Few simple Q`s for you mechanical experts..
Bikes: Trek Top Fuel 26" & Trek ion cx 28" (cyclocross)
Quoted: 86 Post(s)
So while the red loctite seems to work its magic, i am moving forwards and can administer to less pressing concerns. I recently decided to clean out the hub and re grease with the Park Tool green fluorescent tube grease and removed the cassette from my 28" rear wheel to get in there. I do this maybe once every year. After reassembling the wheel, there is one thing that i really need you guys advice on. That long bolt that runs through the wheel hub has one side with a few pretty darned tightly fitted nuts. The other side has the nut that you`re supposed to tighten the hub assembly altogether. If i tighten the bolt too hard (with my fingers), as long as the rear wheel is turning, the crank arms will "follow" in a spiral like if i was cycling. If i only mildly tighten this bolt i can spin the rear wheel without having the crank arms following. Right now i have cycled maybe 10 miles in sun and rain hoping this syndrome would let up. It has not. So am i really supposed to only very lightly tighten this bolt before i move on and install the cassette? Or is it ok to have a bike that has this syndrome assuming this will not correct itself within a few days or weeks or even months. Thankyou for any good advice
2nd question. I need a high quality grease for my steering wheel upper and lower bearings. It seems to be much thicker and tackier than the above mentioned Park Tool grease. I don`t really know what i am looking for here, so some advice would be greatly appreciated
Bjoern in Norway
Bjoern in Norway
Really Old Senior Member
Typically, I tighten the DS cone/locknut much tighter than the NDS.
When I want to service the bearings, I remove the NDS cone/locknut and pull the axle out the DS.
I simply never remove the DS cone/locknut. (unless the cone is bad)
This avoids having to recenter the cone/locknuts on the axle to get equal protrusion on the ends.
I do remove the cassette first.
Your grease will work fine.
This might help , Park Tool Co. » ParkTool Blog » Hub Overhaul and Adjustment .
Quoted: 1074 Post(s)
Liked 295 Times
What you should be doing is something called "bearing adjustment". And to do that right on a cup & cone hub you do need to use a cone wrench.
The Park tool link that bikeman posted should set you right.
yes probably need a 15mm cone wrench + a 17mm box combo? for the locknut. (13mm is common cone wrench for the front)
the end inside the Cassette is hard to get to once the axle is in the freehub, so Get it tight .. then slip the axle in the hub with the greased bearing balls in place
you do the bearing preload adjustment on the easier to access non Drive side ..
remember the adjustment is even tighter with the QR closed, so a fine tuning of just right on that is something you have to learn ..
Quoted: 86 Post(s)
Assuming the DS is the side that holds the cassette, it goes without saying that i only remove the nut that sits in this end of the cone bolt.
I am not at all considering removing the nuts from the other side as these seem to almost be glued in place. So that right there means when i reintroduce the cone to the hub, the protruding on each side will be the very same as before. Right?! Sure my grease will work fine, but "fine" is not quite what i had in mind
As far as bearing adjustment, i have no idea what that is. I slapped it back together and it works as before. Cone wrench? Well let`s just say thanks for the linkie..
Quoted: 86 Post(s)
So you`re telling me the "head" of the cone bolt that has the "fixed" nut array is supposed to be on the side where the cassette is ??
Constant tinkerer
OP - in your original post, were you talking about removing the freehub body and putting it back on? Check out this link for more info on cassette hubs: Shimano Cassettes & Freehubs
Quoted: 86 Post(s)
Well in that case i can safely say we are not communicating very well together. On my rear wheel the cone bolt (the long bolt that runs through the length of the hub) has the "fixed nut array" on the opposite side of the cassette side. The NDS if i understand correctly.
I don`t think this varies from one wheel to another wheel. It would be nice for someone here to please tell me how tight or "loose" the DS
nut is supposed to be. This is still something i have not seen an answer to here. Forget everything i just wrote. It seems i have had the cone the wrong way all along, ugh. Ugh. Ugh.
Constant tinkerer
Here is a really great article on cone adjustment: Cone Adjustment
/K
Quoted: 86 Post(s)
both lock nuts should be tightened about the same amount against the cone. i've never heard anyone discuss tightening them, purposely to different amounts. they serve to hold the cones in place on the axle.
WRT the crank turning when the rear wheel is freewheeling, IME, it just means that the crank bearings are running with less friction than the unloaded freewheel bearings. and one or the other is always going to win that race.
you may benefit from an exploded view of a shimano rear hub and it's freehub and an explanation of how it works. the link a previous post is excellent.
Quoted: 4806 Post(s)
Liked 3,933 Times
Ben
What's a "cone bolt"?
Using proper terminology is normally half the battle.
I doubt it in this case though.
Constant tinkerer
I was going to offer this as well since his English is very good. But it's his bicycle terminology that is difficult to understand. And that's something that comes from native and non-native English speakers alike. Some reading through Sheldon Brown's bicycle glossary would go a long way if his goal is to be able to speak about this stuff fluently in English.
The OP has had multiple links offered to him that have the correct terminology.
Their refusal to adapt indicates they aren't even looking at them.
"Assuming the DS is the side that holds the cassette, it goes without saying that i only remove the nut that sits in this end of the cone bolt."
"I am not at all considering removing the nuts from the other side as these seem to almost be glued in place."
"As far as bearing adjustment, i have no idea what that is"
The OP asks for help and then absolutely refuses to do as suggested.
Quoted: 86 Post(s)
Shees you guys, i`m completely new to all these english bicycle terminologies and i don`t mean to pretend i know them all by heart just yet. The links are great, but i need some downtime to sift through those. I was presuming you would bear with me here while i speak my engl-ish mechanical language. And with all these terms, i guess i felt like doing a little bit of a revolting here, hahaha... But i do want to learn them
Off to work it goes..
Quoted: 86 Post(s)
Ok i get it, it`s not called a cone bolt. Just the axle that holds a cone on each side. The word cone i imagine derives from its conical shape. Makes sense. I`m ever so slighlty lazy, so it might take me a day or two to straighten things out between me and my bicycle. Easter is a welcome time to spend some of that elbow grease;-) I`m currently reading up on the cone adjustment link and i get the distinct feeling that my cone adjustment is off. Probably slightly too tight. It says little about the symptoms for a too tightly fitted cone, but i bet the most easily observed symptom for this as i previously mentioned is, my crank arms will "follow" long as the rear wheel is turning freely. The interaction between the cone adjustment and the quick release mechanism is an interesting point. Will be fun to observe how freely my rear wheel will spin after i install the wheel axle the correct way. I`m not so sure i need another "speciality" tool for adjusting any of my cones though. Thanks for the links btw, they were really helpful.
Bjoern in Norway
Bjoern in Norway
Constant tinkerer
This is still a little strange to me. It sounds like you're having a problem with the freewheeling mechanism in your cassette body. Which should not be affected by the cone adjustment. But I suppose if you crank down the cones way too much it might be enough to stiffen up the freehub mechanism.
