Winter and spring maintenance
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
Winter and spring bring wet and grimy conditions, curious to hear what folks do to keep up on maintenance in those conditions. Or not. Wiping down the frame and keeping moisture off leather saddles, mitigating against drivetrains and braking surfaces eating themselves, etc. Most is probably self explanatory.
Any special chain lubes, cleaning regimens, etc. I suppose most of it is going to be just a matter of keeping things clean, but maybe there’s a tip or two that’ll help speed things up or make ‘em more effective.
Speaking for myself I definitely could be better about keeping up, but the biggies are wiping down the chain thoroughly, cleaning the road grime out of the freewheel/cassette and off the chainrings and jockey wheels. Wipe down the braking surface of the rims with a clean shop rag and hit the brake pads with a clean cloth and maybe file as needed. I’ve been using Chain L chain lube for a few years now and love that it’s pretty much a set it and forget it kinda lube versus other stuff I’ve used in the past. T-9 was nice, but I found I needed to apply it every ride or two in the best conditions let alone winter in New England.
So, what do?
So, what do?
Quoted: 3811 Post(s)
Liked 6,717 Times
I took the plunge (of sorts) and waded into the deep waters of chain waxing. Very happy with the results so far! As is also likely true in the nutmeg state, they salt the crap out of the roads around here, so every ride is pretty much a brining experience. In the past, I've put my bikes away wet and just figured I'd replace the chain come March, but this year I decided to a more preventative stance.
Quoted: 932 Post(s)
Liked 1,317 Times
Ditto with chain waxing. I use Molten Speed Wax and a crockpot. This combined with using Wipperman Connex quicklinks to easily get the chain on and off makes it easy to have an always pristine chain. The downsides: 1) initial chain prep when changing over to wax takes a while; 2) no chain tattoos.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,803 Times
Quoted: 2588 Post(s)
Liked 4,824 Times
I'm a wimp so don't ride in the gucky weather if I can help it, but if I get caught out there I do a deep clean that very evening. My deep clean is similar to the OP's in that I remove the wheels, put the bike in the stand and then deep-clean the drivetrain with degreaser, old toothbrushes and rags. If it was really bad? Sounds stupid, but I remove both tires and clean the sidewalls with a scouring pad. That way the sidewalls don't turn gray/black too soon and they live that bit longer. If the bike in question has a cutout in the BB shell, I'll remove the NDS cup and see if any gunk got shoved up into the stays, but usually that's not an issue. I'll shine a flashlight up the fork steerer to see if anything got sprayed up there, too. Don't forget to use an old toothbrush on both brake fixing bolts if they're recessed because they gunk up quickly, too (of course, if you're running fenders the last couple don't apply).
Last thing I do before putting everything back together is eyeball each brake pad and use a dental pick to remove those tiny chips of rock which always seem to become more easily picked up and embedded in wet weather. These little guys act like sandpaper and score sidewalls, wearing them out before their time.
The time involved in clean up afterwards, plus the increased wear of braking surfaces and contaminated tire sidewalls are major factors in my personal decision to refrain from riding in the wet. Others are much more hardy and worry less about their equipment, and I get that. I only end up having to do these things to re-animate my bike if I get unlucky and the skies open up while I'm far from home
A very rare photo indeed:
DD
DD
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
Chain waxing is interesting...the roads here in nutmeg land are heavily salted and leave a nasty mess on the bikes. I got out for an hour yesterday during lunch and the drivetrain was much nosier than I had expected or would really call acceptable. Granted, the previous ride was a night time rain and slush ride with a good helping of sand and small rocks in the mix. All I did from above was give the chain a good wipe, no other cleaning to speak of. That works with my current chain lube much of the year with very infrequent lube reapplication, but I guess it’s about time for a thorough cleaning and reapplication. Might be a good excuse to get the small jewelry ultrasonic cleaner out and give the chain a bath with some Dawn. Or maybe just strip and wax a fresh chain from the stash.
Good point on picking rocks out of the brake pads, DD. I need to get a dental pick, I’ll typically use the corner of an x-acto knife blade for that job. It was the sound of sandy pads on the rims that prompted this thread. The nice anodized tubular wheels don’t get ridden in this stuff...! Same with nicer vintage chains for that matter.
I’ll add that early this winter I picked up a waxed canvas saddle cover from Randi Jo Fabrications, along with a wool cap, and definitely recommend their stuff.
Liked 6,717 Times
+1 to Randi Jo goods. Top stuff.
I recommend starting with a new chain with the waxing regime. I’ve cleaned a couple of used chains so far, and it took many steps in the ultrasonic and then in mineral spirits to get them clean. They looked clean coming out of the ultrasonic (with hot water and Dawn), but immersion in mineral spirits revealed lots of dirt/grease still there.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 932 Post(s)
Liked 1,317 Times
I recommend getting a small (1.5 qt) crockpot so that the wax is deep enough to easily immerse the chain. Also, they're cheaper (i.e. $10-15).
Liked 6,717 Times
Quoted: 987 Post(s)
Liked 641 Times
Liked 6,717 Times
Some Weirdo
Bikes: '86 Schwinn Prelude, '91 Scott Sawtooth, '73 Raleigh "Grand 3"
Quoted: 223 Post(s)
Liked 141 Times
Clorox wipes clean gunk from skinwall tires. It's like magic. These tires are 4 months old with 5 rain rides. They don't look it though.
Likes For Ferrouscious:
Quoted: 987 Post(s)
Liked 641 Times
(offered in the topic "Winter and Spring maintenance" as an example of what NOT to do)
Likes For tiger1964:
