How to keep a Super Record seat post from slipping?
Cisalpinist
Bikes: blue ones.
Quoted: 5 Post(s)
Liked 16 Times
single bolt, micro-adjust but without grooves or knurling on either the cradle or the clamp insert. I found some threads in the mechanics subforum saying "you can't ", but maybe C&V knows better. What will help? Tape? Sandpaper? (I'd rather not damage this nice little post, so I'll just post here first before trying something rash )
Likes For Italuminium:
Bikes: Colnago (82, 85, 89, 90, 91, 96, 03), 85 Cinelli, 90 Rossin, 83 Alan, 82 Bianchi, 78 Fountain, 2 x Pinarello, Malvern Star (37), Hillman (70's), 80's Beretto Lo-Pro Track, 80's Kenevans Lo-Pro, Columbus Max (95), DeGrandi (80's) Track.
Quoted: 179 Post(s)
Liked 198 Times
I've never had one slip.
I take it that you are referring to the saddle slipping in the cradle.
Do you have one that slips?
I would imagine that a good de-grease would help plus an inspection of the mating surfaces to remove any high spots.
This is very interesting indeed.
Cisalpinist
Bikes: blue ones.
Quoted: 5 Post(s)
Liked 16 Times
The saddle is tilting backwards as I ride, sorry if that wasn't clear. The fore-aft position of the saddle stays the same (or at least changes as little as unnoticable). From what I saw on google it's a pretty common problem, leading to later posts having knurls or grooves for the micro-adjusting.
Quoted: 179 Post(s)
Liked 198 Times
So it's like this one? (photo from Velobase)
What about a bit of loctite on the mating surfaces? I've never tried any such thing, just brainstorming.
Likes For due ruote:
I'll bet fitting a small piece of fine sandpaper with a dab of this between the two surfaces will solve the issue.
Bikes on Flickr
I prefer email to private messages. You can contact me at justinhughes@me.com
Bikes on Flickr
Likes For ColonelJLloyd:
car dodger
I had a similar problem w/ my SR post a few years ago, I think I greased the bolt threads and torqued it a little tighter than it was. The saddle hasn't budged since. Even with a proper box wrench it's hard to torque that bolt enough due its low profile, if you aren't careful the wrench will slip off before it's tight enough.
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
Cisalpinist
Bikes: blue ones.
Quoted: 5 Post(s)
Liked 16 Times
car dodger
Have you tried friction paste? It helped with my moving seatpost and creaking handlebars.
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
Quoted: 443 Post(s)
Liked 27 Times
I have one of those as well as a couple of late Simplexes that look suspiciously like copies. Simplex used a socket head bolt instead of the hex head so you can apply more torque without danger of slipping. It's a better idea, but they blew it by using a bolt with a black oxide finish that tends to rust.
Quoted: 179 Post(s)
Liked 198 Times
Bikes: Casati, Look, Torelli, Ridley, and a bunch of steel bikes from the 80s and the 90s..
Quoted: 11 Post(s)
Tighten it a little more. it wouldn't hurt anything. I crank them down when even I change saddle.
Wow, even greasing the bolt ain't workin', eh? That cures it 9.99 times out of 10. Grip grease, clean everything, grease the bolt threads and bolt head seating surface and tighten like heck!
Quoted: 113 Post(s)
Liked 16 Times
If that doesn't work it is on to the next. Sand either the underside of the lower cradle or the head of the post.. unless there are already marks showing uneven contact points. If you can see that the contact is not even then I would sand the piece you think is less even and try again with friction past. It can't hurt to go at both surfaces with a coarser emery cloth just to rough them up before you apply the friction paste. I would go this route before trying something like sandpaper in there as I like things to work without have to add a band-aid. I have to shim the seatpost on my 2011 mountain bike and it pisses me off to no end.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
car dodger
Any good bike store should give you a small packet of friction paste just for asking - they come with some new bikes for assembly. Maybe buy a tube or something if they hook you up.
1983 Bianchi pista
1979 raleigh track
1983 Bianchi pista
1979 raleigh track
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Quoted: 78 Post(s)
Liked 30 Times
Make sure all the parts are clean and oil free, then only apply a bit of grease to the bolt threads and tighten down real tight.
Inner tube
My SR post is 41 years old and has at least 180K miles. It started slipping -- seat tilting back. I'm trying a slice of innertube on the lower rocker. Will let you know after I do a ride if this will work. It needs about 20 miles to start slipping. The issue might also be one where I can't tighten it down enough. I may try a socket wrench if this doesn't work.
Likes For rayhosler:
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
Just throwing this out there.....
I solved this problem on a full carbon, laprade-style seatpost clamp by putting a strip of friction tape on the cradle. It lasted like that as long as I needed it to.
Epic fail. It got worse with the innertube. I used a socket wrench to crank it down. One with a hinged head allowed me to get a good grip and position. I'll see if this works.
Quoted: 1106 Post(s)
Liked 1,328 Times
Single-bolt seat-clamps are a Bad Idea. Those with serrations are going to be never-just-right for some people; those without either rely on extreme clamping pressure or on a toothed spacer under the bolt head - an even worse idea as that makes its own serrations, each one a potential crack-forming stress raiser.
Except for access, the two-bolt and the simplex-pattern are better. Snug each one up, a little extra and it's done - and if it's a half a degree off you can tweak that no trouble.
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
I've used sandpaper to good effect. IIRC all mine needed was some wet/dry something like 400 grit, maybe I used 320
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Likes For Ex Pres:
