Please teach me STEEL
Old 12-28-08, 03:31 PM
lbear
just going for a ride...
lbear's Avatar
Bikes: LeMond Sarthe, OCR A1, OCR 2, Cypress DX
I am beginning to catch the C&V fever. I am in the early stages at this point. I am just beginning to gather a knowledge base. Are there any books or web sites beside that you can recommend. Or help you can give me. Particularly about the different steel tubing types. And how they differ. ie CroMO, Champion 1 & 2 etc.
lbear is offline
Old 12-28-08, 03:35 PM
Old Fat Guy
http://www.desperadocycles.com/The_L...per_Tubing.htm
Old Fat Guy is offline
Old 12-28-08, 03:43 PM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 694 Post(s)
Liked 87 Times in 70 Posts
Also need to consider many steel bikes use a variety of grades throughout the frame. So read the label carefully: is it limited to main tubes, what about stays and forks? And if it is not labeled, assume it is high ten steel (bottom end).
wrk101 is offline
Old 12-28-08, 04:55 PM
bbattle
bbattle's Avatar
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Trevisio, 1991 Colnago Master, '06 Bianchi San Jose, 1987 Moulton Fuso, 1990 Gardin Shred, '82 John Howard(Dave Tesch)
Quoted: 48 Post(s)
Columbia SL and Reynolds 531 are the two biggies. 531 is a manganese alloy, SL a chromoly. 531 has been replaced by air hardening steels that can be TIG welded. SL has been replaced by Nivachrom (niobium alloys) and Columbus' newest, xCr stainless. LINK1, LINK2, LINK3, LINK4, LINK5
True Temper makes some good steel alloys; notably Oxplat and S3. Tange has some good chromoly tubing; lower the number, the better the tube. Dedaccai(sp?), Gilco, Excel, Vitus, Ishiwata and a few other small names shouldn't be dismissed.
LINK6
LINK7
LINK8
LINK9
LINK10
Every once in a while, a frame with the wrong tubing decals is spotted on eBay. Sometimes it is noted by the seller, sometimes not. Be careful of possible counterfeits. When in doubt, ask around or just stay away.
And sometimes, a frame is up for sale missing the decals and the seller notes that or doesn't; meaning he doesn't know what he's got. Or it's missing the decals but the seller claims it is something which it is not. Have to be careful.
bbattle is offline
Old 12-28-08, 05:12 PM
caterham
a nicely biased set of short articles from the torelli website- emphasis on Columbus steel tubing & Torelli/Mondonico framesets
http://www.torelli.com/tech/material.shtml
http://www.torelli.com/tech/matdesn.html
http://www.torelli.com/tech/747.html
caterham is offline
Old 12-28-08, 05:17 PM
John E
feros ferio
John E's Avatar
Quoted: 722 Post(s)
Liked 47 Times in 43 Posts
If you just want a bike which rides well, a mixed tubeset frame with a high quality double-butted moly steel main triangle can be a great bargain. You will suffer only a very small weight penalty for a frame which otherwise performs every bit as well as one of its much pricier and more collectible thoroughbred stablemates. If you can't afford a PX-10, consider a PR-10 or PKN-10. Instead of a top-of-the-line Bianchi, consider a Campione d'Italia.
John E is offline
Old 12-29-08, 12:43 AM
soonerbills
soonerbills
soonerbills's Avatar
Bikes: 25 at last count. One day I'll make a list
I love the stuff on this site.
patentpending.blogs.com
Like this
"Steel Tubing for bicycle frames
Bicycle construction was made considerably lighter and stronger when in 1885 the German brothers Max and Reinhard Mannesmann patented a process for making seamless steel tubing. A solid cylindrical blank is fed into contact with forming rollers which grip and pull the blank over a mandrel which bores out the inside of the blank. The diameter of the tubing becomes larger than diameter of the original blank. This 1888 patent is for a version of their process in which the work of forcing the blank over the mandrel is accomplished by a feed device, so the rollers have to form the outer shape but do not grip and pull the blank. The brothers founded the Mannesmann company, which grew into a huge industrial giant which is dominant in its field today, and valued at around $92 billion."
Original text from:
http://patentpending.blogs.com/paten...tubing_bi.html
soonerbills is offline
Old 12-29-08, 11:57 AM
soderbiker
Waiting for Summer !
soderbiker's Avatar
Bikes: E.Merckx Corsa extra PK Banken,E.Merckx Corsa extra TT,E.Merckx Strada,De Visini,Olmo Gentleman,Peugeot PA-10,E.Merckx Corsa extra Team Issue,Nishiki Olympic Royale,Nishiki Olympic
here is WHY STEEL
here is COLUMBUS TUBING PDF'S
Cheers
T
soderbiker is offline
Old 12-29-08, 12:09 PM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 694 Post(s)
Soderbiker: Thanks for the good link on lugged steel frames. Now I have another reason to like them lugged!
wrk101 is offline
Old 12-29-08, 12:21 PM
lbear
lbear's Avatar
This is what I like about BF everyones always ready to teach. Thanks guys!
lbear is offline
