Tout Terrain / Supernova The Plug II Plus Problems (need electrical help)
Old 04-13-12, 10:16 PM
iconicflux
Fredly
Bikes: Surly Long Haul Trucker w/ SRAM Rival, & 36H 38's, Late 70's Santana Tandem w/ Double Diamond frame
I emailed Supernova about this about a week ago and haven't gotten any response so I thought I'd ask what people here think....
I've been researching why Tout Terrain / Supernova's The Plug II Plus has problems with maintaining charging of my Droid RAZR. It seems that the RAZR is finicky about the power it sees.
I checked tonight and found that the voltage put out at the USB port is 4.95v (which I think meets the USB standard) but I don't have any idea what sort of amperage the plug is supplying at this point.
Can anyone here think of a good way to use a multimeter to check the amperage of a usb cable without hacking a good cable apart?
Thanks,
Kevin
iconicflux is offline
Old 04-13-12, 11:03 PM
unterhausen
Randomhead
Liked 639 Times in 479 Posts
can't help because my method is to hack the cable.
4.95v is fine
unterhausen is offline
Old 04-14-12, 07:40 AM
iconicflux
Fredly
unterhausen - Are you thinking that I open the insulation and use the 5v dc wire to measure across?
I think I have an extension cable somewhere that I may be able to use.
Old 04-14-12, 08:36 AM
unterhausen
Randomhead
that is what I have done in the past, did some low-power computer work and needed to measure power consumption
Old 04-14-12, 06:57 PM
iconicflux
Fredly
In the mean time, my use of a buffer battery totally works. The dyno charges the battery and the battery charges the phone. The charging is pretty stable at 9.5mph and at 12mph it's damn solid.
Glad I had the idea of using a verizon P893 for $30 instead of a $100+ e-werks cache battery.
maxprofwell
Electric Bikes
3
07-21-17 08:28 PM
gauvins
4
06-26-16 03:55 PM
memebag
Bicycle Mechanics
5
09-28-15 09:32 AM
cs1
Classic & Vintage
17
06-24-14 09:45 PM
