so why no disk brakes on touring bikes?
#51
Bike addict, dreamer
I hope I'm not stepping into anything here...
I test rode a Kona Sutra with STIs and Disc brakes. The braking was horrendous and the levers felt spongey. The bike was discounted to $700 because no one liked how it felt and the shop said they'd never stock them again. I have no idea if they just didn't set them up properly or if there was inherent weakness, but that bike simply didn't stop properly.
On the other side, a friend from the forum built an awesome Soma with disc brakes and STIs and that stopped like a dream.
Adam
#52
Someone alluded to disc hubs having an effect on wheel strength a while back. I can understand this on the front, where the rotor mount requires the hub to have unequal flange spacing and thus a tension imbalance between the left and right-side spokes, but I'm wondering what the effect is on the rear. On the one hand, the rotor mount will reduce the flange spacing, which could make the wheel laterally weaker, but on the other hand, wouldn't pushing the left-side flange inward actually offset some of the dish caused by the freehub, which would tend to equalize the spoke tension?
I'm just curious since, if a non-disc rear wheel is stronger, it tends to argue that the "disc in front, rim brake in back" configuration might be preferable to an all-around disc frame.
#53
Bicycle Lifestyle
Bikes: Neil Pryde Diablo, VeloVie Vitesse400, Hunter29er, Surly Big Dummy
that is
the curve allows you to simply step across the top tube
rather than swing a leg over the saddle
and/or
the need to lean the bike some to get a leg over the bike.
curved tube lets you step across the top of the frame
while the bike can stay relatively stable.
#54
Single-serving poster
#55
Check out the Gunnar Rock Tour. From the pictures it looks like it needs a suspension-corrected fork though. There's also the Rock Hound and Rock Hound 29'er, but from the pictures it looks like they don't have the rack-friendly caliper mount.
I wish there was some brand with this kind of disc mounts, although I guess On-One is the only one - since they designed it...
https://forums.mtbr.com/showthread.php?t=301181
The mounting hole looks so much more sturdy - though it has to be ridden to be proven... hmm....
#56
There's plenty available with disc brakes, if that's what you want. But why do you want them? Disc brakes add weight, require special (expensive) hubs, strain your spokes, and because of where they're mounted, require a heavier fork that's stronger near the middle. Most importantly, I can skid my bike with cantis; regardless of whether discs offer more braking force or not, the weak point remains in the road-tire interface. Once you've skidded, you've exceeded your bike's maximum braking power. If you want to improve it, you should focus on new tires, not new brakes.
Tourers also tend to be a cheap bunch. Many would rather free camp than spend $12 for access to a toilet and shower. I can't see many spending extra money on discs.
#57
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Stuart Black
Stuart Black
#58
I love m BB7's, got them on two bikes. Disks stop better in the wet and mud. Those claiming rim brakes are better probably don't ride here in New England. Bring out the gloves.
#59
Spokes aren't really an issue. Any wheel built to handle touring loads will handle disc forces with no issues. A stronger fork (and frame) is definitely worth considering from a ride quality perspective, though I don't notice any ride difference between my disc CX bike and my rim brake fixies or tourer (the touring bike honestly has a heavier duty fork than the CX bike anyway, and I strongly suspect that modifying the design to put a disc mount on it wouldn't actually change it very much).
As for skidding and power, the advantage to discs is they generate power with less effort (you don't need to grab as hard), and more importantly, they are extremely consistent. Wet, dry, icy, hot, cold, it doesn't matter. You'll always get the same amount of braking for the same amount of lever pull. When you are in a situation where precise braking matters, that consistency is just fantastic. Discs also have a big advantage when it comes to heat. Rim brakes cannot take as much heating without adverse effects (on the rim, tire and pads) whereas discs can take an enormous amount of heat before performance begins to be compromised. On a long descent on a loaded touring bike, that may be a big advantage.
To answer the original question (why they aren't seen on more touring bikes), I'd guess that its a combination of tradition and the fact that most touring bikes evolved from road bikes (where lighter-weight wheels/bikes and a lack of interest in absolute braking performance make discs less attractive). Theres a lot of market inertia as well (if the LHT sells well with cantis, why bother updating it to run discs?). And theres a bit of retro-grouchery as well.
I wouldn't be very surprised to see discs start appearing on more touring bikes in the next few years though, at least as an option. They definitely make a lot of sense on a touring bike.
Likes For jabberwocky:
#60
https://www.jensonusa.com/store/produ...rlock+Hub.aspx
https://www.jensonusa.com/store/produ...+M580+Hub.aspx
#61
Infamous Member
Bikes: Surly Big Dummy, Fuji World, 80ish Bianchi
facilitates ease of mounting the bike when loaded.
that is
and/or
that is
and/or
Sorry, maybe I should have said step-over clearance.
"Let us hope our weapons are never needed --but do not forget what the common people knew when they demanded the Bill of Rights: An armed citizenry is the first defense, the best defense, and the final defense against tyranny. If guns are outlawed, only the government will have guns. Only the police, the secret police, the military, the hired servants of our rulers. Only the government -- and a few outlaws. I intend to be among the outlaws" - Edward Abbey
#62
And no, I have never owned a disc brake bike. I have test ridden one or two, but have not been convinced that there is a benefit for riding on a road, touring bike or not. Trail riding may be different, as knobby tires may have enough friction to take advantage of any increased power provided by the disc brake. Mud on the rim would also be far more detrimental to braking performance than water (generally I find that it's actually easier to skid when my rims are wet because I've lost more traction on the wet road than I've lost on the braking surface.) Different technology is appropriate to different applications.
#63
Fat Guy on a Little Bike
Bikes: Two wheeled ones
Quoted: 1254 Post(s)
Liked 345 Times
This thread makes me really want to try a pair of discs on a long ride. I was looking at rack set ups and lot of the companies have lines specifically designed to work with disc brakes. I can definitely see not having the rim overheat on decents as a huge advantage.
I had a MTB where I was using v-brakes and ceramic rims and pads...I saw a notable increase in stopping power, especially in wet conditions. Would that work for a touring rig?
#64
The whole point of my post wasn't that rim brakes are better. It's that there are tradeoffs and in the end you will not increase your braking power because the brake is not the restricting factor. Essentially, to paraphrase your post, you are adding weight and expense in order to not have to squeeze as hard. If you have arthritic hands, this might make sense, but for the rest of us?
Now, I'm not arguing that there is anything wrong with rim brakes (FWIW, my touring bike has rim brakes, as do two of my road bikes). Just that there is a lot of misinformation out there regarding discs for some reason. On a road bike, there are really three disadvantages to discs: they require heavier fork/frame construction, they require 3-cross laced wheels (or at least a lacing pattern with trailing spokes) and they weigh more than caliper brakes. They are also hampered by the fact that roadies generally don't ride in bad weather, and certainly don't ride heavy, loaded bikes. However, on a touring bike, weight is a non-issue (seriously, who cares about an extra 1/4 pound of brakes on a bike with 5 pounds of fenders/racks and 30 pounds of gear hung on it?), the frame and fork is already pretty heavy (to handle racks and touring loads) and the wheels probably aren't 20 spoke radially laced jobbies.
On the other hand, I do have a disc-equipped road bike (A Lemond Poprad Disc) and have had another before (Redline Conquest Disc-R, which I had for 6k miles before selling). Both served as general purpose road/commuting bikes. I also have a rim-equipped tourer and two rim-equipped fixies that get used for the same purposes. The discs are flat-out superior brakes, even compared to the koolstop-equipped v-brakes on the tourer (which are excellent). I honestly don't see much in the way of downsides with them aside from weight (obviously, if you're building a weight-weenie machine, discs need not apply). I don't see them catching on in the roadie realm anytime soon, but I think they're an excellent solution on a touring bike.
#65
Neil, I have to disagree with you, disc brakes will increase your stopping power. I have four bikes with discs and 3 without. They are great for wet and dirty conditions. This is often what I ride in when I'm on trail, commuting or touring. I'm 230 lbs plus bike and gear, that's a whole lot to slow and stop. Ride one for a while, you will come to see the light. Be not afraid.
#66
Liked 4,218 Times
Uh, no. Generally speaking, they are both "disc brakes", but there are big differences between rim brakes and disc brakes as used on bikes. Rim brakes are squeezing a thin, hollow object (a rim) with much less force than a disc brake. They use soft, rubber pads with a long profile to compensate for the fact that they can't squeeze with much force. Disc brakes are squeezing a solid steel disc, and grab with considerably more force than a rim brake, using a solid resin (or sintered metallic) pad. They have very little in common in terms of function, other than that they are both, broadly speaking, brakes grabbing a disc.
Rim brakes use long rubber pads to keep erosion of the rim to a minimum and extend the life of the wheel. Replacing rims isn't a cheap proposition and the rim serves not only as a braking surface but as an integral part of the wheel structure and we want them to be as light as possible. You could use solid resin (rubber isn't exactly a liquid resin) or sintered pads for rim brakes you'd just have to replace the rims more often or use a harder material for the rim surface. There are ceramic rims out there that will take far more abrasion than aluminum will. If you used steel rims and sintered pads but no one would like the weight.
As for force, I doubt that you can squeeze the brake levers with much more force when using a 'disc' brake than with a rim brake. The advantage for the disc comes from less lever travel because the pads are set closer to the rotor. Most rim brakes I've seen are set too far from the rim for the best braking in the first place. Some advise that the brake lever should travel half way to the bars before the brakes engage...to prevent pitchover I suspect. That is far too much lever travel and is likely the major reason that people complain about rim brakes.
The amount of force that you can put on the rim or on a rotor hardly matters anyway. The maximum deceleration available for any bicycle braking system is limited by the tire's contact patch, by the rider's position and by the possibility of pitch over. Nearly every single bike out there is capable of enough deceleration to skid the rear wheel and rotate the bike around the front axle independent of whether it is a rim or 'disc' brake.
Stuart Black
Stuart Black
#67
When I want to skid the front and rear wheels, I use disk.
#68
Liked 4,218 Times
I can even skid the tire on my touring bike with a full load but even then skidding a tire isn't the test of ultimate braking power. Slide forward on any bike and you can skid the tire until the cows come home...ask any 10 year old kid to show you how if you don't know.
Mud and water on the rim aren't even that detrimental to decelerating a bike if you know how to deal with it. It take longer to stop but if you are riding in wet or muddy conditions, it's a lesson you learn pretty quickly (and possibly painfully).
The biggest single factor that you can use to influence how the bike brakes in any condition is to know how to move your center of gravity and how it influences the deceleration of the bicycle. Sitting on the saddle in a normal riding and applying the brake will allow you to get to around 0.5g of maximum deceleration before the bike rotates around the front axle and puts you on your face. Move your CG back and down a few inches and you can double that deceleration without the risk of hitting your face
Stuart Black
Stuart Black
#69
#70
FWIW, wet weather riding is one of the reasons that I installed a disc brake on my touring bike. In the rain, my rim brake-equipped bikes take a noticeable amount of time to clear water/mud/sludge off the rim before they provide any significant stopping power. The disc brake-equipped bike, on the other hand, begins to slow almost immediately and stops in a significantly shorter distance. Don't know if the disc-equipped bike really has more absolute stopping power than a rim brake, but it does provide more consistent braking and better modulation than any of the rim brakes I've used...
#71
Where is this disc vs v-brake discussion going anyways... i see a lot of arguments about the features of either systems but not much in the way of stating why fewer touring bicycles have disc brakes. The only real problem i ever heard about disc brakes was some guy dropping his bicycle into a fire-pit and the rotor being bent, but if he carried a spare rotor or a rotor truing fork(both wise ideas) he would have been rolling quickly. On the flip side i have heard a few stories about machined rim-brake sidewall failures ending trips and causing delays. Smashing a rim on a tree so it will become true enough to go through your brake stays is less than idea. Sand and grit grinding through expensive rims is not cool. If anything disc brakes increase the longevity of your equipment at a modest cost in weight(sounds good for touring) - does anybody have some real weight numbers here?
Finally, nobody here is trying to force certain people to use disc brakes, stick with the rim brakes if you want, but their are those of us always looking for a better fit.
#72
BB7 caliper + rotor: 329 g
Single Digit 7 (V-brake) + hardware : 185g (a common mid-range linear cantilever. Most of the other models were within 20 g give or take)
I also looked at a few Shimano hubs and the disc and non-disc versions were usually within 5-15 grams, with some having no stated weight difference (e.g. XTR freehub). You may also need center lock adapters so add a few grams there.
So by my math, the difference for 2 brakes is: (329*2 + 15*2) - (2*185) = 318g, or about 12 ounces.
#73
From the Avid website:
#74
Yes I forgot the fork...that could be pretty significant (also the left rear triangle). Not sure how to figure that one. I think there are a few cyclocross forks that are sold in disc and non-disc versions that might be useable to get an idea of the weight difference.
#75
Liked 4,218 Times
So, you seem to be siding with the disc-brakes-have-no-advantage crowd... but you admit that rim brakes take longer to stop in wet/muddy conditions?
As for better modulation, I haven't experienced it on the two disc brake systems I've owned. Both have been digital...either being on or off...and don't offer the kind of braking and speed control that I get from a rim brake . The hydraulic system I have on a mountain bike turns the bike into a skidding machine but the ability to skid the rear tire (or front) isn't a measure of deceleration ability of the bike. It's just indicative of bad braking. A rolling wheel will stop a bike faster with more control than a skidding one.
You can surely put me in the 'disc don't offer any advantage crowd'. I'm proud to be there
Stuart Black
Stuart Black
