Can I safely cut a deeper dropout?
I'd like to cut a portion out of my dropout. The reason is that I want the tire to be more in line with the fork and handlebars. This will help with many of the artistic cycling tricks I plan to do.
To save me describing such tricks and derailing the thread, you can check out a post I made on the subject: https://www.bikeforums.net/alt-bike-...ng-anyone.html
I'm guessing I could either hacksaw or drill the dropout—not sure which one is best. Below is a picture of where I want to cut:
My question is how to best do this, and do you think the dropout will be able to sustain a reasonable amount of strength and not just crack or crumble in some way due to the cutting?
Here is some info on the fork: Hi-ten steel with 11/4-inch OD legs, 11/8-inch threadless steerer, and 6-millimeter dropouts.
I don't do any hopping, jumping, or falling tricks. The riding is generally light, and my weight is 150lbs.
Will this be doable?
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
I don't know the exact angle that you are after but would it not be better to remove the drop if it is stamped steel and reverse it...that would move the wheel axis further in shortening the wheelbase etc.
Any professional welder could do this...if you try drilling it on your own you will need to be very precise...otherwise, the front wheel will be out of alignment and throw of your balance defeating the purpose etc.
JMT's
Best, Ben
JMT's
Best, Ben
Voltaire
Voltaire
JMT's
Best, Ben
JMT's
Best, Ben
The tricks I'd like to do require that the handlebars be balanced with the forks and tire; grabbing the bars and spinning ones body around the bike on an imbalanced system wouldn't work too well. You should be able to draw a line from where the handlebars attach, through the stem, into the forks, and into the tire. It all needs to be as in line as possible. That is the most important thing.
I've ordered a special 90 deg. handlebar stem (e.g., stem stands straight up in line with forks) to take of handlebar/stem balance.
As to the welding suggestion, I don't fully gather what you're saying. Could you break it down a little? You don't just mean flipping the entire fork backwards, do you?
Liked 2,181 Times
Flipping the fork might be one way....it would depend on the rake etc.
Voltaire
Voltaire
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
As far as the safety of cutting the drop-out, no one in their right mind will tell you "no problem, give it a try". I would point out that (IMHO) you are using a normal bike for an unusual use (artistic bicycling) and this may put more than normal forces on the front fork (as in jumping from the seat onto the fork with both feet), so you probably need a stronger fork than normal. I recommend not doing this, and getting a fork designed and built for use.
But "Man's reach should exceed his grasp, else what's a heaven for?".
So I understand your original question as: "Will cutting this slot end up hurting the metal in or the structure of the dropout?" there are a couple of things to consider. The first is geometry. Cutting the slot at the angle you show will move the wheel back, but also up, so the front of the frame will drop. May not be a big deal, but you are going for a very responsive ("twitchy") bike, and this drop may have an effect. Consider this in your modification plans. If you cut the additional slot straight back (so that the axle slot was a doglog shape) you'd keep the front elevated. I suspect that you could cut a bit of metal out of the slot provided you left enough metal in the gullet so that your axle nuts tighten onto the dropout and don't touch the fork tubes. That may not allow you much cutting space (so is the view worth the climb?). But before you start, remember you have to stop cutting the slot to leave enough space for the nut, with (for example) 1/16" or 1.5mm clearance or so FROM THE WELD. Check both sides of the dropout, as he welding may be thicker on the inside or outside. You don't want a nut to tighten on the weld. (Frankly, I suspect that if you measure how much clearance you have right now, you'll be surprised at how little you'll be free to cut.
This then leaves the effects on the metal. Your dropout is welded. I don't know the alloy. The safest way to cut the new slots would be to lay out your slot with a sharp scribe, then clamp the dropout in a vice and use rat-tail and flat files to remove the metal. Done carefully and finishing with a an appropriately file (smooth, or perhaps bastard if you have a light hand) you won't mork up the metal. Welding in new dropouts is beyond my tech expertise, but a good welder can do this is its possible to ascertain the alloy that your fork is made of.
But, first thing, check out how much clearance you have from the current nut or washer to the border of the weld. And whatever your plans, make sure that they end up having the nut and washer on flat dropout, and not on the border of the weld bead.
Liked 341 Times
Ah, upon edit, and in watching the amazing video you cited, I see the issue: when you are standing on the handlebars you need to be able to do a quick 180° turn and have the wheel have the same alignment in either case. I see no way to do this with slotting the dropout. As outlined above, you could cut the dropouts off, cut the fork tube ends off appropriately, and then weld on new dropouts that give you the proper zero-offset design, with enough allowance of space between the fork/dropout weld and the the axle nut/washer/locknut.
I have to say that seeing the gal back up her bike was just amazing to me. The forum post that bedtime cited, contains a pretty amazing video of a gal doing some impressive tricks of balance and strength on a bike. I thought it was interesting:
And another one:
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
The YouTube video of artistic cycling in your other thread blew my mind. It's worth a watch for anyone even remotely interested in cycling (all of us!).
It looks like these bikes require the front axle to be directly inline with the fork's steerer tube (essentially, zero offset). This will be very difficult to achieve with an off-the-shelf fork, because that offset is needed to generate enough trail for stable riding, and forks are designed accordingly. Some forks have legs that curve forward and some forks have straight legs that angle forward. If your fork legs angle forward at all (from the centerline of the steerer), you may not be able to align the axle with the steerer, even if you could cut the dropout deep enough. In that situation, you'd theoretically want the axle behind the fork legs, so as to achieve that zero offset you want. From that respect, you could actually try to find a straight-legged fork that angles forward, and have dropouts welded to the rear of the legs (as they would normally be installed). You could then cut dropout slots as needed to position the axle directly in line with the steerer.
I'm not qualified to speak to issues of strength or geometry of your proposed modification to the fork, but I think I would get it done with a Dremel or similar. Use any number of special abrading drums with the correct material (they probably have some designed for strong metal). You would basically just "dig" the dropout deeper. Keep in mind that you won't be able to go ALL the way back to the tube of the fork leg because the axle lock nuts will need some room.
Here is one of my favorite videos:
No problem, give it a try. What do you have to loose? Start with a hacksaw.
My favourite artistic cyclist, especially considering that this performance happened over 55 years ago:
Liked 2,181 Times
[QUOTE=WizardOfBoz;21113147]As far as the safety of cutting the drop-out, no one in their right mind will tell you "no problem, give it a try". I would point out that (IMHO) you are using a normal bike for an unusual use (artistic bicycling) and this may put more than normal forces on the front fork (as in jumping from the seat onto the fork with both feet), so you probably need a stronger fork than normal. I recommend not doing this, and getting a fork designed and built for use.
+1 To all of the above and that is why a pro should look at it and give you an assessment, I would not drillit or cut it unless I was very proficient with the tools etc....if removing and changing the drop (don't just cut and reweld..work with the slot in the fork if it is brazed) however if the drop is just tig/mig welded a builder could remove and reposition providing you have enough clearance and the angles are correct for your application.
You may find that you will have to put additional reinforcement in the form of a gusset to strengthen the drop as well as the fork etc.
"Careful" measurement and "not" overheating the metal are keys to proper set-up.
Good Luck, Ben
Good Luck, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Liked 2,181 Times
I see you seem to have solved the problem already with expertise and tools at hand..Best. Ben
Good Luck, Ben
Good Luck, Ben
Voltaire
Voltaire
