Flared bars - have you tried them?
Quoted: 1461 Post(s)
Liked 1,485 Times
I have been a bit skeptical of flared drop bars on gravel bikes. I guess I'm a traditionalist and think they look a bit goofy, and it seemed like a gimmick by manufacturers to try to make gravel-specific versions of things that could otherwise just be standard road parts. Also, I ride (and race) a CX bike, prefer the race-oriented geometry and like quick handling lightweight machines that are aggressive and aero. My bikes have always had narrow road bars. I'm not doing DK or super long gravel days, I don't have a huge beard, and frankly assumed beyond extreme conditions that flared bars were mostly about looking the part, and didn't really provide any functional advantage.
Fast forward to last week... I had a fit session on my bike and the fitter noted that my shoulders were fairly wide compared to my bar width, and asked if I had ever tried flared bars. They started explaining how the shape and width might help alleviate pressure on my wrists and prevent my shoulders from being "scrunched up", and provide more control/comfort in the drops allowing me to ride in that position more, even on the road but definitely more off-road. They offered to put a flared bar on for me to try on the trainer, which was the (very expensive) Enve G series bar.
This is a 42cm bar measured across the hoods, and 54cm at the ends. The flare is not a straight line, but more of a compound curve so the result is that the levers are still relatively straight, and the bar widens out just below them. The tops are oval shaped, which provides more of a flat area around the corners as well, which is very comfortable to grip.
I was surprised at how instantly comfortable this setup felt. Just adding that few cm of additional width made the drops feel a lot more comfortable. I suppose the same result might be achieved by just going with a wider regular bar as well, but I also liked how in the drops my wrists are turned just a bit more inward which seems to be more comfortable as well. The carbon bar also promises more compliance, so a smoother ride over rough terrain (I have yet to test this). The downsides are obviously a bit less aero, and a wider bar may be problematic when navigating those first few turns on a tight and crowded CX course.
Anyways, maybe it was just an awesome sales job (they did have a much cheaper alloy bar with a similar shape) or the fact that it was Friday and I felt like splurging, but I came home with the new Enve bar, a slightly more aggressive new fit, and I am excited to try out this new setup once the snow melts a bit. I am still a bit skeptical of using it for CX racing, both in terms of width and durability, so I may swap my old bar back on for the fall race season, but I'm looking forward to getting some outdoor miles on it soon. I'm either going to love it and wish I had made this change years ago, or be tying to sell the dang thing on Ebay in a few months and be wondering what I was thinking...
Likes For msu2001la:
Quoted: 714 Post(s)
Liked 800 Times
You're going to love them. I have FSA Adventure bars on all of my drop bar bikes now, because I prefer the wrist position. I tried some of the wider flared bars, like the Gary Sweep and didn't like them at all. The 12 degree flare of the FSA Adventure bars feels just right to me.
Quoted: 1088 Post(s)
Liked 1,024 Times
Sounds like what you got might not be an extreme flair. The 3T terranova gravel/cross bars I bought have the slightest flair to them, the result is that the bottom of the drops is only about an inch wider then at the brake levers, I prefer a 44cm bar and I find the difference quite comfortable.
My wife's most recent bike came with a really noticeable flare to them, I suspect about 18 degrees and they sucked to use. The twist they put in the brake levers made riding them uncomfortable since it was no longer a flat surface. Looking at a cervelo with 12 degree flare it was obvious that GRX levers were designed for this but not wanting to replace brake levers I wasn't bothering with this. 24 degree would probably suck for regularly riding on the tops of the levers.
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
I use Salsa Cowchipper bars. Its the middle bend of their 3 dop bars with 24deg of flare.
I love the bar and while riding it doesn't seem like an extreme angle at all. The hoods are comfortable at that angle and the shallow drops make for easy steering with a wide slow base when the surface is sketchy at higher speed.
Flared bars are so varied in geometry that each one looks and feels slightly different(though its easy to adapt to many, i think).
some flare more than others, some have more sweep, some have the hooks bend sharply, some have the flare at the bottom of the hooks only, some have significant back extension, etc etc.
If one flared bar doesn't work, try another and same as road bars, really. Too much variety to just dismiss an entire style of bar after 1 try.
There are lots of great flared bars that are close to road style with less flare.
Likes For mstateglfr:
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
Cowbells here. handle just like a normal drop bar with with a little flare. If I needed to replace this one, I'd go for something a bit wider and with more flare for stability.
Liked 1,485 Times
The bar is the Enve G, size 42cm (which is their narrowest size). It's not as extreme as some other bars I've seen, but still is way more than I've ever had. It looks much wider from behind than from the front. My bike is a Cannondale SuperX. Photos below:
And from experience, using wide, flared bars don't present any additional challenges during a CX race (44cm cowbells here). That extra width is actually quite handy in a slippery descent or off camber.
Now get going on that beard.
Likes For justin1138:
Sunshine
Liked 7,490 Times
And yes, the three different flared bars I have used all look more extreme from behind than from the front. I think its the sweep of the drops that are more easily visible from behind.
Liked 1,485 Times
The Enve bar tape they put on is pretty nice too, has a good grippy texture.
This has been my experience with gravel bars so far:
Ritchey Venturemax - Used on my first gravel bike because it looked the part, and I didn't know any better. The flare was way over the top, and I didn't find the ergo bends to be ergo at all.
Satori X-Race Aero - OE bar that was actually very good with the perfect reach and drop, and I liked the flattened hooks a lot as well. The 16 degrees of flare was still too much though. They make an 8 degree version, but it's hard to find this bar for sale anywhere since Satori mostly just makes OE parts.
Ritchey Butano - Not bad, and the 8 degrees of of flare was just about right, but I really missed the flattened hooks that the Satori had.
Zipp 70 XPLR - This bar has only 5 degrees of flare, but the drops sweep out more than most bars. This keeps the brake levers from tilting out (good), but I'm not sure how useful the drop sweep actually is.
Personally, I don't like a lot of flare because of how it changes the brake lever position, and it also makes riding in the hooks / drops feel more like an open parachute. Doesn't really seem to add that much control over technical terrain either, but I agree it's a little easier on the shoulders for long hauls. The above comments are based on my experience mostly riding midwest gravel that is pretty tame outside of some MMRs that can get tricky.
For a dumb comment, I would actually really like to try VO Crazy Bars /w aero bars extensions on a more extreme terrain / YOLO fun extra gravel bike. For some reason I find that more appealing than trying to use some crazy drop bar for very technical riding.
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,833 Times
My off-road is generally packed surfaces with varying amounts and sizes of gravel. And i’m not racing.
Preferring narrow bars, I found Soma randonneur bars. 40cm ctc at the drops, 35cm at the hoods.
Not many miles. Not sure about the bends on the ‘tops’, but good on the hoods and in the drops.
Likes For Wildwood:
Old guy on a bike
I recently bought the Enve G and love it. I have the 46, which is 58 at the drops and is much mor comfortable than the 44cm I took off. Also, this is my first carbon fiber bar and noticeably less buzz than aluminum.
bOsscO
Bikes: 2024 Spec Crux, 2015 Norco Search S1, 93 Mongoose IBOC COMP
Quoted: 296 Post(s)
Liked 355 Times
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
The flared lower portion is about perfect for me, and feels natural to the point of invisibility when my hands are at the ends of the drops. Highly recommended.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
After riding Cowbells for a while I am sold on the idea for literally any type of riding.
