so why no disk brakes on touring bikes?
Old 02-10-21, 12:06 PM
  #126
elcruxio
elcruxio's Avatar
Bikes: 2011 Specialized crux comp, 2013 Specialized Rockhopper Pro
Quoted: 862 Post(s)
Liked 334 Times in 222 Posts
Originally Posted by cyccommute
If you have something to say, start a new thread rather than drag out an 11 year old thread to comment on.
That said, I still hold the same opinion towards disc that I did 11 years ago. They aren’t “superior” to rim brakes. They are the same as rim brakes. I have ridden in mountains on road bikes, mountain bikes, and loaded touring bikes for 40+ years. I’ve even ridden tandems in those same mountains. Not once have I ever overheated a rim even when riding down those same mountains at 50+mph. How well a brake performs has more to do with how they are used than what the actual mechanism is.
The way that you avoid heating the rims...or rotors, for that matter... is to use the brakes quickly and sparingly. Hit them hard, slow down, and get off them. That’s for any kind of brake. You don’t squeeze on the brakes at the top of a hill and keep them on to the bottom. That’s how you overheat brakes.
But have you ever worn through a rim? Good rims are expensive. Or rather, good light rims are expensive. Ryde rims are cheap enough to be almost free but they're also incredibly heavy (and yet my next touring wheels will have ryde andra's).
A new rim every two or so years? Pass... Even if one uses cheap rims the rebuilding is a hassle. And with expensive rims the costs start adding up.
elcruxio is offline
Old 02-10-21, 01:31 PM
  #127
350htrr
Bikes: 27 speed ORYX with over 39,000Kms on it and another 14,000KMs with a BionX E-Assist on it
Quoted: 1024 Post(s)
Liked 57 Times in 49 Posts
I too still hold the same opinion as 11+ years ago... Discs are "superior in every way" to rim brakes, I can think of no parameter that rims are better than discs for sure, the only thing they are even close to the same is that they are both meant for stopping,...
350htrr is offline
Old 02-10-21, 02:53 PM
  #128
Tourist in MSN
Quoted: 3450 Post(s)
Liked 1,449 Times in 1,130 Posts
Originally Posted by elcruxio
But have you ever worn through a rim? Good rims are expensive. Or rather, good light rims are expensive. ....
A friend of mine thinks that Koolstop Salmon brake pads reduce rim wear. I put those on one of my bikes when I built it up, that rim shows very little wear so far.
Tourist in MSN is offline
Old 02-10-21, 02:58 PM
  #129
djb
Quoted: 2735 Post(s)
Liked 968 Times in 791 Posts
this, and always cleaning rims and pads after rain riding. Checking pads for embedded bits too .
but dirt riding with downhills and rain is hard to avoid.
So yes, I agree. And I like less finger pressure for strong braking with disc.
djb is offline
Old 02-10-21, 03:53 PM
  #130
Trevtassie
Quoted: 1188 Post(s)
Liked 1,154 Times in 640 Posts
To get to the same point as I was at with rim brakes, same stopping power and mostly no overheating I've needed to go to a 203mm front disc on my Troll. There are a few specific times when discs have sucked for heavily loaded touring, going down a long steep gravel dusted road where pulse braking wasn't possible because of lack of traction, also with bears so stopping to let them cool down wasn't possible either. Same with going down a super steep hill with lots of pedestrians so need to go constantly slow, disc went blue.
Bit of a PITA when travelling, have to take it off the wheel and tape it to the box. The rear disc on the Rohloff is even fiddlier, have to take the gear shifting box off to get the disc off.
Trevtassie is offline
Old 02-10-21, 05:06 PM
  #131
robow
robow's Avatar
Quoted: 595 Post(s)
Liked 281 Times in 192 Posts
Agree, that's another reason I like my salmons !
robow is offline
Old 02-10-21, 05:39 PM
  #132
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6192 Post(s)
Liked 4,190 Times in 2,351 Posts
Yes, I’ve worn through a couple of rims...as in 2 or 3. That’s over 40 years of riding and hundreds of wheels. I’ve lost more rims to cracked eyelets than to wear. It’s a non-issue. Nor do I use cheap rims. Nor do I use overly heavy rims. I generally plan wheels around the lightest rims I can find but wear is seldom an issue.
How are they “superior in every way”? I have rim brakes and disc brakes. I even have a bike with rim brakes and disc. At no point in 40+ years of riding mountains, mountain bikes in mountains, riding loaded touring bike in the much steeper hills of the eastern US mountains, riding loaded mountain bikes during off-road touring, and riding through 40 winters of commuting have I ever thought “this bike isn’t going to stop!”. The bike I have rim brakes and disc brakes on reacts exactly the same to brake input independent of which lever I’m squeezing. The rim brake doesn’t take any more or any less pressure to stop the bike.
Frankly, I can think of no parameter where disc are better at stopping than a rim brake. Lots of people know diddly about how to actually use their brakes effectively so they blame the tool and not the mechanic.
Stuart Black
cyccommute is offline
Old 02-10-21, 06:52 PM
  #133
350htrr
Frankly, I can think of no parameter where disc are better at stopping than a rim brake. Lots of people know diddly about how to actually use their brakes effectively so they blame the tool and not the mechanic.[/QUOTE]
Well now... I guess it would 'depend on what you expect, what you want, what you demand' , of a brake system... For the casual rider, the difference is... Negligible.... It's that simple, unless it rains, ( Oh Oh, I am squeezing the lever as hard as I can and the bike is NOT slowing down as good as I was expecting) or it snows, ( and the brakes are frozen), or when overloaded, and (going too fast an a too long of a downhill)... Not to mention the disc brakes "feel",... the disc brakes "consistency" ... the disc brakes "controllability",... with a single finger"... ... At least, it is so, with my disc brake system...
NOW, there maybe, are a lot of crappy disc brake out there... So, what is the answer,...??? Buy, quality hydraulic discs brakes, using dot3 brake fluid, it;;s that simple... IMO, after owning nothing but disc brakes for the last 20+ years... I would NOT buy anything without disc brakes... again JMO as to the differences I have experienced... , and what they are worth... To Me...
350htrr is offline
Old 02-10-21, 07:12 PM
  #134
robow
robow's Avatar
Quoted: 595 Post(s)
Stuart, I don't mean to interrupt your ongoing discussion but have you ever used any of the newer compressionless brake housing available on any brakes such as V's, mini V's, canti's or even mech disks ? Does it really offer much if any benefit for the significant additional cost in your opinion ? Thanks
robow is offline
Old 02-11-21, 02:10 AM
  #135
Trevtassie
Yes, makes a big difference, mainly with cable discs and to a certain extent high end rim brakes. Low end rim brakes, not so much, the arms will flex before the cable compresses
Old 02-11-21, 03:57 AM
  #136
djb
When I got my Troll x years ago, tore it down to frame and rebuilt with drop bars, I had to get longer housings, and asked my lbs for compressionless stuff, so I assume this is what I have. I am very happy with the braking and finger pressure required, and figure the housing is part of the equation.
I'd have to look at it to know what brand it is.
djb is offline
Old 02-11-21, 04:14 AM
  #137
JaccoW
Overdoing projects
JaccoW's Avatar
Quoted: 784 Post(s)
Liked 1,237 Times in 686 Posts
+1 on compressionless housing. It also makes a huge difference on most brakes but especially bigger drum brakes.
As for rim brakes vs. discs, I have little experience with discs but I have certainly had rim brakes become ineffective in the rain especially if it has been dry the weeks before.
In dry conditions both can work just as well but rim brakes do require more maintenance. And while I love tinkering, some things should just work.
JaccoW is offline
Old 02-11-21, 06:27 AM
  #138
Tourist in MSN
Originally Posted by djb
..., I had to get longer housings, and asked my lbs for compressionless stuff, so I assume this is what I have. ...
If it is much less flexible than the cables you have on other bikes, it is compressionless.
Old 02-11-21, 06:34 AM
  #139
saddlesores
saddlesores's Avatar
Bikes: inferior steel....and....noodly aluminium
Quoted: 1053 Post(s)
Liked 341 Times in 229 Posts
stopping power seems about the same if set up properly.
big advantage to disk brakes is not getting clogged
with mud as easily....
https://www.mtbr.com/attachments/mud...ud-jpg.964896/
saddlesores is offline
Old 02-11-21, 09:06 AM
  #140
cyccommute
cyccommute's Avatar
I’m not a “casual rider”. A “casual rider” doesn’t do 50 mph descents on loaded touring bikes. A “casual rider” doesn’t do 40 winters of commuting. I’ve ridden in pouring rain at 50 mph on loaded touring bikes downhill with only cantilever brakes. I’ve ridden down rough fast mountain bike trails in rain with only cantilever brakes. I’ve ridden home in ice storms with only cantilever brakes. I started mountain biking in 1985 when all we had was cantilever brakes and the brakes I had on those early bikes were not an impediment to riding most of the same trails that people ride today. The reason I use “most” is because lots and lots of trails have been built in the intervening years and I haven’t had a chance to try all of them...yet.
I, too, demand consistency from all my brakes. Brakes should slow a bike a little or a lot depending on how much lever force is input into the calipers. I have yet to run across a quality brake that doesn’t provide consistent performance...wait! I’ll dial that comment back a little. The only brake that was completely inconsistent was hydraulic brakes which I found to be grabby, touchy, and completely lacking in any kind of “consistency”. I have very good brakes on every bike I own...whether those are disc or rim...but not one of them is hydraulic. All my bikes...whether disc or rim...slow and stop when I need them to in exactly the same manner. If they didn’t, I’d change the brakes to something that will do the job. I just don’t consider discs to be the “be all and end all” of bicycle braking technology.
Stuart Black
Old 02-11-21, 09:11 AM
  #141
djb
thanks, I probably went though this when I did all this but have forgotten, will compare housings just to see.
djb is offline
Old 02-11-21, 09:30 AM
  #142
cyccommute
cyccommute's Avatar
No, I haven’t tried them. But I don’t find that the braking performance of any of the brakes I use...cantilever, dual pivot side pulls, mechanical disc, or linear brakes...are suffering in terms of performance. My bikes stop when and where I need the to stop in every condition and situation I’ve put them through.
To be clear, I use a lot of strategy when braking...even in emergency situations. I will use brakes in corners but I go very easy when doing so. Any serious deceleration is going to be done before the corner. The tighter the corner and the looser the surface, the more I brake before entering the corner. I don’t brake too much when going through a rock garden off-road...that’s a good way of ending eating a lot of dirt. Same if I have to hit a pothole that I can’t avoid. I get off the back of the saddle every time I brake, no matter if the road is smooth and flat or steep and rocky. Generally, braking should be done where the road or trail is smooth and straight rather than in the rough, twisty bits.
Stuart Black
Old 02-11-21, 10:09 AM
  #143
Tourist in MSN
I think that compressionless brake housings are most important on longer cable runs with full length housings. And moving the brake unit for discs to near the rear dropouts makes the rear a really long cable run where rim brakes have a shorter cable run . I used compressionless on my Lynskey rear because TRP specifically recommended that on the Spyre brake instructions. (Yes, I know, real men do not read instructions, sorry.)
And my Lynskey is new enough that they built the frame so that it could use hydraulic or cable and that means that the cable run lacks cable stops on the frame tubing, so full length housing has to be used. On frames where there are cable stops, since frame tubing is essentially compressionless, I think compressionless housing is less important with the short housing runs.
My expedition bike has full length housing everywhere to prevent mud and road grime from messing up the cables. That bike has rim brakes, but my rear brake is a bit spongey due to the length of extra cable housing along the top tube. That bike would probably benefit from compressionless cable.
My road bike has compressionless, but quite frankly I can't tell the difference in how compressionless and regular cable housing compares on the front rim brakes, the housing is so short on those brakes that any housing compression on normal cables on my other bikes with normal cables would be minimal.
Old 02-11-21, 10:24 AM
  #144
staehpj1
staehpj1's Avatar
Quoted: 1250 Post(s)
Liked 753 Times in 560 Posts
I hate zombie threads coming back! Especially when I have changed my mind on the topic.
FWIW, I thought disks were overkill back then and I love them now. Most of my bikes do not have them, but that is because they are old and I am too cheap to replace them. I love the hydraulic disks on my newest MTB. That said the rim brakes on my other bikes all work fine. I hate replacing worn out rims though and have needed to do so on half of the bikes that I was riding when this thread was started. Also I have found the disks require less attention and work a little better.
staehpj1 is offline
Old 02-11-21, 10:35 AM
  #145
Tourist in MSN
My folding bike has full length cable housing for all purposes. You would think that the cable runs would be short because a folding bike is small, but the cable runs are actually quite long due to the folding mechanism. I need tandem length cables for the rear derailleur. I have a 3 speed IGH (Sram Dual Drive) on that bike, thus a second gearing cable with full length housing to the rear dropout for that too.
Bike has rim brakes. I have regular (not long cable pull) brake levers, the levers you would typically use on canti or sidepull brakes. But I have mini V brakes on that bike and do not use travel agents. The long cable runs with normal cable housing means that I have a very spongey brake feel, but with the mini V brakes it takes very little lever effort to grip the rims pretty hard. So, I have to be careful when braking on that bike. I initially tried canti brakes on the front but switched to mini V later.
The braking would definitely be improved on that bike with compressionless, BUT I think that the folding mechanism might not play well with a cable housing that is that stiff. So, I will be sticking with the cable I have. The way it is, each time I fold and unfold it, I have to manualy try to straighten out the kinks in the rear cables.
This bike is over a decade old, they switched to disc several years ago.
Old 02-11-21, 10:42 AM
  #146
fooferdoggie
Quoted: 680 Post(s)
Liked 947 Times in 554 Posts
I
well you had the wrong hydraulic brakes. there is a big difference between brands and models. my magura's take a fair amount of effort to get the max out of them but they are always consistent. my shimano's are touchy but they only take 1 finger to stop with and you get used to it. but they are consistent till the pads are pretty much worn out. the brake pull hardly charges at all through the pads life. in the rain they are great.
fooferdoggie is offline
Old 02-11-21, 05:09 PM
  #147
djb
the bold bit pretty much sums up the Troll. Full length , but what you say about the shorter lengths kinda makes sense.
djb is offline
Old 02-11-21, 05:15 PM
  #148
djb
jeez louise, a crotchety old guy changing his mind, who wuda thunk !?
I think both your and my take on discs now is a pretty average take on the whole thing, even from riders who are ok with how rim brakes work, but acknowledge the advantages of discs. I'm just happier to be able to dump speed effectively with less finger pressure, so descents are safer and more relaxing for me.
djb is offline
Old 02-11-21, 05:46 PM
  #149
djb
ha, even Froomie aint happy
https://cyclingmagazine.ca/uncategor...le-moment-yet/
I do have to say that I like my old BB7s in that I can adjust each pad and make sure there's enough clearance to never have rub (when the caliper is aligned and I use my qr well and line things up well--not hard to do, just saying)
djb is offline
Old 02-11-21, 08:22 PM
  #150
Russ Roth
Quoted: 1079 Post(s)
Liked 1,015 Times in 718 Posts
I thought no disc for me on my touring bike but honestly their consistency on my mtb and gravel bike has changed that. My kids stopped fine with rim brakes on their first mtb, were happier with the cable discs on their current bikes but loved the upgrade to a basic shimano hydraulic system. They went from 3 finger squeezes with rim, 2 finger with cable and just use a finger with hydraulic and never struggle to scrub speed. Rim brakes do work fine but hydraulic brakes just work better.
Russ Roth is offline
