Riding in the Rain: Excess Wear on the Bike?
I bought a 'winter/beater' bike a couple of years ago, expecting it to take a lot of abuse on rainy days with not so meticulous maintenance. Since then I have ridden many times in light to moderate rain.
I have noticed zero problems due to rain riding. No chain rust, no excessive pad or rim wear. There is some rust on the stem bolts but otherwise I don't notice any more wear than on bikes that don't see the rain.
This bike gets regular maintenance but I'm not studious or fastidious about it. It seems like I could ride nicer bikes in the rain and expect even better results? I feel like riding in the rain doesn't make much difference in the wear and replacement of bicycle components.
I wouldn't leave my bike out in a torrential downpour but an hour or two of riding in light to moderate rain seems to be absolutely no problem.
Bikes: ...a few.
Quoted: 2010 Post(s)
Liked 408 Times
Having wet brakes will wear out the brakes shoes and the braking track upon your wheels faster. Not a problem with disc brakes though.
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
I destroyed the hubs on my rain bike. After several years of use and abuse, they were completely rusted and pitted inside, though the wheels were crap to begin with. Also I get some minor rusting on other parts/bolts, but not much else. I just hose it off when I get back to get the gunk off, dry off the chain and re-lube it. I also take the bike inside to dry faster. I have noticed if I leave it in the garage, and it takes days to dry, that seems to be worse than if I bring it into the warm house and it dries out the same day.
Your biggest issues will be things you can't see: water getting past seals, getting into cable housings, getting into frame, etc. And of course washing the oil off the chain, grit in the chain is hard on all drive chain parts.
Obviously, this can be more of a problem on some bikes than others, depending on quality of seals, etc.
Quoted: 2952 Post(s)
Liked 3,106 Times
Chains, cassettes, brake pads all wear faster. And like cthenn, I destroyed a hub because water infiltrated the seals.
Quoted: 1218 Post(s)
Liked 298 Times
some BB will be better than others for rain, as will head sets, and also wheel hubs.
use a fender to keep the spray off the seatpost. Or use an old tube as a seal to help keep water from running down into seattube.
imo the biggest wear from rain would be winter rides in states that get snow. Roads get gritting and water washes that grit up and through your driveline. fenders helps.
Quoted: 1216 Post(s)
Liked 183 Times
Riding without fenders will significantly reduce the life of your bottom bracket as well. One year I did maybe 20-30 hours of heavy rain which means front wheel just spraying directly into the bb area, and when I finally checked my bb it was completely devoid of grease. Rusted, notched and just destroyed. This was Shimano UN55 but had similar experience with FSA Mega Exo/Evo.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Bearings and friction surfaces need inspection and cleaning/lubrication. Steel bike frames need a framesaver on the inside...or they'll rot from the inside out.
Yup. Full coverage fenders do wonders. People love to carp on MegaExo/Evo in particular...Mine is coming up on 10,000 miles of service, through many a long t-storm or downpour ride, and still spins smooth without noise. Keeping water out does wonders. Probably should finally break down and apply grease come thanksgiving time, just to do it.
Even good cartridge units aren't immune to abuse.
Quoted: 4227 Post(s)
Liked 2,488 Times
Modern hubs especially cartridge bearing hubs and bottom brackets are very well sealed against contamination, I never had an issue with water or snow getting into my hubs and ruining them... I also run full fenders on all my bikes....The problem with some loose ball bearing hubs is that they don't put enough grease into them at the factory. It's best to take them apart and put a lot of automotive wheel bearing grease into them.
Bikes: ...a few.
Liked 408 Times
I clean and repack the wheel bearings after every winter, or at least try to. You'd be amazed to find the amount of contamination that builds up inside. Sealed bearings will fare much better, but will still degrade with continual exposure to moisture.
Once the factory wax/lube wears off from the chain, you'll have to begin wiping off and oiling the chain when you ride in heavy rain. I just recently replaced the chain on my three-season commuter, not because of rust or build up, but just chain stretch.
Liked 298 Times
I am pretty abusive to some of my bikes. The hardest thing that I do to some of them, is not having a place to bring them in to melt the snow off.
this bike in particular has some pretty messed up spoke nipples. due to the weather.
with that said 'Rain bikes deserve brass nipples!'
As for the rain and everything else..... the biggest thing for me was looking to minimize maintenance. Other than brake cables, a single speed was my answer to minimal maintenance for a bike that sees diverse weather.
52psi
Quoted: 790 Post(s)
Liked 801 Times
I'm a big fan of "the bounce" after a rain ride. Multiple 3-4" lift and drops, alternating front and rear and letting the bike bounce on the tire in question. Shakes the excess water out of all the little nooks and crannies before any wipedown. Or at least that's what I tell myself it does.
Quoted: 1062 Post(s)
Liked 665 Times
In my view, any exposure to the elements adds to wear on the bike. But I consider an occasional rainy day or even a downpour to be part of normal cycling. I plan on enjoying my bikes, and maintaining them as needed.
Now, I do make some accommodations for road salt. Mainly, I limit myself to one bike during the winter, so I have just one bike to prepare and clean up.
Cycleway town
The only thing that really rust's up bikes is being left outdoors. 24/7 humidity will wreck a bike. This includes sheds, and even garages, especially where draught-proofing is poor.
A couple of hours a day in the rain is nothing in comparison, especially when the bike is kept indoors.
This bike has just spent well over a year as a car-free daily. No matter what the weather, it has done 400 days in the last 400 days. It's kept indoors. I have searched, but trust me, there is not a spot of corrosion anywhere. The rear spoke nipples have dulled a bit, though.
Quoted: 92 Post(s)
Liked 12 Times
Unless your bike is made out of sugar, a little rain won't hurt a thing.
Quoted: 2594 Post(s)
Liked 1,922 Times
In the past couple years I've had more problems with cable ferrules and adjusters rusting than anything else. Annual bearing re-pack, oil chain when squeaky, oil pivots when chain needs lube, and fenders -- that's my service plan.
Quoted: 5222 Post(s)
Liked 3,576 Times
keep the drive train clean, dry & lubed to the best of my ability. replace parts as needed. nothing is precious ...
Lurker
Bikes: A lot!
I will be coating all bike left outside in the rain with a layer of Boeshield T-9, then a layer of LPS-3, then some ACF-50.
My plan is to be able to leave my cruddy bikes like the Huffys and beach cruisers outside in the rain and if friends want to come ride, they can just jump on a bike and ride it, no tune-up needed! My main problem with these bikes in the past has been: The chains and cables and shifters and brakes and steerer tubes and bottom brackets and wheels all rust up over the winter and then people come over to ride on a nice day---and the only thing not broken is the tires, still inflated :/
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,201 Times
I’ve also done a lot of mountain biking here fenders are a liability and dirt is ubiquitous. I’ve only worn out a couple of rims in 40 years of riding.
Stuart Black
Stuart Black
Quoted: 4789 Post(s)
Liked 3,915 Times
If you pack all serviceable bearings with (all you can pack) marine boat trailer hub grease and use the same on threads, exposed steels, etc. you need not worry about anything getting wet, even very wet. No water the bike will ever see will touch that stuff. I use Finish Line MTB lube (A fairly thick oil) for my winter chains, again because it stays around. (It does get filthy. Oh well.)
Edit: If you build your wheels using the same boat trailer grease, the nipples will never freeze on. I replace rims every 2-3 winters (Pacific NW, rim brakes - that's life) and reuse the spokes for the second and third rim, replacing perhaps three nipples at the rebuilds.
Ben
Ben
Liked 3,915 Times
This something that everyone says but I’m not sure I agree. Rain shouldn’t make the brakes wear out any faster than dry. The grit is there no matter what. If anything, rain should keep the dust down so that the wheels don’t have as much dust on them as the water washes it off.
I also can’t agree with this. Again, from mountain biking with unfendered bikes, I have never had a sealed cartridge bearing bottom bracket wear out of any flavor. I’ve replaced a lot of them through upgrades but I’ve never worn on out. I also see a lot of cartridge bearing BBs at my local co-op and have only seen a few that aren’t functional. Most of the used ones we have could go several years without issues.
If you use a sealed bearing BB that is made purely to race in non-water environments, riding in wet weather can kill them. Fenders (including a good, deep front flap) with these BBs make a big difference. I use Miche BBs on my good fix gear, a ti bike I ride all winter. The Miches because they are ISO taper and not too expensive. (I might go Phil next time around.) I will agree that the oh-so-common Shimano sealed BBs are very hard to kill. But my Sugino 75 cranks don't like their JIS taper.
Ben
Liked 298 Times
apparently cyccommute has never heard of water cutting before. I mean they don't do aircutting in industrial applications, they do water cutting for reasons.
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
The issue isn’t about certain kinds of weather, or the use of sealed bearings vs non. It’s all about foresight, preparedness and diligence.
A few few points:
1. Not all cartridge bearings are ‘sealed’. And referring to a cartridge bearing as a ‘sealed bearing’ is wrong. There are also plenty of loose ball hubs and bb’s that have seals to help prevent ingress. How well all of these work is.. well do you trust the water resistant seals in your watch or your ‘weatherproof’ camera? How about that new smartphone? Yea me either. And the seals in a proper sealed cartridge bearing are just as effective or not as other seals. The best prevention of ingress is multiple-stage seals, like SKF bb’s use, for example.
2. Most corrosion that occurs though, occurs long after your ride in the rain. This almost always comes from simply leaving a bike wet. The best way to prevent this is by simply drying the bike after it’s been ridden in the wet. I’m a commuter, and as such I always carry a hand towel to completely dry off the bike, especially on parts that are more prone to corrosion. Chromed steel is a big one. Don’t let the bike air dry, especially in a cold or humid enviroment and be surprised you got rust. And if theres rust where you can see, there’s likely more rust where you cant.
3. Use quality grease, especially this time of year. But nothing is more important than diligent maintenence. Doesn’t matter if you have all ‘sealed bearing’ everything or loose ball bearing everything. Take things apart, inspect them and if necessary clean and re-grease them. If you’re doing a lot of riding in the rain, I would recommend this every two to three months, especially if you’re usibg loose ball bearing components.
4. Excess wear of brake pads and rims, is heavily dependent on where you live, but in general, water and other debris get mixed together with the brake dust that’s already on your pads and rims, when wet. This creates a bit of a ‘slurry’ that will also contain whatever is on the road surface, trapped by the rain and kicked up by your tires. (Obviously things like full coverage fenders and even a fully enclosed chaincase make a massive difference here. They were invented for a reason.) in my case that extra ingredient is sand, as I live on the southeast coast of the US. In dry weather it’s no biggie, in the rain, it becomes a big biggie. And it will absolutely create excess wear to pads and rims. Don’t believe me? Ride a pair of black anodised rims with rim brakes in the rain. Nothing you can do to avoid it in the moment, but when drying off your bike after the ride, do a quick wipe down of both the rims and the pads to remove any debris.
5. Check everything! Don’t just focus on the obvious, like headsets and hubs. Check pedal bearings, freehub bearings, remove seat post and stem periodically (use framesaver in a steel frame). Remove and clean cassettes. Also remove tires and check for moisture on the inside of rims. Certain rim tapes (cotton tape like velox) can soak up and trap moisture and can corode nipples and eyelets.
6. This is especially important on older (like C&V) bikes: If you can replace chromed, galvanised or regular steel fixtures, like bolts, with stainless, do it. Stem bolts, chainring bolts, binder bolts, etc. Also, stainless cables and housings are always a good idea, as is a stainless or nickel plated chain.
7. Clean your chain, regularly. Seriously. And don’t over-lubricate it. Use a lubrication designed for use in wet conditions, but use it sparingly.
this time of year, where I live sees a lot of rain. I install fenders, but my daily rider/commuter has loose ball track hubs, loose ball bb, loose ball pedals, cartridge bearing headset, a cartridge bearing freewheel, rim brakes and a leather saddle. I replaced my chainring bolts for stainless, I use stainless cables and housings and a stainless chain (connex). A 41 year old steel frame with chrome. no corrosion and no worries. Also, no need for a ‘beater’ bike. Those type of bikes are for people who are too lazy to properly take care of what they own.
A few few points:
