Hard to steer?
Hard to steer?
Old 07-24-08, 12:41 PM
  #76
Cheeto
Bikes: Trek 3900
Well it worked last nights ride.
Rode pretty hard to, Tore the living crap out of the insides of my left shoulder, pretty painful today.
It's fixed for now, and hopefully for a while.
No, I wasnt dumb enough to leave the water in the bearings.
Yes I soaked in alcohol.
Yes I ran some Wd-40 into it to remove all the water.
the hot sun also helped get rid of water.
and for the record, the preload adjustment doesn't work very well. I get it nice a firm, and then.... CLICK, it drops to soft.
Cheeto is offline
Old 07-24-08, 01:17 PM
  #77
C Law
Too Much Crazy
Bikes: A bunch
Quoted: 114 Post(s)
thats too bad. And you are a young guy no?
That stuff shouldn't happen until you get much older
C Law is offline
Old 07-24-08, 01:42 PM
  #78
ed
ed's Avatar
Bikes: Hecklah
Ya know Cheeto...I'm glad you're steering okay now but I think your headset is installed improperly.
Under your lower cup...there's a larger space than normal. Someone from your other thread brought this up already. Are you sure you don't have the upper wedge thingy on the underside? It looks like there's something on top of your crown race between the race and bearing. There shouldn't be.
File Type: jpg
File Type: jpg
ed is offline
Old 07-24-08, 01:59 PM
  #79
rb07
rb07's Avatar
Bikes: 05 Specialized Rockhopper, 70s Motobécane Grand Touring
Originally Posted by pyroguy_3 View Post
Please buy a copy of "Zinn and the art of mountain bike mechanics". It will save you a lot of time in searching out answers on a forum, it's nice to have when you're actually at your bike so you can just flip to the pages on headsets, and it's only ~$25-30 USD. Mine has taught me a huge amount, from rebuilding a headset, a drivetrain, and the transmission, to building and truing a set of wheels. It also has a handy troubleshooting section that lists problems, and then what chapter to look in. Ohhh, and torque tables for commonly used parts, if you do that sort of thing that is. Seriously, that book is in the top of the list of best bike related items ever purchased.
+1
rb07 is offline
Old 07-24-08, 02:11 PM
  #80
Chris_F
World's slowest cyclist.
Bikes: Cannondale CAAD5 and Cannondale Rush
Obviously... you said as much. The problem with water isn't always the water. It's what water leaves behind after it dries. For a bearing like that I wouldn't use water at all, and if I was forced to use water I'd go out and buy a replacement to have on hand for the day when I need to replace it. If you used WD40 to get the water out you may be fine. You might not be as well, and only time will tell.
No biggie though, all this stuff is fixable or replaceable. Just ride it until it don't ride no more, fix it, and repeat. I think you've got the first part of that process down and are making progress on the second part. A word of advice (something I learned myself): never underestimate your own ignorance.
Chris_F is offline
Old 07-24-08, 02:14 PM
  #81
scrublover
Te mortuo heres tibi sim?
scrublover's Avatar
Bikes: hardtail, squishy, fixed roadie, fixed crosser
probably because it's an old fork. maybe very clapped out. maybe just needs a decent service.
scrublover is offline
Old 07-24-08, 07:25 PM
  #82
Cheeto
Bikes: Trek 3900
I think he may of put two crown races on. Im going to take it apart yet again and double check EVERYTHING and piece it together and make sure everything fits nicely.
It's steering again, but it did come loose yesterday, same with my left crank arm!
bikes falling apart around me. Going tomorrow for a new 1x8 crank.
I'm dreading the fork service thing, I don't really know what to do when it comes to forks, I've never had to take one apart.
Cheeto is offline
Old 07-24-08, 07:39 PM
  #83
troie
:\ ping of death
troie's Avatar
When you say that you cleaned the "sealed" bearing, you just cleaned the outside right? I think they are sealed for a reason.
troie is offline
Old 07-24-08, 08:06 PM
  #84
Cheeto
Bikes: Trek 3900
its not 100% sealed like the person said above. I can see the bearings through a very tiny gap. They're just in a casing, and then when you put the race on, it has a rubber seal that covers the very very small gap.
AHA!
I think there's already a crown on the fork, but it wont come off.
it's stuck!
does this look normal? I looked at other forks and they didnt have it, it seems to not want to come off
excuse the black smudge, my dog wanted in the picture, its his nose.
Just to please him, Here my Pooch.
Cheeto is offline
Old 07-24-08, 08:59 PM
  #85
Cheeto
Bikes: Trek 3900
OK AFTER A FEW MINUTES LOOKING AT MY OLD SUNTOUR, AND THEN MY MANITOU, the suntour has a notch just big enough for a screw driver, stick it in there and pry up the crown race pops up.
The manitou doesnt have one of these. So after about 15 minutes of carefully poking and proding with random thin tools and a few taps of a rubber mallot, and a chunk of skin missing off my finger the old race came of.
It was a little rusted on to, so I cleaned up all around the area, and slide the Cane creek crown race (looks exactly like the one pictured above! thanks for that, same color and everything) down onto the steer tube down to the crown. Assembled it all backtogether paying close attention to the bearings and stuff, and now it's all together correctly, its all fitting good, no wobble, no stiffness, no gap, its perfect!
IT'S FINALLY FIXED!!!!!!!
Guess I owe some of you some appologies, and some of you some thanks.
I should of read up a little more, and payed closer attention, at first I didn't know what the difference was between the two races, tonight, at like 10:45, it finally hit me. It has got to come off. SO thank you everyone for your help and critques. My headset is now properly installed.
Next thing on my list is the... fork =)
Cheeto is offline
Old 07-24-08, 09:03 PM
  #86
ed
ed's Avatar
Bikes: Hecklah
Awesome!!
You remind me of me back then, hahaha.
Don't expect too much outta your frok. They weren't very frokken fantastic yet at that point in time. They still got the job done though.
ed is offline
Old 07-24-08, 09:13 PM
  #87
Cheeto
Bikes: Trek 3900
11:00 at night, and I have to get up at 6:00am.... and Im working on a bike LOL.
The fork is still better then the Suntour, I just need the preload adjustment to stop slipping. I just don't want to take the think apart.
Im not even sure it's an 01 yet LOL.
but it's been in his garage for approx 4 years he said. so that makes it atleast an 04.
im just glad that's out of the way now.
tomorrow I'll get that crank ordered, and soon i should be ready for the race in august.
Cheeto is offline
Old 07-24-08, 09:18 PM
  #88
ed
ed's Avatar
Bikes: Hecklah
Which one?
ed is offline
Old 07-24-08, 09:21 PM
  #89
Cheeto
Bikes: Trek 3900
IDK what he had in mind, we'll discuss it and finalize it.
Basically what ever I want, he can give me, as far as square taper goes..
Cheeto is offline
Old 07-24-08, 09:22 PM
  #90
ed
ed's Avatar
Bikes: Hecklah
What who had in mind? Who's deciding your parts for you? Are they free or do you have to pay for them?
ed is offline
Old 07-24-08, 09:25 PM
  #91
Cheeto
Bikes: Trek 3900
paying for it.
65-100 bucks.
the GOOD mechanic at the LBS, he went to school for bikes lol. He's an amazing biker as well.
He's one guy we can all count on around here as far as bikes go.
we had one picked out, had bashguard and jump guard on it I think, removable/changable chainring, and the crankarms were ok.
Don't know what company, he was trying to run the shop, fix a bike, and answer phones the whole time I was there lol.
I wont be getting any more free stuff for a while, lol I've run out of very generous people=)
Cheeto is offline
Old 07-24-08, 10:53 PM
  #92
Siu Blue Wind
BACK2ME
Siu Blue Wind's Avatar
Quoted: 1659 Post(s)
Liked 93 Times in 70 Posts
YAY Cheeto!!
Originally Posted by making View Post
Please dont outsmart the censor. That is a very expensive censor and every time one of you guys outsmart it it makes someone at the home office feel bad. We dont wanna do that. So dont cleverly disguise bad words.
Siu Blue Wind is offline
Old 07-24-08, 11:08 PM
  #93
kenhill3
use your best eye
kenhill3's Avatar
Bikes: '75 Bertin, '93 Parkpre Team 925, '04 Kona King Kikapu, '05 Bianchi Vigorelli
Here's to mechanical success, Cheeto! Right on, man!
"I tell you, We are here on earth to fart around, and don't let anybody tell you any different." - Kurt Vonnegut jr.
kenhill3 is offline
Old 07-25-08, 03:43 PM
  #94
Cheeto
Bikes: Trek 3900
To add to the success, I got my crank, We decided to go the cheaper route, he gave me a Shimano 3 ring crankset for 40.00. I removed the granny gear, and I have to keep the Large chain ring on for a spacer for the bolts for now. Eventually I'll get a bash gaurd to replace it. I orderd this chain guide thing, LBS said he uses one and it works great.
Guess it goes where the FD used to go, and it keeps the chain down on the ring.
for 10.00 I'll give it a whirl.
Installed crank, and it works nicely.
But, My method of removing the old crankset was a bit out of the box lol. I don't have a crank puller or anything, so, I got my hammer out..... I'll take a picture of the old crank later lol.......
muhahahaha
Cheeto is offline
Old 07-25-08, 07:14 PM
  #95
Fable
I'd place the fork somewhere around 98-01. I would be very surprised if it was a 2004.
Fable is offline
Old 07-26-08, 01:24 AM
  #96
lanfarm
Gotta Catch em all!
lanfarm's Avatar
Bikes: 2008 Giant Rincon
Ahahaha, I hope im not the only one to get this. Or the only one imature enough to post this...
lanfarm is offline
Old 07-26-08, 01:34 AM
  #97
kenhill3
use your best eye
kenhill3's Avatar
Immature enough to need help with your grammar and spelling. (Sorry, I couldn't resist).
kenhill3 is offline
Old 07-26-08, 03:15 PM
  #98
lanfarm
Gotta Catch em all!
lanfarm's Avatar
My bad
i spellz how i wanna spellz
lanfarm is offline
Old 07-26-08, 04:11 PM
  #99
troie
:\ ping of death
troie's Avatar
What?
troie is offline
Old 07-26-08, 05:25 PM
  #100
Cheeto
Bikes: Trek 3900
the bolts that hold the chainring on, they are a tad to long for just one crank. I dont have any washers small enough, so the big chain ring stays on to take up the slack on the bolts.
Cheeto is offline
