubbing alcohol to make sure it would dry up, and then they spent about 20 mins in the GA sun.
#52
Bikes: Hecklah
#53
Bikes: Trek 3900
very carefully, I have this thin runny grease crap.
Prob, not the best, but I was able to get it inside. (theres a small gap)
#55
Bikes: Trek 3900
Ive never had a bearing rust on me before.
My BMX bike used to go swimming.
(rode along an ATV trail in alaska that went into the lake)
#56
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,200 Times
Maybe chest or some of the dangly bits but not likely. The edge on a stem is pretty dull and, if installed properly, the sharp parts of the fork are buried pretty deep in the stem.
Stuart Black
Stuart Black
#57
Homey
Quoted: 2427 Post(s)
Liked 1,401 Times
Glad to hear you finally figured that out but that water in the bearings thing kinda scares me.
I don't understand how it got so bad if it was sealed though. Perhaps some of you who know more about it than I will educate me?
#58
Some of them aren't really sealed all that well, dirty water can still get in. More of a shield than a seal...
#60
Nitro
Bikes: Salsa
Old School Rad
Bikes: Blur LT
This thread has been fun.
Like a circus monkey on a stolen Harley......
#62
Type 1 Racer
Bikes: A dozen or so.
Generic Title
Bikes: 2008 Trek Fuel EX7, 2007 Trek 1600, 2007 Eastern Warthog
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Quoted: 29 Post(s)
Liked 6 Times
I was afraid to open this. Now I know why. It was almost too painful to skim; kudos to anyone who actually read it all. And to all of you who patiently gave sound advice only to be ignored, hats off to you all.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
#66
Moar cowbell
Quoted: 29 Post(s)
Liked 6 Times
^^ I ignored it at first because I thought, "someone will straighten him out quickly and he'll be on his way." Silly me.
#67
Generic Title
Te mortuo heres tibi sim?
Bikes: hardtail, squishy, fixed roadie, fixed crosser
actually pretty easy on most sealed bearings. use a thin pick or blade to pry up the seal -carefully, so as to not deform it - you'll be re-installing it. clean out the old gunk. instill new gunk. pop bearing seal back into place. wipe off the excess gunk that has been spooged out fromhaving the seal popped back in place. done.
#69
Fourth Degree Legend
Bikes: 2005 Kona Cinder Cone & 2010 Cannondale SuperSix
I am making some dope hamburgers.
#70
Old School Rad
Bikes: Blur LT
The funny thing is he started a thread about a new fork and headset then this one shows up.Now he's got his feelings all hurt becuse evryone made the obvious connection.
#71
Bikes: Hecklah
Heck, he said his fork was "too soft" and thought maybe he needed to add oil to make it firmer. Finally figured out what preload was and how to increase it....then asked "what is damping?"
Lord help him if he finds out that you can actually take springs out and replace them with stiffer/lighter ones to tune the ride height to ones liking.
#73
unofficial roadie
Bikes: 2004 Marin bobcat trail, 2006 trek fuel ex7, 2007 iron horse road bike
maybe he does have the wrong crown race for his headset like SVR stated in the other thread, it does look like it's too far apart.
it may be a "semi cartridge" headset where it's not sealed just bearings behind a sleeve.
#75
World's slowest cyclist.
Bikes: Cannondale CAAD5 and Cannondale Rush
WD40 would have been the right choice for getting the water out of that bearing. Follow that up with the grease (WD40 isn't a good lubricant) and I think you'd have avoided your rusty balls. Time will tell if your fix lasts. Best bet I think would have been an overnight soak in degreaser, followed by an overnight alcohol soak to get the degreaser out, then bake in an oven (assuming there's no parts in the bearing sensitive to the temperature) to get the alcohol out, then grease.
But if there was a way to disassemble the bearing for better access that's a better choice. Better still is to replace the bearings.
