Please help! Buying advice
Two days ago everything I new about bikes was what I saw at the big box stores, therefore, nothing!
After about 4-6 hours researching entry to mid level options I have decided that the best type of bike for what I want to do and my budget (under $500 dlls) is the Hybrid models. So far I have narrowed it to two options: the Specialized Sirrus V-brake (base model) recommended by my LBS and the Diamondback Trace dual sport based on online reviews.
I understand the difference from one brand to the other. Comparing both bikes, I can see value in both and I see a slight edge of the Trace dual sport because of its capability to ride on light trails with its added suspension; but because it is a brand I can find in Walmart, it makes me hesitant to spend $400+ on it.
Will I be able to ride the Sirrus on light gravel trails? Does any body has experience with the Trace dual sport model?
Your advice will be greatly appreciated!
Andres.
Andres.
Bikes: 2013 Trek 4.7 Flatbar Madone, 2018 Giant Roam 2
Quoted: 103 Post(s)
Andres.
Andres.
Yes you can ride a Sirrus on gravel trails. You can technically ride a road bike with 23mm width tires, it will just be bumpy. Without checking, I think the Sirrus comes with 700x35 and they will be fine on gravel.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
The Giant Roam is nice, and so is the Specialized Crosstrail. Since you're already at the Specialized dealer, checkout a Crosstrail -- it (like the Giant Roam) are in the "dual sport" category, and Specialized makes a Crosstrail version with mechanical disc brakes for 500 bucks (up from the $430 Sirrus with rim brakes). The Sirrus comes with 32mm tires, and you'll want to keep them aired up high when on gravel/off road, especially if you're a heavier rider. More tire volume lets you run with lower pressures and still keep a similar rolling resistance and impact protection level as narrower tires. A 35mm tire would be better for gravel, and a 38mm tire (on the Crosstrail) would be even better.
Be sure to ride both types of bikes, though. I recently bought a Giant Roam, and it and the Escape rode COMPLETELY differently. Be sure that you're comfortable on the bike that you buy, no matter the brand.
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
Andres.
Andres.
If you can, try to ride both bikes, and see which one loves you back. Good luck, and ride it like you stole it!
Thank you very much for all your help and advice. I now have more good homework to do based on the recommended models. Hopefully I can decide on a bike this week and post the results...
Bikes: 2015 Specialized Sirrus Base, 2018 Jamis Renegade Expat
Quoted: 23 Post(s)
I have a sirrus base with vbrakes that I use for commuting, city riding, and bike/gravel paths. I love it. I owned a crosstrail disc for 2 years prior and it was an just an ok bike imo. I know many love it and I can see why they do. Just not for me. It was much heavier than the sirrus due to the shock (which didn't do much imo). I ride much faster on the sirrus, even on bumpier roads and gravel which surprised me. The crosstrail does have room for wider tires. That said, I know my sirrus can handle very similar terrain as the crosstrail and is quicker and lighter. Test ride both of you can.
A cheap suspension fork is a turnoff, so I'd get the Specialized all day every day, but I'm biased.
The 32mm tires on the base Sirrus are a true 32mm and are very fat (I have 30s on my Sirrus which only look 2/3 as wide as the 32s, not sure what's up with that but my tires definitely don't measure 30mm wide whereas the 32s most likely really do...) and should handle gravel no problem.
What color/year Sirrus you looking at? Ws just at my LBS this morning and they had base Sirruses from like the last three years so there were lots of colors to pick from.
eazerad
Hybrid Bicycles
7
07-02-15 06:50 AM
2EXTREME
Hybrid Bicycles
3
06-25-14 09:53 PM
