Wider tires - same inner tube ?
Hi,
I got a Trek DS 3 (2021) bike that i just bought.
The tires i got with the bike are 700x45cbut i want a little wider tires 700x50c, do i have to buy another set of inner tubes or can i use the ones that i have allready ?
Quoted: 9652 Post(s)
Liked 6,363 Times
Optimal would be a tube that is size matched to the tire. But, I'm intentionally running tubes that are one size down in one of my bikes with no issues. Tubes stretch quite a bit.
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 404 Times
Check the stamping on the tube. It should indicate what size tire(s) its recommended for.
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
Most of my tubes have a range of tires, 30 - 37mm as a for instance, of what size tires they will fit. I would hope that your tubes will have it marked on them but unfortunately, you would have to break down the tire to see the tube. Maybe your local Trek bike store can tell you the information but I think you would have to do the work yourself and see what tube you have on your bike. Not what you were looking for as the answer but this is the situation you are faced with.
Be safe, Frank.
Be safe, Frank.
