question about some stuff i have read...
so first off, about to purchase my first fixed gear bike from an individual...i am told that the bike is 52cm, i stand 5 9 and have read that w/ my hiehgt that a 52 or 54 would work...while speaking w/ the guy on the phone, found out that he is 5 6 or 5 7, and says that the bike might be alittle to small for me...but i have read someone on the internet amongst the pages and pages of cycling forums and blogs that a small bike is kind of ideal when dealing w/ a track bike...is this true? or should i not even waste either one of our time? have been super stoked on getting this bike for 200 bucks and to find out it may be too small kinda bums me out...ne way, i won't be seeing the bike for another 3 - 4 days thats when we can get together...so, insite please for all you veterans...thanks in advance
Disgruntled Grad Student
Bikes: CAAD 10, Cross Pro, Cross Comp, TK2
there are plenty of resources here, and elsewhere on the web to help determine what size bike is best for you. for a full, comprehensive fit guide, check out here:
competitive cyclist
for a less comprehensive guide, but still way better analysis than "how tall are you?", try here:
e-bicycles
if youre measurements put you within the range of that frame, then go nuts. keep in mind, minor fit issues with a smaller bike can be remedied by any combo of: more seatpost, longer stem, seatpost with setback, longer cranks, etc.
if you want to really do some math, do the competitive cyclist fit, and you'll be able to see if you can get components with proper setback, reach, etc. to fit you on that frame.
competitive cyclist
e-bicycles
Oh, you know...
Bikes: '74 Schwinn Sports Tourer (Polo), S-Works E5 Team Festina (Chorus 11), Trek 2200 Bonded Carbon (Fixed), Trek 920 (7 speed IGH), Chesini Olimpiade SL (1x7)
If you're just riding it around the city, don't sweat it. I'm 6'2 and both of my "city" bikes are 56cm.
Fit matters most if you're going to be in the saddle for long periods, or you are really trying to maximize efficiency.
For now, just do the basic stuff: adjust saddle height until you're getting comfortable extension on your legs, saddle fore-aft to get proper knee position through the pedal circle, and if you wanna get really ambitious you can play around with positive/negative rise stems or different lengths to tweak the cockpit.
If you're not riding that bike within an hour of picking it up, I'm gonna be disappointed.
Bikes: Leader 722TS, Surly Cross Check, GT Outpost, Haro Z16, Trek 1000
I found for me with track bikes that larger than what i ride road it better... usually i ride a 56cm, but the cannondale capo 61cm was perfect and my new leader 722ts is a 58cm and very comfy... my motobecane team track is a 56cm and is on the small side for me... so yea take from this what you will. Go see it, ride it (more than a block, more like 15-20min if you can) and if it fits buy it... like dsh said also consider how long your gonna be on the bike and what its use is for...
Goon
Bikes: Rocky Mountain RC30, Soma Sport Fixed
I think bike fit is important, even if you're not doing longer rides, not for comfort, but for joint health. if you're bike is too small, and your knee over pedal is too far, than you'll be hurting yourself over time.
Liked 12 Times
it's not about your height, it's about your leg and arm/torso length. i'm 5'11 and i ride 52cm(ish) because i have crazy short legs. but with stock frames, i end up looking for slack seat tube angles and/or running long stems to make the reach work...the alternative being to buy bigger frames (longer top tube) and run a normal(ish) stem, but have no seatpost showing. the best answer would be to shell out for a custom frame that was 52x56, but i'm cheap. what's your pants inseam? i wear 30in, with an actual inseam measurement of 29in.
Many people here are hitting it. It is not expensive to go to your LBS and get a professional fitting. There is no need to explain yourself or pretend you are there for any other reason. It is a "pay for" service. You want to be fitted. Take your clipless shoes if you have them. Some of the best money you will ever spend. They'll write everything down for you. I think it's typical to measure you with 120mm stems (worth keeping in mind). Be pro-active with your fitting. Ask questions. Try different setups. Be honest with yourself when it comes to what is comfortable. You can always make yourself uncomfortable if you decide you want a specific setup for whatever reason but the whole idea behind a fitting is to discover what is naturally comfortable for you. It's a baseline not an edict. Do it. Do it. Do it.
This is wrong. height does have to do with size. While size does vary, all size is relative and usually related. Da Vinci figured this out when he thought up this drawing. While it is deemed the "perfect" man the idea is everything is exactly proportionate to the other.
With this said, you will probably fit a 54cm. However, you could have a longer reach than most or higher/lower inseam, Or a back that doesnt allow you to be comfortable on certain frames. So yes, go get fitted. You wont know its comfortable till you do.
Quoting DaVinci is nice. So is quoting Beevis and Butthead. "He, he. He said load." Same contextual relevance to this thread.
