27" X 1-1/4 tire, what tubes?
Bikes: '15 Trek DS 8.3 (Everyday) - '84 Trek 720
I cannot seem to find the required tubes that fit inside a 27"x1-1/4 tire. My brain hurts trying to figure out the tube size. I've got the old tubes;stamped at both 28x1-5/8x1/8 and 27x1,1-1/8,700x20c-25c. I cant make sense of this at all. What's going to fit a 27"x1-1/4 tire...? Help!
Bikes: 2017 Surly Cross-Check. 2020 Specialized Turbo Vado 3.0, 2002 GT Dyno Roadster, 2002 Rans Stratus, 2020 Giant Fathom 2, 2011 Trek Pure Sport
Quoted: 171 Post(s)
Liked 85 Times
700c x 28-32 is the same tube used on 27 x 1 1/8" or 1 1/4" tires
27" is very close in diameter to 700c, so tubes are interchangeable.
1 1/4" is nominally ~32mm.
So, if you get a 700c tube that's made for tires somewhere in the rough vicinity of 32mm, you'll be fine. I don't like going bigger because that makes the tube harder to install, but a bit smaller is fine.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
27 x 1¼ tires are 32-630 in ETRTO sizing - a standard which provides the most robust description of the tire size.
28x1-5/8x1 1/8 are 28-622 (aka 700-28c)
700-20c are 20-622
700-25c are 25-622
Tubes are very flexible.
So, 700-25c should be good to go on my 27"x1-1/4 wheel? The tubes I'm finding at that size describe themselves as fit for a 700c wheel which I've found out by buying and since returning 700c tires is smaller than my wheel.
Quoted: 86 Post(s)
buying tires that fit a rim is much, much more exacting than buying tubes.
buy a:
27x1 1/4
27x 1 1/8
27x1
700x25mm
700x28mm
700x32mm
tube.
buy a:
27x1 1/4
27x 1 1/8
27x1
700x25mm
700x28mm
700x32mm
tube.
Nigel
Quoted: 384 Post(s)
Liked 6 Times
Really Old Senior Member
The inside diameter of the 27" rim is 8mm more than a 700c. (630mm vs 622mm)
Thus, a 700c tube will stretch slightly and fit fine. (PI*8mm)
Likely the box will specify for both sizes.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
get a 700x 28-32 tube, with the appropriate valve stem size/design.
a 20-25 will stretch thinner when inflated, and will "pinch flat" more easily.
Bikes: The Good Book of bicycling
Quoted: 535 Post(s)
Liked 36 Times
Been wondering about a mountain bike inner tube. If i change my mtb tire from 2" wide to 1 1/2" wide, do i need a different tube? This is on an old mtb with 26" wheels.
thanks
thanks
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Depends on what tubes you were using before. Some of mine are marked 26"x1.5-2.2", which would work with either.
Liked 2,568 Times
It probably could work, but would increase the chance of pinching the tube when installing it. Make sure you have a little air in the tube to give it shape when putting it in the tire.
Thumpic
Bicycle Mechanics
14
10-25-13 06:25 AM
imetazoa
Bicycle Mechanics
21
02-04-13 11:44 PM
