Looking for a lever nut
I'm looking for a quick-release #8 36-tpi (metric is fine) nut.
I want the quick-release lever-type that cams down a little. Most of them have the bolt/post/shaft attached to the lever, but I need the nut/threaded/female side in the lever end
I don't know what to call this thing, let alone where I can find it
Cheers
Cheers
Quoted: 194 Post(s)
Liked 204 Times
Do you mean something like this kind of quick release lever?
Quoted: 713 Post(s)
Liked 796 Times
It's called a Nylock or nylon locking nut. https://www.amazon.com/U-Turn-Fasten.../dp/B07H742C6T
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Quoted: 2026 Post(s)
Liked 1,096 Times
Duplicate post. Sorry
Liked 1,096 Times
Cheers
Cheers
Quoted: 6187 Post(s)
Liked 4,803 Times
If you need a #8-36 nut, then how can metric be fine? A M4x.7 might be close, but probably so sloppy you won't get to tighten it much.
Quoted: 427 Post(s)
Liked 699 Times
Don't know if they all do, but our local ACE hardware has drawers with many different nuts, bolts, etc. I've been surprised at what I was able to find there. And I can buy just one or two instead of several in a package, as at a big box hardware store.
Liked 4,803 Times
Are you replacing one that came original on the bike? What make year and model bike is it. That might give someone a clue to helping you find one.
Quoted: 1943 Post(s)
Liked 2,164 Times
Have you contacted Sunny to see if you can get a replacement?
I know there are parts lists online. If you know the model number and can get the PN of the missing part that would be my first step.
John
John
Cheers
Quoted: 713 Post(s)
Liked 796 Times
Now that I understand what you're looking for, they are called "cam handles". McMaster Carr has them here https://www.mcmaster.com/handles/han...threaded-hole/
