VTG Stronglight 99 with smaller chainrings
Old 03-11-20, 09:03 AM
breezwhey
Bikes: 1972 Super Mondia Special, 1989 Gazelle Champion Mondial AB, 1972 and 1977 Peugeot PX 10, 1981 Peugeot PFN 10, 1984 Peugeot PGN 10, 1981 Peugeot PH 40, 1984 Peugeot Pipeline 1, 1995 Schwinn Searcher Range, 1990 Trek 930 MTB, 1995 Trek 730
Quoted: 9 Post(s)
Liked 5 Times in 4 Posts
Long story short, has anyone ever run, or know for sure if you can run a Stronglight 99 crankset double with a 40T or 42T outer chainring and a 30T or 32T inside chainring? In other words, use what is normally the inner chainring as the outer? I don't know why it wouldn't work, since the on the 99, the outer chainrings use the same 86 BCD to mount as the inner, but there may be something I'm not considering. I realize there are many other alternatives, but this is my cheapest solution to my problem.
breezwhey is offline
Old 03-11-20, 09:12 AM
bikemig
bikemig's Avatar
Quoted: 5885 Post(s)
Liked 3,468 Times in 2,078 Posts
I don't think there is any reason why this should not work. 86 bcd chainrings are available from Spa cycles in the UK.
bikemig is offline
Likes For bikemig:
Old 03-11-20, 09:16 AM
Bad Lag
Bikes: 1974 Bob Jackson - Nuovo Record, Brooks Pro, Clips & Straps
Quoted: 1104 Post(s)
Liked 794 Times in 452 Posts
The inner rings are usually not as nicely finished as the outers.
There may be an issue about counterboring of bolt holes, too.
Bad Lag is offline
Likes For Bad Lag:
Old 03-11-20, 09:32 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3870 Post(s)
Liked 2,563 Times in 1,577 Posts
As ​​​bikemig points out, Spa Cycles sells 86 BCD chainrings. That includes 40/42T outers and 30/32T inners, so you don't even have to think about using an inner as an outer: https://www.spacycles.co.uk/m2b0s149...l-40-50t-outer
(But even if you swapped rings between inner and outer, it ought to work fine. Not having the counterbore on the outer face just means the head of the crank bolt will sit proud of the chainring. EDIT: I wouldn't flip a ring around to use the counterbores, for the potential issues John calls out in following posts.)
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Likes For ThermionicScott:
Old 03-11-20, 09:36 AM
seypat
Quoted: 3233 Post(s)
Liked 2,512 Times in 1,510 Posts
Sakae/SR and Takagi also made 86BCD cranks/chainrings. Check the Bay. They are usually cheaper than the Stronglights.
seypat is offline
Likes For seypat:
Old 03-11-20, 11:18 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,393 Times in 1,927 Posts
The teeth on Stronglight rings are centered with respect to the thickness of the ring, while those on Sakae Ringyo rings are offset slightly, with a ramp on what is intended to be the inner face of the ring. If you use what is designed to be a middle ring on a Sakae Ringyo crank as the outer ring instead, that ramp will be on the outside (unless you ignore the counterbore for the bolts and let the bolts stand pround of the ring face), and shifting will suffer.
Been there, done that.
JohnDThompson is offline
Likes For JohnDThompson:
Old 03-11-20, 11:32 AM
breezwhey
Quoted: 9 Post(s)
Both very good points. I hadn't taken either into account. Appearance is very important on this particular build, so these may be a deal breakers. I am planning on just adding a 30T Stronglight from a triple to the existing Stronglight 40T, so I believe that would eliminate some of the other potential pitfalls.
Old 03-11-20, 11:45 AM
bikemig
bikemig's Avatar
But shifting won't be an issue if running a stronglight inner as an outer even if the bolts stick out, right? This is a problem with SR rings as they are offset? Or am I missing something?
bikemig is offline
Old 03-11-20, 11:58 AM
JohnDThompson
Old fart
The teeth are centered with Stronglight rings, so they can work as either outer or middle/inner rings. If you turn a middle/inner Sakae Ringyo ring to use as an outer, with the counterbore facing out for the bolts, the chain has a hard time climbing up to the outer ring.
Old 03-11-20, 12:00 PM
bikemig
bikemig's Avatar
I thought that was what you were saying but I just wanted to be clear.
bikemig is offline
Old 03-11-20, 12:47 PM
seypat
Great info! Between you and T-mar and others, we have a wealth of knowledge at our disposal.
seypat is offline
Old 03-11-20, 01:30 PM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
I have run a 99 with 28t inner ring and 44t or 45t outer. No problems, and I don't remember know whether the inner rings we're Stronglight or Sakae.
www.rhmsaddles.com.
rhm is offline
Likes For rhm:
Old 03-13-20, 09:27 AM
breezwhey
Quoted: 9 Post(s)
Sounds like it will definately fine work with Stronglight Chainrings, which is what I was planning on using anyway. I just need to see what it will actually look like before I decide this is the route I want to go, although I'm the only one who would ever notice the bolts. That or just build a another new-old bike just for hill climbing
Old 03-13-20, 09:39 AM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
Stronglight 99 with 28/40/45.
thumpism is offline
Likes For thumpism:
Old 03-13-20, 09:48 AM
breezwhey
Quoted: 9 Post(s)
Thumpism, I like the way it looks without the unused outer holes on the outer ring.
