Fork; Lack of filler
Quoted: 13 Post(s)
Hi,
I bought fork and found that under "crown" there is a gap between two elements. Some kind of filler is visible only on 1/3 of hole. I have the same second fork ( damaged), and there is no gap.
Is this problem? Is it safe to use?
Quoted: 1529 Post(s)
Liked 718 Times
Might be a weak spot... Only expensive testing would tell
Quoted: 645 Post(s)
Liked 797 Times
What’s the filler in the second fork made of? If it’s metal, it might be structural. If it’s something softer, then it’s likely just the fill the gap. In that case, if it makes you feel better, buy some silicon caulk and squirt some in there
Quoted: 13 Post(s)
@Litespud it is some kind of hard compound.
I asked LBS ( Road bikes experts) and they said that it is Brake Insert glued inside and I should not worry about too much.
Quoted: 13 Post(s)
I inspected fork from inside through the hole. It seems that glue is lets say "esthetic" element. Brake insert is one big element which goes through whole upper part of fork and above crown joins steerer tube.
