Where would you cut weight on your bike?
I don’t live in Tampa
Bikes: 2014 Jamis Ventura Race, 2014 Cervelo P2, 2017 Raleigh Tamland 1, 2015 Jamis Trail X
Quoted: 151 Post(s)
Liked 42 Times
I have a 2017 Raleight Tamland 1. The changes I've made to it have been adding a redshift sports shockstop stem, a shimano 105 crankset (as I had a left-arm stages PM for the 105), and recently upgraded the wheels which are much lighter than the stock wheels. The wheels obviously made the largest weight savings. At this point, without spending a bunch of money I don't see how I could reduce the weight that much any more. I could upgrade the groupset, add carbon fiber handlebars, and swap out the pedals for eggbeaters. all that would save me a bit. The groupset upgrade is probably more than I want to spend. anything I'm missing? I like the bike. it's a bit heavy but it's a nice ride.
Non omnino gravis
The easiest and cheapest method is to just not worry about it. You could spend a couple hundred bucks to drop a pound off the bike, and honestly never notice a difference. In my experience, a bike doesn't start to get unwieldy until it's north of 30lbs.
Weight weenies are usually okay with $1 per gram of reduction, and as someone who once upon a time worried about bike weight, you usually end up lightening your wallet more than the actual bike.
Not to sound like a typical N+1 guy, but If you want a lighter bike, buy a lighter bike. I have two bikes that are ~7lbs apart. The lighter one is a little easier to ride faster. But I ride the heavy one more often-- almost twice as often. Weight isn't everything.
Quoted: 1872 Post(s)
Liked 692 Times
I went weight weenie on a Tamland (like I weighed EVERY single piece). It was fine but it's just not a lightweight bike, and never will be.
2019 Salsa Warbird
2019 Salsa Warbird
Sunshine
Quoted: 10965 Post(s)
Liked 7,491 Times
- That Redshift stem would be an easy place to cut weight. A 100mm Redshift weighs 274g and costs $150, while an Uno7 UL stem costs $26 and weighs 108g. It doesnt have that elastomer suspension/absorbtion tech though. Anyways, thats where you could drop almost 6oz.
- Tires are another place where noticeable weight can be cut. There is a wide range of weight for similar sized/style gravel tires, and the lighter dont necessarily offer less realized protection. Popular tires vary in weight, even in comparable size. Conti Terra Speed 40mm is 420g, WTB Resolute 42mm is 460g, Vittoria Terrero Dry 40mm is 490g, Panaracer GravelKink SK 43mm is 497g, and Donnelly MSO 40mm is 532g. These are 5 popular quality gravel tires that are all tubeless ready and vary in weight by 110g.
Going from MSOs to Resolutes will save a combined 5oz and give you tires that are about 3mm wider. And they cost half as much as the MSO tires.
- A full carbon fork would drop some weight since the stock fork has an aluminum steerer. Not cheap though.
As for where I would cut weight on my bike- I just built a new one a couple months ago, so I dont think I would really cut weight anywhere since what I chose was what I wanted within the cost I wanted. Most was reused from my old gravel bike.
- I could cut 100g if i bought a new crank(currently a Shimano CX50 with 46/34 rings), but I dont want to spend the money. Though if I got a smaller crank ratio like 46/30, that would weigh less and I could get a slightly smaller cassette which would drop a few grams too. But thats chasing grams for too much $ for me.
- My frame is where obvious weight could be cut, but I would need a different frame entirely and dont want that. The current one is 853 main tubes and shaped 4130 stays. It isnt the lightest, but its really well finished and half brazed which I like. So the biggest place to drop weight is a place I am not interested in dropping weight.
- My saddle is a Brooks C17 and that is anything but lightweight. No interest in changing there either since comfort is more important than weight for a saddle to me. If I ever find an alternative saddle that feels the same over 50mi of gravel and either weighs or costs less, I will for sure buy it.
My two examples on where to cut weight on your bike would save 11oz and also save you $185. It isnt often that you can save weight AND money! Slap on 3mm wider tires, run em at 5psi lower pressure, and there is the increased comfort to offset the lack of elastomer stem.
Likes For mstateglfr:
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Gotta agree with Isotope.
just for education, here is how to get your bike down to 17.4lbs.
(Spoiler - He started with your frame, but in carbon).
https://gravelcyclist.com/training-r...n-gravel-bike/
Often you can save upwards of a pound on rotating weight by upgrading your wheels and tires without spending a fortune. Can't speak for anyone else, but I REALLY notice reduced rotating weight. And a pound off the wheels and tires is huge!
Bikes: 2011 Fuji Absolute 3.0 -- 1997 Trek 830 (modified to hybrid)
Quoted: 79 Post(s)
Liked 548 Times
I would look to cut weight directly above the saddle - unless that part is already anorexic or malnourished.
Quoted: 151 Post(s)
Liked 42 Times
Quoted: 151 Post(s)
Liked 42 Times
lol I've heard that before. Honestly a large part of it is genetics for me. don't get me wrong. I work to stay at this weight but even if I didn't do triathlons and bike a lot it would take me longer than most to gain that weight back. but in the endurance sport world there are a lot of people our height that are much lighter than I am.
Quoted: 1218 Post(s)
Liked 298 Times
Quoted: 151 Post(s)
Liked 42 Times
it's a thought for sure. anything I buy I keep in mind the idea of transferring over to a new frameset. the wheels and saddle are ones I'd be happy transferring over. The crankset didn't cost much. I could always buy a Lynskey gravel bike on sale or buy a lauf true grit frame + fork and transfer most others over. not for maybe another year or so though. If I bought a new gravel bike I might switch over to a 1x setup though.
Liked 298 Times
Quoted: 151 Post(s)
Liked 42 Times
Liked 692 Times
I don't disagree with you. I was fine buying a new set of wheels that I like and were a reasonable price. But the tamland frameset is steel and fairly heavy. the stock wheels were heavy so I replaced those. in theory that will save me ~1.5 lbs. I'll have to see once I put them on and weigh the bike if it ends up being that much. all else is small potatoes.
2019 Salsa Warbird
2019 Salsa Warbird
My Niner is right under 20lbs and I don't obsess over the weight. I'm cycling for excercise, so dropping 50 grams here and there means nothing. I have a buddy who obsesses over grams and it cracks me up. Ride the damn bike! Heck, I have two strong cups of coffee and a big bowl of steel cut oats an hour before I ride, and if I time it right I drop about 5 lbs right before I leave!
Likes For csrpenfab:
Quoted: 151 Post(s)
Liked 42 Times
Likes For biketampa:
Quoted: 6972 Post(s)
Liked 10,968 Times
If you like the bike, and you are comfortable on it, don't sweat its weight.
