Giant Escape 1 Disc
Giant Escape 1 Disc
I just ordered a 2018 Giant Escape 1 Disc from local bike shop; the owner tells me it should be here mid June. I was considering several different bikes, but my experience at this local shop is what solidified the deal for me over other brands.
Now I'm curious: Does anyone have any experience with the Escape that you'd care to share?
Bikes: 2015 Giant Escape 2,
Quoted: 52 Post(s)
Wasn't aware the 2018 Escapes were available to order. Congrats to you my friend. My first bike was a Giant Escape 2 a few years back. GreAt bike. You will need to post pictures when you take delivery.
I was planning to buy the 2017, but my LBS was out of stock for my size. When the owner called the Giant warehouse, they informed him that 2018 models would be available mid June. Thus, I ordered one. Will definitely post pics when I get it.
Bikes: Specialized Fatboy (I call her Big Orange), FELT Carbon F FRD Custom Road Bike, Salsa Vaya, Giant Escape
Quoted: 34 Post(s)
+1 same experience. Giant Escapes are a near perfect first bike for street, road and bike trails. Mine got taken out in a car vs. bike accident or it would still be going strong..
The bike has performed very well. In terms of wear and tear, I wore out the rear tire in about 3,000 miles and replaced both tires with Specialized Crossroads Armadillos. The tires are a bit wider and heavier, but they last a lot longer and have good flat protection.
The other upgrades I have made was to the pedals and grips. I put on Shimano MX80 flat pedals and Ergon grips. I also had to replace the saddle after about a year. It was cracking. I replaced it with WTB Speed Progel. It was what the LBS had. It has been a good replacement.
The last thing I would say is when you have to replace the chain, put on a good one. I put on the Shimano XT/Ultega CN-GH 93 chain and it has lasted for over 7,000 miles so far.
Bikes: Giant ToughRoad Giant talon
Quoted: 705 Post(s)
They are at that. I don't own one, I own the two Giant designs either side of it and both of those are great. I love hybrids, they really do it all.
Thanks for the replies and tips everyone. JSK, the LBS owner recommended upgrading the pedals right away, so I plan to do that, add some lights, and maybe put a rack on the back.
Any other recommended "must haves" before leaving the shop?
Quoted: 34 Post(s)
Are pedals are something that would add value right away? I rode the stock platforms for a year then went to clips once I as comfortable riding and wanted more speed. A better investment might be bar ends which allow you to change hand position and, of course, a solid lock.
Quoted: 705 Post(s)
No, but I'll give you a recommendation "before" leaving the shop, and that is don't buy too much before you look online. For $15 you can get an amazingly bright LiPo headlight and battery off ebay, you can save a fortune on pedals, on computers, on almost any bike component you can to think of.
bikeexchange.com is worth looking for specials on bikes in your local area and any number of online outlets like Chain Reaction Cycles are good for parts. I buy a lot through ebay, lots of stuff in fact.
While I wait for my Escape to arrive, I've been riding my wife's Giant Cypress around town (163 miles in the last two weeks ). I'm a former runner who grew tired of soreness after suffering a knee injury. It was only two weeks ago that I filled up my wife's tires and took off. Been hooked since.
This leads me to a question: I realized today that a large part of my joy on the bike comes from hopping onto greenways, sidewalks, dirt paths, roads, etc. Will the Escape be good for this type of riding? Or is it more street-centric?
Bikes: I'm a Flatbar Guy
Quoted: 356 Post(s)
Quoted: 34 Post(s)
I had an Escape that was recently clobbered in an accident, but before that it was flawless on limestone trails and streets. And all in our very tough Minnesota climate. Now that I have a road bike though, thinking of replacing it with the Giant Toughroad which will handle the trails better but may sacrifice some speed on pavement.
Bikes: 2022 Specialized Kenevo SL exp2017 Specialized Expert carbon X1 2016 Specialized Trek 8.6 DS, Previously owned 2016 Specialized Stumpjumper comp carbo Trek 4500, 2019 Canyon Urban 5.0, Diamondback, Ross Apollo 5speed, Huffy? Research Dynamics(stolen)
Quoted: 49 Post(s)
I would recommend a bell, maybe a lock but I would hold off anything else until you put some miles on it. see if the seat and grips are ok, or maybe need to be changed out. see what aches after 2-3 hrs and then decide if it can be adjusted or changed.
Bikes: More bikes than riders
Quoted: 1438 Post(s)
Liked 749 Times
With relatively thin 32mm tires, the Escape is certainly more optimized for paved surfaces. Your wife's Cypress probably has 38mm tires, which are far more forgiving off the pavement. More volume means you can run less air pressure and absorb more irregularities off road. You may be able to fit larger tires on the Escape, I don't know. I personally like to run as large of a tire as I can, and inflate it appropriately. I'm not a time trialist, and my average speed is not important to me. I bike for exercise and for the enjoyment of it, and set my bikes up accordingly. I have 42mm tires on my Trek 750, and currently have 35mm tires on my Trek Verve, though the Verve will get the same 42s that the 750 has next time I buy tires for it. I generally run 30 psi in the front and 50 psi in the rear on both bikes.
Liked 749 Times
I do want to caveat my post (I don't think I made it clear) that it's my personal opinion only. I like as much tire volume as I can reasonably get, but I don't want my post to read like I'm saying that 32mm tires cannot be used offroad. Some professional off-road series (like some cyclocross I think) is actually limited to 32mm as the largest tire if I'm not mistaken (and many folks run narrower). You certainly CAN take a bike with narrower tires off-road, but you do have to air them up more than you would a larger tire because there's not as much volume, and you don't want to pinch-flat them on a root or other obstacle. The shorter your tire sidewall, the less it can compress before you actually hit the rim, and that's what brings the potential of a pinch-flat. So you have to keep them inflated more to prevent that, and the trade-off is ride quality.
Like everything else, there's no free lunch, and everyone has their personal preference and experience. I just didn't want my post to come off like "this is the only way" because it's certainly not -- it's just what I prefer.
Cheers!
Cheers!
I can confirm that you can put larger width tires on the Escape. I have 700x38 tires on mine.
Quoted: 14 Post(s)
Helmet if you don't have one. You only have one goard on your shoulders😜 Also have a tube, tire levers, and some type of inflation otherwise one day you will (not may) do the walk of shame🤣
Regarding the specs and prices, are there any differences between the 2017 and the 2018 you ordered?
I'm looking at buying an Escape Disc 2017, for mostly the same usage as yours (former amateur of running, looking to ride it on road but also on gravel and dirt trails. However, different colors/specs/price might put me in the market for a 2018 one.
Whib, what colors were available for the 2018 Escape Disc? I see the 2017 comes in black with a few touches of lime on it.
Thanks Whib, didn't realize the 2018 line was already online in the States - it's not online yet on the French website.
Did you receive your bike yet?
Yep, totally agree, these were the first items i bought when i got my bike, also throw in a water bottle.
Bikes: Giant Escape 1
Quoted: 136 Post(s)
I got an Escape 1 and love it. Here are two things I would recommend that might make your experience better.
1. Get a mirror. If you plan on riding in the road or on the streets, then a mirror is a MUST. Myracle Mirror makes one that you can add to the end of your bar. It will make you a much more confident (and safer) rider.
2. Ask the dealer if he is willing to swap the stock tires for 28m tires. I think you'll notice a difference in performance on pavement.
Good luck.
Good luck.
