Shimano information.
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
Is there a Shimano site/consumer help area, that will tell me what the compatibility would be across the Shimano line of products? Would like to upgrade a piece or two on my bike but want to know if the new derailleur I may want will work with my current shifter.
Thanks in advance, Frank.
SE Wis
Quoted: 2747 Post(s)
Liked 3,394 Times
Quoted: 249 Post(s)
Liked 306 Times
Quoted: 18376 Post(s)
Liked 4,510 Times
I've found this page particularly useful with understanding cable pull issues.
https://en.wikibooks.org/wiki/Bicycl...ing_Dimensions
Perhaps post a note of what you're trying to accomplish, and someone will make a comment on the likelihood that it will work.
Quoted: 249 Post(s)
Liked 306 Times
My knowledge is shallow while my ignorance is deep. I am in over my head but this is how I learn.
Frank.
Liked 4,510 Times
Thank you for this also. Great information. As far as posting a note I will once I can make a semi-intelligent question as to my end. As of now, with the information already given, I believe I can not do what I am attempting with out changing the shifters to use the front derailleur I want to use.
Frank.
Frank.
If you are close, there are a couple of ways to adjust cable pull and other compatibility issues.
WolfTooth makes a "Tanpan" to convert between MTB and Road cable pull.
https://www.wolftoothcomponents.com/products/tanpan
Jtek makes a similar Shiftmate to convert between various road formats, in particular Campagnolo vs Shimano
Jtek ShiftMate Gear Shifting Adapter for Shimano Campagnolo and SRAM components
You will also see notes of "Hubub" cable routing which may help adjust a bit if you are very close.
The "Travel Agent" is similar to the above, but designed for using road brake levers with linear pull V-Brake calipers.
Tektro also makes some long pull/linear pull brake levers for drop bars. RL520
Wolftooth also makes a Goatlink to drop your derailleur a bit, if you need more range.
https://www.wolftoothcomponents.com/products/goatlink
Microshift Mega bar end shifters are designed to work on road bars with MTB derailleurs.
https://www.amazon.com/Microshift-Me.../dp/B01NBVFRKC
Quoted: 249 Post(s)
Liked 306 Times
CLIFFORDK, thank you for this information. I appreciate your taking the time to post this.
Frank.
Frank.
