Stronglight 93 using only small chainring - which VO bottom bracket to buy?
Old 11-13-19, 07:31 PM
polymorphself
Quoted: 132 Post(s)
Liked 14 Times in 8 Posts
Like title says, what mm would be safest bet here? Velobase is showing 118mm but I'm guessing I should shave a few off since it will only be one chainring.
polymorphself is offline
Old 11-13-19, 09:39 PM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2463 Post(s)
Liked 361 Times in 263 Posts
You don't have a pile of UN26s (or cheaper) for test-fitting?
Period catalogs suggest a 113mm for "pista" use. If you're going to use a single chainring on the outer position, I'd start there and see if everything clears.
Otherwise, if you're going to just use the inner position, I wouldn't change from the original 118mm at all.
Originally Posted by noglider
RUSA #7498
ThermionicScott is online now
Old 11-14-19, 06:39 AM
nlerner
Quoted: 1218 Post(s)
Liked 107 Times in 80 Posts
If you’re positioning the ring on the inside mount, you’ll still need a 118mm BB. If on the outside, you could probably get away with 115mm, but those shoulders for the inner ring on a mod 93 crank extend toward the frame quite a bit.
nlerner is offline
Old 11-14-19, 07:42 AM
rustystrings61
Quoted: 324 Post(s)
Liked 114 Times in 69 Posts
I have run Stronglight 113 mm asymmetric spindles in both French and British-threaded Stronglight cups with a 93 fitted with a 45T ring in the outside position on several bikes. I wound up shaving the shoulders for the inner ring down to about half or less of their original thickness AND counter-sinking the backside of the chainring bolt holes on the spider to reduce clearance issues on bikes with round or round-oval-round chainstays. Not an issue so much when there are crimps for clearances.
rustystrings61 is offline
Old 11-14-19, 10:13 AM
polymorphself
Quoted: 132 Post(s)
Hmm, it will be mounted on the outside. Making this mixte a single speed. I trust you both...so 113 or 115?
Old 11-14-19, 11:08 AM
ThermionicScott
hungry
I would definitely trust the folks who've run this crank over me.
Having a chainline that's 1mm further out than spec is no problem, but scraping the paint on your chainstay sure is...
RUSA #7498
Old 11-14-19, 11:42 AM
jonwvara
jonwvara's Avatar
Quoted: 320 Post(s)
Liked 20 Times in 14 Posts
If your best guess turns out to be a little bit short, you can always put a 1-1.5mm spacer under the drive-side cup. If your best guess turns out to be a little bit too long, you just have to live with it--although as ThermioicScott points out, a little bit long really isn't a problem.
In other words, don't sweat this too much. Whatever you choose will probably work out fine.
www.redclovercomponents.com
--Ogden Nash
jonwvara is offline
Old 11-14-19, 12:41 PM
polymorphself
Quoted: 132 Post(s)
Looks like the options jump from 113 to 116. Thinking I’ll go 113...
