Gravited to the Upper Crust of Biking and now clueless :-(
Quoted: 54 Post(s)
Hello all,
I gotten a bike that's about two years old and I haven't got the foggiest what these bosses are for.
It is at the rear end of the left chain stay.
Also this mount fits nice on the center of my handlebar stem and the seller told me it came with the bike and is suppose to be a fairly univerisal mount. Any ideas?
Thanks for any info you might have and I appreciate all replies.
Quoted: 7653 Post(s)
Liked 3,485 Times
The mount is a headlight mount, maybe a Lezyne mount. Forget "universal." I have had half a dozen headlights and none of them share mounts.
No clue what's under the cover.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
What model bike is it?
Quoted: 54 Post(s)
WALSTIB
The kickstand mount Trek seems to be using nowadays. One shop had kickstands on most Treks on display
SE Wis
Liked 3,401 Times
Quoted: 54 Post(s)
Dang man, I thought this was for something like the sweetest trailer hitch ever seen! An F-ing kickstand huh?
Quoted: 5793 Post(s)
Liked 2,595 Times
Nothing stops you from using it for whatever you want. A bit of scrap metal, a drill and a file, add some creativity and you have the sweetest trailer hitch ever seen.
FB
Chain-L site
FB
Chain-L site
Quoted: 1062 Post(s)
Liked 665 Times
Quoted: 54 Post(s)
Granted those two bolts might not be able to handle a trailer, but I was thinking of a light weight trailer. Maybe weight limit of 50 lbs? You would think in this day and age designers are putting out a better trailer hitch system. The stuff out there looks like it hasn't improved in 20 years.
Bikes: A hauler, a commuter, and a steamroller.
Quoted: 15 Post(s)
The rear double bosses are for a kickstand. No idea what the other on the handlebar is. I have a crossrip elite, also, same frame color and year, no handlebar mount.
Quoted: 54 Post(s)
Have you had any problems with the bottom bracket? I've had mine coming loose on me. This last time I really torqued down on tightening it. Hopefully that does the trick.
Quoted: 54 Post(s)
Quoted: 18431 Post(s)
Liked 15,585 Times
Trek Crossrip Elite=reaching the upper crust? Thanks. My cat is declining due to lymphoma and I needed a good laugh.
It's fine - I have the same one on my Trek Crossrip and it's pretty robust. I even started riding with the stand down by mistake once and scraped it round a corner - no damage.
Quoted: 54 Post(s)
Sunshine
Quoted: 10971 Post(s)
Liked 7,499 Times
A handful of people I ride with use those mounts to attach a kickstand. And others use an adapter which attaches to the stays since they dont have those mounts.
Rear wheel kickstands are apparently becoming purposefully cool.
