Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 10-14-18, 08:15 PM
  #5251
Baby Puke
Bikes: Marin Stelvio, Pogliaghi SL, Panasonic NJS, Dolan DF4, Intense Pro24 BMX
Quoted: 343 Post(s)
Liked 57 Times in 38 Posts
Zipp 900 users: My axle has become worn so that there is play between the axle and bearing inner races. This is giving an unacceptable amount to radial and lateral runout at the rim. Bearings have just been replaced, so it's not them. I micced the axle under the bearings and it's 14.9mm, bearing inner race being 15mm. Thing is, it's 14.9mm all along the section that sits under and between the bearings, which is a little perplexing because the section between could not have become worn (no contact).
Two questions:
1. Could someone measure their axle for me (where the bearings sit)?
2. Has this happened to anyone else? What was your solution?
Thanks in advance!
Baby Puke is offline
Old 10-14-18, 09:06 PM
  #5252
Bang0Bang00
41 calories/30 min typing
Bang0Bang00's Avatar
Quoted: 32 Post(s)
Re track straps
Has anyone tried the Ynot brand straps on the track?
They're pretty beefy compared to most pictured. I just love them for street and am curious if they'd transfer... presumably with the zap strap attachment method.
https://youtu.be/rE9GungwI3o
Bang0Bang00 is offline
Old 10-21-18, 12:40 PM
  #5253
Kaben
Kaben's Avatar
Quoted: 62 Post(s)
Hi all, I have a random question regarding flying 200m gearing on different track lengths / banking angles.
Is there any agreed wisdom on changing your gearing for different tracks types?
For example locally I have a 2 tracks, one is a 450m track with shallow banking and the flying 200m incorporates corners 3 &4.
The other is an indoor 250m Velodrome with very steep banking and the flying 200 starts mid corner between 1/2, continues through corners 3/4 and finishes on the straight.
Do the different tracks require a different gearing or would you tackle them with the same gear?
Sorry if this seems elementary - was just wondering if the additional corners made a difference.
Kaben is offline
Old 10-21-18, 01:03 PM
  #5254
carleton
Elitist
carleton's Avatar
Quoted: 1348 Post(s)
Liked 55 Times in 45 Posts
Generally speaking, the way you'd approach the flying 200 on the two track mentioned would be significantly different.
One major point is that on a shallow track, there is very little climbing during the windup. On the steep track, there is a significant amount of climbing during the windup.
The second is the dive. On the former track, the dive is from a shallow height. On the latter track, from a much higher point.
Experience on both will guide you more than our words can. You have to go out and practice it...and use various gears doing so. "Big gear" and "Small gear" are all relative terms. Your goal right now is to find out what that "Normal gear" is for you and the track. From there, you can go bigger or smaller.
carleton is offline
Old 10-22-18, 05:40 AM
  #5255
Kaben
Kaben's Avatar
Quoted: 62 Post(s)
Hi Carlton, thanks for that. If just getting out and testing is the answer, thatís cool. I just wanted to check that there wasnít some agreed wisdom on gearing adjustment from a control gearing for each track type so I didnít waste time going the wrong way with the tweaks. My inclination would be to go slightly easier since there is more climbing as you say and more time spent in corners. Maybe with so little experience it doesnít really matter as line choice will be more important.
I have a sprint training session coming up for the 250m track the weekend after next and then my first sprint competition is a few days after that. The training session is 2 hours but realistically I assume I will only have a handful of 200m attempts taking rest times into account. Hopefully I can work something out!
Kaben is offline
Old 10-22-18, 06:01 AM
  #5256
Baby Puke
Quoted: 343 Post(s)
My three usual tracks area 400, a 333 and a 250. I usually ride pretty much the same gear on all of them, maybe a tooth up in front on the 250. I find my top speeds are a bit higher on the 250, but the times are pretty close between all three tracks.
Old 10-22-18, 07:36 AM
  #5257
TDinBristol
Quoted: 26 Post(s)
Just a quick observation/question after watching some of the World Cup over the weekend.
In both the Women's and Men's team sprint, teams failed because Rider 1 skidded the rear tire coming out of the starting gate and couldn't recover (see Day 1 at about the 40-minute mark on the UCI's video post). It seemed the reason was simple - the back tire lost traction. But why? Is it that these riders are leaning too far forward on the front tire, trying to get more power, or is it at the starting gate (i.e., trying to go a fraction of a second before the gate releases)? Or is it the wooden track, maybe an less-familiar surface than one's home track? It seems this is happening a lot more, and it's got to be disappointing to train that hard for that long and lose because the tire slips.
TDinBristol is offline
Old 10-22-18, 08:13 AM
  #5258
Kaben
Kaben's Avatar
Quoted: 62 Post(s)
thats really interesting - I will focus more on technique between the tracks rather than worrying about gearing so much then.
i honestly thought there would be bigger gear variance between the track styles but this at least means thereís one less variable to worry about come race day.
Kaben is offline
Old 10-22-18, 08:32 AM
  #5259
carleton
Elitist
carleton's Avatar
i honestly thought there would be bigger gear variance between the track styles but this at least means there’s one less variable to worry about come race day.
Maybe consider doing Flying 100s with a full windup and note your 100m split time and max speed. Doing full Flying 200s can be taxing and that last 100m the most taxing. You can learn what you need to know about your windup and gearing using the first 100m.
To estimate your Flying 200m time, double the 100m split time and add 0.1”. That should get you close and save your legs for more tests.
EDIT:
I'm not sure how much experience you have on the tracks that you intend to race on. But, I think your windup strategies (e.g. when to accelerate, when to relax, when to jump out of the saddle, where to start the dive, etc...) will have more of an effect on your time than a few gear inches up or down. For example, at DLV, adjusting your "jump" point several meters forwards or back will greatly affect your time. That jump point also depends on what gear you have on. It's all sort of mingled together.
carleton is offline
Old 10-22-18, 10:23 AM
  #5260
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 324 Post(s)
Liked 20 Times in 17 Posts
The only real applicable instance of "drastically" altering your gearing, is for really short tracks. A 250 isn't short enough to affect gearing. It's The really tight turns that make it harder for news and average weekend warriors to carry speed through the banks.
I've ridden 200m tracks that were both round and cigar shaped, these being Rochester Hills and the old Bromont Velodromes.
The old Bromont Velodrome was a 166m track that was already slightly oblong because it was constructed as a temporary velodrome that went into a hockey arena. It then got each straight lengthened by 17m to make for a 200m track when it found its permanent home in Bromont. Riding this track was not for the faint of heart (54*banks) and was really like shooting into the corkscrew of a rollercoaster after coming in on that "long-ish" straight. As a 16yo I was pulling roughly 2.5G in the banks and the amount of compression really made it hard to pedal compared to other tracks. Rochester Hills was the opposite, and rode much like a 250, as the track was rounder with shorter straights and gentler banks, making it super easy to carry your speed through the turns.
As an aside, besides gearing, the tactics for racing on these two tracks (despite being the same length) were quite different. A shallower banking puts a passing rider further to the outside than a steeper banking does, as a stepper banking "stacks" the riders more. A shallower track makes it much more important to make the most of a passing attempt on the straight. A steeper track with long straights offers quite an advantage for the passing rider as theet is less distance penalty, yet you really shoot out and down the track as you come out of the turn. The right and long tracks make for more exciting racing to watch in my opinion.
taras0000 is offline
Old 10-23-18, 03:10 AM
  #5261
ruudlaff
Quoted: 84 Post(s)
Liked 9 Times in 8 Posts
I have a similar issue to this and can't seem to find help anywhere. I start skipping my back wheel around revs 3-7, it settles down into turn 1 of the 250m track then does it again as I exit turn 2 into the straight while still accelerating out of the saddle. It doesn't seem to matter what wheels I'm using. I'm guessing the reason it settles down in the turn is the extra forces applying more grip...but can't find a way to fix it.
ruudlaff is offline
Old 10-23-18, 04:45 AM
  #5262
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 324 Post(s)
If you keep your butt over the seat yoully see this go away. Watch videos of kilo starts. Everyone is straight arming and keeping their butts back over the saddle.
Old 10-23-18, 08:30 AM
  #5263
ruudlaff
Quoted: 84 Post(s)
Originally Posted by taras0000 View Post
If you keep your assistance over the seat yoully see this go away. Watch videos of kilo starts. Everyone is straight arming and keeping their butts back over the saddle.
Willing to give anything a try
ruudlaff is offline
Old 10-23-18, 10:05 AM
  #5264
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 324 Post(s)
Its not to say that you can't move forward to get more leverage over the pedals, but you have to keep your hips/center of gravity behind the front wheel. If you feel the seat brush the back of your thighs asayou pedal, then your in a good spot to start from.
Think "monkey humping a tennis ball" as Ryan Bailey once put it, with the tennis ball being the back of your stem.
Old 10-24-18, 07:04 PM
  #5265
Baby Puke
Quoted: 343 Post(s)
Anybody know what type of bearings are in a Mavic iO? I found this info before, but now I can't seem to dig it up, all I find is the magic bearing kit online. Thanks
Old 10-24-18, 08:11 PM
  #5266
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 324 Post(s)
Originally Posted by baby puke View Post
anybody know what type of bearings are in a mavic io? I found this info before, but now i can't seem to dig it up, all i find is the magic bearing kit online. Thanks
6001. You can double check it if you have the wheel available. Mavic part #M40318 . 12mm ID, 28mm OD, 8mm deep = 6001 bearing.
Old 10-24-18, 09:42 PM
  #5267
Baby Puke
Quoted: 343 Post(s)
Thanks Taras!
Old 10-24-18, 10:23 PM
  #5268
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 324 Post(s)
No prob! Any 6001 bearing will fit, but you will want seals/shields too. A straight 6001 bearing will have open races. You'll need the suffix designation as well. "RS" means rubber seal on one side. "2RS" is robber seal on both sides. "Z" designates a metal shield or "seal". "ZZ" or "2Z" is shielded on both sides.
Rubber provides a better seal, but metal shields offer way lower rolling resistance. I'd opt for 6001 ZZ/6001 2Z. They are the same bearing
You could go for 6001Z (single shield/one side only) for even lower resistance, facing the open sides inwards, but you would have to service your bearings frequently, and that's not so bueno for cartridge bearings.
Old 10-25-18, 04:54 AM
  #5269
Morelock
Morelock's Avatar
Quoted: 251 Post(s)
Liked 29 Times in 21 Posts
^ If it's a primarily indoor (or race only outdoor so long as it's a track and not road or exposed to the elements) you can get by with no seals fairly safely. Just check every once in a while.
I did that on my road TT wheels for years running low fill grease. (although I did some extra precautions if the weather sucked)
It doesn't save you much admittedly
Morelock is offline
Old 10-27-18, 08:58 PM
  #5270
Baby Puke
Quoted: 343 Post(s)
Hey Taras, just FYI (and to other iO owners), it looks like the bearings are actually 61901, 24x12x6mm. The one's in this wheel are NMB r2412zz (though only one metal shield is fitted) which I cross referenced to the SKF number.
Also, for Mavic newbies (like me...) the axle is a slight interference fit, and needs to be lightly tapped out (screwdriver handle works). But be careful, the axle is aluminum and has EXTREMELY fine threads that look super easy to damage! So take care when removing/installing.
Old 10-27-18, 11:31 PM
  #5271
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 324 Post(s)
You're right. I goofed on the part number. It's supposed to be M40131, not M40138.
Old 10-28-18, 05:41 AM
  #5272
Kaben
Kaben's Avatar
Quoted: 62 Post(s)
Do any of you know whether you can reuse pins To relink a K710SL chain?
i have accidentally split the chain too short ( maths cock up trying to do it in a rush and not double checking).
They are almost £30 per chain here in the UK so Iím keen to save it if I can.
KMC website Doesnít list any spares other than missing links.
im guessing the answer is no but thought I would ask the community anyway just incase! *fingers crossed*
Kaben is offline
Old 10-28-18, 08:42 AM
  #5273
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 324 Post(s)
When you punched out the bearings, they should have the size series engraved on the shield, or the outer race.
Edit: Just saying, those iO bearings are a REALLY obscure size. Although not unobtainable, they definitely are a special order bearing. Mavic really makes it a hassle to order a $10 part just because it's an iO.
Little trick: When installing new bearings, face these markings outwards under any dustcaps. This way you don't have to remove the actual bearing to find out what your replacement is should you need one.
Old 10-28-18, 11:29 AM
  #5274
topflightpro
topflightpro's Avatar
Quoted: 1609 Post(s)
Liked 344 Times in 235 Posts
I've done it, and been doing it. It hasn't been a problem so far.
It's not a great idea to do it too often, but once or twice isn't really a problem. (Replacement pins can be purchased for $5-$6.)
topflightpro is offline
Old 10-28-18, 11:34 AM
  #5275
taras0000
Lapped 3x
taras0000's Avatar
Quoted: 324 Post(s)
Just throwing this one out there after some more investigating, the Comete Bearings are part #M40129 and are a 61902 bearing (15mmID x 28mmOD x 7mm width).
https://www.pelotony.com/cs/18-mavic...40129-mnoz-uni
