An unfair advantage? Gear talk
I am still rocking a 53 tooth Chainring, many local riders are compact 50. This would seem to be a great advantage in efficiency in the 20-30mph pace range. Under 20mph I am Still in the 39 ring which I feel is a small advantage since they go to the 50 right away at about 16-18 mph.
Your thoughts?
Your thoughts?
Super Modest
Quoted: 10972 Post(s)
Liked 4,628 Times
Everybody chooses their own weapon to bring to a ride. Some have Aero wheels and some don't. Some have 15# bikes and some don't. You get the point. Fairness doesn't enter in to it.
Besides, some people spin 110 rpm and some trudge at 80.
Choose wisely and whatever works.
Keep the chain tight!
Should Be More Popular
Quoted: 22614 Post(s)
Liked 8,935 Times
Impossible to say much of anything without although knowing the cassettes being used, and the typical speeds of riders, their preferred cadences in various circumstances, how willing they are to multi-shift to work around ratio gaps, etc. And even if you did know those things, it's hard to characterize the relevance of various efficiency differences, partly because it mostly just isn't significant as long as the bike provides the ratios you need.
Quoted: 48 Post(s)
I don't really get the issue, maybe somebody can explain that to me if its the otherwise.
Its about the gear ratio, not just if your crank ring
e.g
front 50 x rear 18 = 2.78
front 39 x rear 14 = 2.79
Their ratio is close enough that with the same effort and cadence, the speed should be real close.
BikeCalc.com - Bicycle Gear Ratio Chart
So I don't see how having just 50 vs 39 front would be any advantage? Maybe except the 50x34 crank would be slightly light than 53x39 in the crank setup?
e.g
The closer ratios of a 50 would mean better tolerance to minute speed changes where a 53er would be more likely to be between gears assuming a standard of 90 rpm.
Not most of the time, I don't know where you got that from. That is during the start of the ride before it gets to be an assault. Most of the time is 20-25.
Quoted: 1218 Post(s)
Liked 188 Times
Unfair advantage for what? You get your name in the paper for winning the city limit sprint?
Gonna start complaining about people with low crr tires? Aero frames?
Quoted: 1096 Post(s)
I'm not good at math, but I find it interesting, so I hope I don't sound argumentative here - I'm genuinely curious. Meanwhile, I think that when it "gets to be an assault," having a bigger big ring would definitely be an advantage - a no-brainer, but not unfair. Nothing is stopping the other guys from riding a standard.
Quoted: 2331 Post(s)
Liked 5,020 Times
?? You mean people actually use the smaller chain ring when not climbing???? WHAT!!!!
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4401 Post(s)
Liked 3,024 Times
Though I think that the overall gist of this thread is pretty silly, yes, on my bike with a 53/39 (and a 12-27 in back, fwiw), I can ride quite happily in the flats on my 39, unless the pace is, say, above 22 mph. Admittedly, I am more often in the big ring, but when you don't have a compact, the small chain ring is more than just for climbing.
Farmer tan
Quoted: 4813 Post(s)
Liked 3,941 Times
Larger chainrings and cogs are slightly more efficient. Slightly. Having the right gear ratios for the speed, effort and your legs is really important. Nothing about either the 50 tooth or the 53 have anything special there except the best cassettes for each (for any particular rider) will be slightly different. This was a concern 30 years ago when the smallest cog was a 13. Now with 11, hardly.
Ben
Ben
Quoted: 509 Post(s)
Liked 9 Times
Ben
Ben
Bikes: Specialized Roubaix, 2011 and 2017
Quoted: 165 Post(s)
War never changes.
I remember back in WW2 when all our boys were equipped with triples, and even then the supply of good chainrings was dry before we even got to the shores of France.
I'm glad to hear that you are better equipped for your local group ride. May you have the best luck with your assault. May you claim victory in this mighty conflict. Mighty hero, you carry our hopes on your back.
I wish only that we could one day sue for peace, and with light hearts and bandaged wounds... just go ride bikes together.
But go out there and slay those who oppose you, mighty standard-pedaler! I will await you, fresh paraffin in hand, when you return victorious.
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
If you're pedaling 90 rpm with a compact 50t big ring, you'd have your final 2-tooth jump as you accelerate and shift up from 18.5mph to 20.7mph, while with a 53t you'd hit it between 19.7mph and 22mph. Above that and it's all single tooth differences as you go into smaller cogs on most road cassettes so there isn't any real difference there until you get to speeds where you are spinning out the 50t.
Still, most people don't pedal at a completely fixed rpm and are just fine spinning up a bit before shifting, so I don't think there is any real advantage here.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Rode a 50/34 for half a season. 34 was almost useless and spent most time in the 50. Annoyed the crap out of me. That and having to ride in the 50 and on the end of the cassette any time it got fast was irritating.
Quoted: 6556 Post(s)
Liked 58 Times
War never changes.
Liked 5,020 Times
