Why Spec went back to clinchers
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Who is the author and what's his/her weight? Article says he had the 25mm tires at 75psi
Roval recommended inflation chart
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
You mean they went back to tubes. What would have happened if a tubed tire exploded? I suspect not much difference in outcome - the tire will roll off the rim just the same.
In other words: look where you put your wheels and avoid crap.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Advocatus Diaboli
Liked 1,533 Times
Ahh.. buried in the comments. So he is 160lbs. And Silca pressure calculator, in addition to the Roval chart, indicates seem to both put recommended PSI in the mid to upper 80s. Could be a contributing factor, especially on 4500 mile (or km?) tires?
Edit: and the author seems to have a history of tire problems (his 3 previous tires all had "total tyre failures due to punctures within about 1000km"
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
This is interesting. I cut a sidewall yesterday on a long ride including some terrible pavement. The cut was big enough that it wouldn't seal - but the tire stayed seated and the rim was protected. Slowed down easily, popped in a tube, went another 60 miles.
Likes For ericcox:
That chart recomends about 20 more lbs than I run with tubes. I thought the advantage of tubeless was running lower pressure?
Likes For popeye:
Quoted: 850 Post(s)
Liked 344 Times
I've run very, very low pressure in tubes. 40 psi in 25mm tires at 135lbs. No issues ever.
That being said, those pressure recommendations seem inline with what I find to be the optimal balance between speed and comfort, if you use measured tire size, not marked. Those pressures are absurd if you go by marked width. Zipp doesn't even let you go past 72psi.
Quoted: 20810 Post(s)
Liked 9,456 Times
Advocatus Diaboli
Liked 1,533 Times
Liked 9,456 Times
The zipp pressure calculator includes bike and rider weight, plus internal rim width. I've been using their recommendations with my fulcrum racing 3 wheels. Must yesterday I hit a big piece of flagstone rock about an inch thick and 3-4 inches in diameter at over 30 mph on a winding descent. I was paying too much attention to the cars ahead and caught it on the left side of the tire. It hit hard enough to bend the bead area in one spot, but no air was lost and the tire was had only a minor scuff. When I got home, I removed the tire and straightened the ding with a pair of wide jaw electrician's pliers, with a popsicle stick on both sides to protect the rim. All is good now. A carbon rim might have a chunk broken out of it, with a hit that extreme.
Likes For asgelle:
Advocatus Diaboli
Liked 1,533 Times
And how did this become an alloy vs CF discussion?
I should be able to speculate on what might have happened with a carbon rim. My wheel hit so hard that I heard the rock to metal contact. If I'd been using 80-90 psi, the rim might not have been damaged. At least it was easily repaired.
Advocatus Diaboli
Liked 1,533 Times
Recommended by who? What was your actual 'recommended' pressure for what size (as measured) tire width?
CL/CLX series dont hold a tire bead all that well. Having CLX32,50 and 64's I decided to off them last year. As for why spesh has gone back to clinchers well the new rapides are not tubeless approved .. so what do you expect ?
Liked 9,456 Times
Hit a big chunk of rock through your own error and then question the validity of a pressure calculator and cast aspersions upon carbon rims that you weren't riding. Makes sense.
Quoted: 18883 Post(s)
Liked 10,646 Times
I hit a pothole so hard I was sure I must have damaged the wheel and it was still true. An alloy rim would have never been perfectly straight again.
Liked 10,646 Times
Quoted: 3957 Post(s)
Liked 7,310 Times
I hit a curb at 20 mph one day and dented my alloy rim. If it had been a carbon rim, it would have exploded and probably killed everyone within a 100 ft. radius.
Likes For tomato coupe:
